Question about Sony NW-E003F MP3 Player
Cant detect with computer
If i connect my devices(NW-E003Fmp3 player) with computer.The system show errror"USB Devices cant recognized).But inside have some show that will play perfect and FM also ok.
if u found solution for this mean,pls contact through this mail id (rubesh_ece2004@yahoo.co.in)
  • sombear Nov 23, 2008
    i have the same prolem with you.
  • Anonymous Nov 25, 2008
    Yeah I have the same problom...one minute it's working the next it's not :( and sadly I have all my school files on it...wow this sucks
Try this:
On the back of the MP3 player. there's a small reset button, pressing it should fix your MP3 well still maintaing all of the same files on it...
Posted on Nov 25, 2008
My computer cant recognize SanDisk sansa clip+ 4GB, where can i download drivers???
There are no particular drivers for any USB devices . They are all Plug and Play devices and will be automatically detected unless faulty or if you are using an older version of Windows ( 98 / 95 etc.).
XP /Vista / 7 will detect your device automatically. Try it on some other USB port on the back of the computer instead of the front ( where usually people tend to connect portable devices ) if its a desktop PC.
Apr 29, 2011 | SanDisk Sansa Clip MP3 Player
When i installed the media player into my computer. i get a little screen saying usb device not recognized. one of usb devices attachedto this computer has malfunction,and windows does not recognize it....
Hi, smpk4083 mp3 player not recognized by the computer
Why is my smpk4083 mp3 player not being detected by my computer when I connect it?
This may be caused by one of the following:
1. Minimum system requirements were not met.
2. Corrupted drivers.
3. Computer restrictions.
4. Power issue.
To resolve this issue, try the following solutions:
SOLUTION 1 - For brand new player or first time connecting to this computer.
For Windows XP users: verify the following operating system requirements are met.
- Windows XP SP2 or higher
- Windows Media Player 10 or higher
Download and install the latest Windows Media Player if it's not installed.
For Windows Vista users: If the player is seen in My Computer when using MTP mode, but not showing in Windows Media Player.
- Download the hotfix from http://support.microsoft.com/kb/939211.
- Run the hotfix.
For MAC users, see smpk4083 mp3 player not recognized by a MAC OS
NOTE: If you are trying to connect to a Computer at work that is part of a network, there may be user right restrictions that are set to disable access to new hardware or stop any program installations. You may need to check with your IT administrator to see if this is causing the problem.
SOLUTION 2 - Refresh the driver
STEP 1 - Connect the smpk4083 mp3 player to the PC
The screen on your player should turn on, show 'Connected' and indicate the battery charging or full.
- If the player does not turn on try other USB ports or on another computer if one is readily available. Ensure you are connecting directly to the computer USB port and not to a USB hub.
- If there is nothing showing on the screen and the player does show up in as a storage device in an explorer window, then the screen is just not working.
If you receive the error "USB Device Not Recognized" on the computer, the player is most likely failed. Additional troubleshooting is unlikely to correct the problem.
STEP 2 - Check under Device Manager
1. Right-click My Computer, and select Manage.
2. Click Device Manager on the left pane.
NOTE: smpk4083 mp3 Players can connect to your computer in MSC or MTP mode. Exceptions are smpk4083 mp3 player Connect and smpk4083 mp3 Express which only use MTP mode. MTP mode is the recommended and default method for smpk4083 mp3 Players when used with Windows OS.
The smpk4083 mp3 player will show up on Device Manager's right pane as:
1. USB Mass Storage device (if the player is set to MSC)
2. Portable Device (if the player is set to MTP mode)
If there is a yellow exclamation point (!) or question mark (?) beside the device, try to refresh the drivers.
STEP 3 - Refresh the drivers
1. Right-click the entry with the error mark, select Uninstall.
2. On the top menu, click Action then select Scan for hardware changes.
NOTE: If a device with yellow exclamation point (!) continually appears and disappears, then the player is most likely failed. Additional troubleshooting is unlikely to correct the problem.
Hope it helped.
Have a nice day,.
Feb 22, 2011 | Sylvania Audio Players & Recorders
My computer will not recognize my 4GB PMP350-4 POLARIOD mp3 player i want to use it
Dear tenmil,
Welcome to Fixya,
Many of the USB devices, and Mass storage devices are not detected by a system when you connect them to USB extension slots such as front USB slot,USB hub etc. So you have to connect your Polaroid mp3 player to a backside onboard USB slots. It will definitely detect your device if your device is working normally. I think it helps.
Best Regards,
Chandrashekhar Bhat
Dec 26, 2010 | Computers & Internet
How do i add music to my pc from my mp3 player?
  1. Hook the device to a USB connection on your computer.
  2. Go to the settings on your device to find a "USB CONNECT" or "USB MODE" option. Some devices do that automatically when they detect power on the USB cable.
  3. Your computer should now automatically detect the device, probably showing it as a removable hard disk. Both Macs and Windows XP computers do a very good job with this, older operting systems can be more challenging (e.g., Windows 98, MacOS 9).
  4. Once the USB is already detected you may now copy the musics from your MP3 player to your pc.
Hope this help. :)
Dec 18, 2010 | Computers & Internet
SanDisk Sansa e250 MP3 Player with Mac? Is there any driver to make it compatible with Mac platform? Thank you
NOTE: MAC computers do NOT support MTP modes of USB conectivity in a MP player. A Sansa player in MTP mode when plugged into a MAC computer will NOT be detected or recognized. MAC computers supports Sansa players in MSC mode Sansa players can only be recognized by a MAC if the USB mode on the Sansa player is set to Auto Detect or MSC.
Check in the System Profiler Open System Profiler from the Utilities folder, which is inside the Applications folder. From the Contents column on the left, under the Hardware header, select USB; the panel to the right will show all the USB devices that the computer recognizes. It may not identify them correctly by name, but it should have the right number of devices listed. . Navigate to USB Mode settings. Sansa View - From the Main Menu, select More > Settings/Options > System Settings > USB Mode.
Sansa Fuze and Sansa Clip+ - From the Main Menu, select Settings > System Settings > USB Mode.
Sansa Clip, e200v1 series, e200v2 series and e200R - From the Main Menu, select Settings > USB Mode.
2. Select Auto Detect, MTP or MSC. e200R - PlayforSure is MTP and Rhapsody is MSC
See this tip posted here on this site for a better explanation on the modes - MTP and MSC. Solve your MP3 Player Connection Problem.
Feb 05, 2010 | SanDisk Sansa e250 MP3 Player
Sony Walkman not connecting to computer
I had a similar problem (my computer uses Windows XP) - Sony Walkman beeps a couple times when I insert the USB Cable that connects it, like it is connecting, but it does not charge or is not found by Windows Media Player. In my case, the way I fixed it was to:
1, Go into Control Panel
2. Double Click 'System' ICON
3. Select Hardware Tab
4. Select Device Manager
5. Select 'View' at the Top
6. 'Devices by Type' AND 'Show Hidden Devices' should be selected
7. 'Scroll down to 'Portable Devices' and open it up.
8. My Sony Walkman was there with and Exclamtion point ( ! ) in a yellow circle,
9. Right Click on this yellow exclamation point.
10, Select 'UNINSTALL'
11. Once the computer says 'Device has been Uninstalled, Disconnect your Walkman's USB cable then reconnect.
12. At this point, my Walkman was recognized by my computer, started charging, and was recognized by Windows Media Player
Hope this helps
Feb 16, 2009 | Sony Network Walkman NW-E005 MP3 Player
My sony VGN N220E does not detect external devices
Try reinstalling your usb ports.
1. goto desktop, right click on my computer and press manage.
2. goto the device manager, find the usb devices / ports.
3. Make sure you are useing a ps2 mouse / keyboard since if your mouse/keyboard is connected to usb they will stop working untill your pc is restarted and the devices are reinstalled.
4. Uninstall all usb devices.
5. after all usb devices are uninstalled reboot the pc.
If the problem is with your drivers ( your pc detects the mp3 player but no drivers found) Download the newest drivers for your product and operateing system from the vendors website.
Nov 30, 2007 | Computers & Internet
Failes to detect mp3player
If you are using Windows 95, the player is not supported. If you are using Windows 2000 or XP, it will show the player as MTP player. If the MTP is not shown on My Computer, install the player as removable disk (use Device Manger, find the device connected, right-click on the player icon, and click Update Driver).
Sep 28, 2007 | Sony NW-E002 MP3 Player
My computer can't recognize it as removable device,
Is there a free drive letter? Typically, USB devices want to be D, E, or F and if you're on a network and your drives start with F and you have additional drives and no free letters that can cause a conflict. Does windows detect the device at all when plugged in? If so, that's a good sign. If not, check in Device Manager for your USB ports and make sure you don't have any with yellow exclamation marks. From My computer, right click and choose Manage to check "disk Management" to see if your player shows up at a low level.
Jun 08, 2007 | Sony Network Walkman NW-A3000 MP3 Player
Sony NW-E003F MP3 Player Logo
80 people viewed this question
Top Sony Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Sony Audio Player and Recorder Expert? Answer questions, earn points and help others
