Question about Insignia Sport MP3 Player
Cuts out it tends to cut out from time to time as if it were skipping..its only for a second then it comes back on
  • ps3luver Oct 30, 2008
    i would return it but i work at best buy and i got it for crazy cheap so its no big deal
I been having problems with my insignia the 3rd month i got it witch been i exchange about three times
if i were u ill go and return it and get another name brand insignia sucks!!! my wont play the songs and best buy wont return it even though i got the 2 year warranty!!!!
Posted on Oct 30, 2008
When my 1990 subaru legacy is cold it runs good then after 10 miles it starts skipping engine light comes on and a strong ordor of gas can be smelled. it does not run hot but when it starts to cut bac
Could be a faulty O2 sensor. The sensor would not take action until the engine warmed up. Have you checked for trouble codes in the engine computer ?
Jul 28, 2014 | 1990 Subaru Legacy
2006 pontiac grand prix is skipping while driving
It's the CPS (crankshaft position sensor) beginning to fail. The sensor is located behind the harmonic balancer on the lower RH side of the engine. If you look down the accessory belt from the alternator you"ll see a wiring harness leading behind the crankshaft pulley. An easy way to diagnose a faulty sensor is to warm up the engine and carefully tap on the sensor bracket while the engine is idling. A bad sensor will cut out and the engine will stall.
Feb 01, 2013 | 2006 Pontiac Grand Prix
I have a rockford fosgate 2400 watt amp 801s it has two power line hooke ups as does the ground is this for a seconde amp or does it need two power wires and two ground wires.the reason i ask is its tends...
The connections you are speaking of are not for a different amp but to provide enough amperage to and from to amp. Your amp is running to hot because the impedance on your subwoffer is to low
Impedance= ohm rating of your speaker
Jul 14, 2011 | Car Audio & Video
Speakers cutting out
Vibration Damage to audio circuit. try Iron Cross Audio. www.ironcrossaudio.com
Apr 22, 2010 | Harley Davidson 426290 AM/FM Radio
Mp 4 my songs are being cut.
Sounds like it's on Intro mode like the older discman's back in the days. Verify the option or read the instruction manual to find how to turn on and off that function. Should be a little icon somewhere too to indicate it is in that mode. It may have another name, but it will do the same thing, which is give you a few seconds of listening of each song to find a song you really want to hear.
Jul 23, 2009 | Audio Players & Recorders
Speedo will cut out when driving
Sounds like your "speed sensor" is failing. When it fails it will cause irregular shift patterns and engine idle speeds.
Jun 10, 2009 | 2000 Ford Focus
Engine skipping
well i had a 98 dodge neon that seems like it did the same and it said engine misfire and all i did was due a tune up change spark plugs and wires.
May 21, 2009 | 2007 Dodge Charger Daytona R/T Sedan
Engine cuts out when cold
check the engine and connect a heater for the engine
Dec 15, 2008 | 1988 Plymouth Voyager
High volume cut out
power amplifier circuitry problem,you need a qualified serviceman.
Oct 04, 2006 | Sony STR-DE595 5-Channel Amplifier
Insignia Sport MP3 Player Logo
Top Insignia Audio Players & Recorders Experts
Alan Matzke
Alan Matzke
jason
Are you an Insignia Audio Player and Recorder Expert? Answer questions, earn points and help others
