Question about Fisher and Paykel Washing Machines
Wshine machine bearing replacement - Fisher and Paykel Washing Machines
    Genius:
  • 1,028 Answers
If you're takling about center tub bearing complete outer tub will need replacing bearing not a separate part
Posted on Oct 30, 2008
Crosley washing machine making a clicking noise when I turn it on.. Machine won't do anything ?
(1) The tub bearing is mounted in the middle of the outer tub. The tub bearing helps to keep the inner tub spinning smoothly. Replacing the tub bearing is a very involved repair and will require disassembling most of the washer. If the tub bearing is defective, i recommend replacing both the outer tub and bearing.
Jan 11, 2017 | Crosley Washing Machines
Why won't it agitate or move drum?
Screeching noise is typical to drum's broken bearing issue.
See some infor about issue:
How to Diagnose Drum Problems in Washing Machine
How to change drum bearings on washing machine
How to Change the Bearings in LG Washing Machine
How to replace washing machine bearings on Bosch Neff Siemens and some...
Some more video there... explore
Now, if you don't find it so easy to replace those bearings or you are not sure if this is your problem, call a repair service
Aug 18, 2015 | Washing Machines
My washer makes grinding sound when washing, how do I fix this?
Guess it's a bearing in the drum, though just my appreciation. If you are not a tech in washing machines, you should call a reapir service to get it dismounted and replaced
Watch some videos about issue. Take note that you are not specifying your make an model and procedure might be somwhat different for your particular washing machine.
How to Replace Washing Machine Bearings
How to replace washing machine bearings on Candy Hoover Otsein Zerowatt
Aug 12, 2015 | Washing Machines
What causes this machine to squeal while running?
I had a similar issue, had a bad bearing. A quite frequent failure int this device. Only way to diagnose is dismounting it
These are not properly your model but see some videos how to do it:; might help to understand the job
Repair HE3 Washing Machine Bearing Noise
ApplianceRepairVBlog 2 Replacing the rear bearing on Whirlpool Duet...
Duet Whirlpool Sport Changing Bearings
Aug 02, 2015 | Whirlpool Calypso GVW9959K Top Load Washer
How do i replace Maytag Neptune front load washing machine bearings
The machine obviously must come apart. See this youtube video:
Dec 13, 2013 | Washing Machines
Samsung front loader washing machine
Sounds very much like the drum bearings have failed. It is not a DIY job I'm afraid. Up to date washing machines are now impossible to actually replace bearings and only way to repair is to replace inner and outer drum assembly. This is a 1/2 a day job at the least to a professional. Older machines.....you can replace the bearings but this still involves removing the outer drum ou from under the washing machine, and the a very normal bearing removal and replacement procedure. Make sure the bearings are knocked in very straight and not on the skew. Good luck
Nov 24, 2013 | Washing Machines
On spin cycle it it has a loud noise like bearings
That will be the bearings then...
It's impossible to give you any more specific advice as you haven't stated a make and model. On some machines the drum bearings can be replaced, on many modern machines they are sealed for life and are non-replaceable and when they fail the rest of the machine is usually pretty well worn out as well.
On those domestic front loaders which can have new bearings fitted, bearing replacement is a very labour-intensive job and is often not cost effective. On commercial machines it's usually far more straightforward. on most top loaders (excluding top loading machines with a horizontal front-loader style drum), bearing replacement is relatively straightforward.
Jun 21, 2011 | Washing Machines
Is there a reason for the bearings in a front loading machine to keep needing to be replaced
It could be that the new bearings are being fitted onto a worn drum shaft, this would soon cause the bearings to fail again.
If it has not been replaced, then it should be done so.
Jan 27, 2010 | Washing Machines
Washing Machines Logo
128 people viewed this question
Top Fisher and Paykel Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a Fisher and Paykel Washing Machine Expert? Answer questions, earn points and help others
