Question about Optoma HD20 DLP Projector
Optoma hd20 fan shut down
Fan
  • dsantiagosoy Mar 14, 2014
    I had a fan failure problem on my optoma hd20 Ok I fixed my fan fairlure problem, just took the small fan out of the case and clean it THOROUGHLY ! Put it back inside and now my projector hd20 is working like a charm...
    New Friend:
I put this here because when I was experiencing the same issue I found there was very little info online for this topic. Optoma asked me $125 just to take a look at my out of warranty hd20 projector after I started getting the dreaded "fan failure" error message, I got this error mesage after replacing the bulb (its important to note that the bulb did explode in the unit so some of the debris may have lodged in the fan.) Optoma also kept saying stuff like motherboard issues and fan sensors on the phone. Everything I've read has said the repair price is so high on these issues that it is better to upgrade to a new projector so I resigned myself to doing that very thing. Then I ran up on this video and thought what the heck. So I took the plunge and popped the case off and sure enough the same little fan was stuck and covered with dust. I gently moved it with a screw driver and blew all the dust out of it. Plugged it back in and I'm experiencing glorious 135" hd once again.
Posted on Apr 11, 2014
  • Cynthia Roberts
    Cynthia Roberts Apr 11, 2014
SOURCE:
SOURCE: cooling fan problem projector
I have a similar issue though mine isn't quite as extreme as yours. Got a couple things you can do.
1. clean out the projector with compressed air. You might have dust building up on components that is trapping heat.
2. Your fan might be burning out. Needs to be replaced. I'm still working on trying to figure out what tipe of fan it needs.
3. The temperature sensor might be going bad. This one is less likely and most complex to solve as it depends on how the system measures the temp. I haven't checked in detail yet.
4. Replace the whole unit or send it in for repair. Both options will be costly...
Posted on Aug 04, 2009
Basti
  • 1447 Answers
SOURCE: Optoma EP7155 gets very hot and shuts down.
Hi
Possible filter problem since its overheating. clean up filters and make sure that you use projector in an open area so air can cool it off while running.
Hope this helps
Posted on Mar 26, 2010
  • 11 Answers
it could be the fan there are normally more than one, replacement is not hard just make sure you remember how it goes back together, a hint would be to get a digi cam for every part you take out, it may sound silly but very usefull esp when ordering parts, or make sure the lamps was replaced with the right one, if you still have the old one check the code numbers match... good luck
Posted on May 17, 2010
toolkits
  • 1099 Answers
SOURCE: HD20 switches on by itself
the projector will shut off when the lamp hour count reaches expected lamp life. It will restart only long enough to read the hour meter again then shut it's self off again. You can manually reset the hour meter to continue using the same lamp. Good luck.......
Posted on Aug 02, 2010
SOURCE: I just got a new
Hi miracles4all: I solved HDMI signal issue in my Optoma HD20. In my case it was the lack of contact between the HDMI cable plug male ending and the Optoma HD20 HDMI female port. My 35ft cable plug male HDMI ending was not completely "seating" in the Optoma HD20 HDMI female port. I solved the problem by purchasing a HDMI female to female coupler and adding a 3ft HDMI cable that had a slim male ending. This 3ft HDMI extension cable made better contact to the Optoma HDMI port and the projector was immediately able to detect HDMI signal. Hope this helps you... kaufmanekpr
Posted on Dec 27, 2010
Does the Optoma HD20 DLP projector have a air filter? If it does, where is it located?
Hello
The Optoma HD20P doesn't have an air filter.
If you remove the covers you will find 2 cooling fans that get a build up of dust on the leading edges of the fan blades.
These can easily be cleaned with a small paint brush and a drinking straw to blow out the excess dust.
If you are having overheating problems, please view my post on replacing the heat sink compound on the image processor.
Cheers
Jul 09, 2014 | Optoma HD20 DLP Projector
yes, any projector with a air filter.
if your projector often make overtemperature protection, you have to inspect the air filter,whether it is still clean, otherwise, you need to replace it.
Jul 09, 2014 | Optoma Hd20 High Definition 1080p Dlp Home...
Why does the Optoma HD20 DLP Projector bulb have dark area on screen
you need to inspect the light tunnel or concave lens( assy relay len)
May 28, 2014 | Optoma HD20 DLP Projector
Optoma HD20 DLP Projecto problem
this is not an hd20..... nor is it the right kind of capacitor that an hd20 needs...........
Aug 21, 2012 | Optoma HD20 DLP Projector
Optoma PCB MAINBOARD MODULE FOR 8EG
My HD20 also broke after about 1000 hours. Their estimate is $703.00 to replace main board and lamp module. Image shuts off automatically after 3 mins of starting. Lamp fail led goes solid red.
Nov 10, 2011 | Optoma HD20 DLP Projector
Optoma hd20 green light flashing brand new bulb doing same thing
I think your mainboard is fried.
Had the same issue, but still didn't find a cheap way for a replacement. Optoma wants at least 400 € ...
Apr 18, 2011 | Optoma HD20 DLP Projector
I just got a new Optoma HD20 and only after 1day of use it is not showing HDMI signal, although it is showing VGA signal. Why is this?
Nov 05, 2010 | Optoma HD20 DLP Projector
I have an optoma HD20 and it connects using a 1.5m HDMI but as soon as i try a 10m HDMI connection (even with a booster it does not connect) any suggestions welcomed?
Hi kgomer782 I have similar issue. My optoma hd20 signal connection with a 3/6ft hdmi cable is perfect. However, no signal is detected when connected to a 35ft hdmi 1.4 cable. The 35ft cable is indeed working becuase I tested it succesfully when connected to a 1080p HDTV. Did you received any solution to your problem? I wonder if it has anything to do with the HD20 design of the "debossed" hdmi ports that prevents the cable plug from getting completely "seated" in the port? My 35ft cable has a flat square male ending however, the 3/6ft cables have slim male ending that seems to accomodate perfectly in the Optoma's hdmi port design...kaufmanekpr
Aug 07, 2010 | Optoma HD20 DLP Projector
Aug 02, 2010 | Optoma HD20 DLP Projector
Optoma HD20 DLP Projector Logo
3,081 people viewed this question
Top Optoma Office Equipment & Supplies Experts
Jason
Marvin
Marvin
Are you an Optoma Office Equipment and Supply Expert? Answer questions, earn points and help others
