Question about Riso RZ220 Duplicator
Riso Rz 220 copies are coming out to light.
Even after 50 copies or more to ink it up. Help!
  • 318 Answers
1)You can set the dencity of the riso on the controll panel before you do your masters.
2)Always use original ink.
3)If you are a bit technical you can remove the pressure roller and strip all old ink buildup from it.was it with water ann soap.
If you open the drum and take it out completely,the pressure roller is the black roller inside the machine that put directly pressure on the drum.There is only one screw to loosen and then it hooked out,but it can be tricky to hook it back if you not doing it every day.
Posted on Oct 30, 2008
Riso rz 390
There should be a built in head cleaner. I think you can access it through the control panel, then device and printers. right click on the printer with the issue, scroll down to printer properties. there should be a box that says "print test page" when the test page prints it should ask you if it is ok, this is where the clean head should be.
Jan 18, 2014 | Office Equipment & Supplies
Riso RZ 220 UI The master drum will not come out and the green light is not on.
This is for master drawer not responding to green light to be released question. Try turning ON machine (turn off first) while holding down the reset button. Also a mechanical way is a small hole to insert a pencil, eraser end first, just below green latch area. Just insert hold in while squeezing release latch. to drawer.
Sep 09, 2013 | Riso RZ390 Duplicator
Service manual of riso Ez 231 E
Please I need a solution to riso ez 231 p-96-569
Jan 23, 2013 | Riso Office Equipment & Supplies
Somebody that speak Spanish? Riso RZ 220 UI have a code that say P18 531. What is the problem?
P18-531 means: Print drum lock sensor is still ON even after 100 milliseconds after the print drum lock solenoid is activated.
Mar 16, 2011 | Riso RZ220 Duplicator
I have a problem error fo115 of riso rz-220
F01-115 means no master on drum at start of printing. Make sure you make a master before trying to print.
Jan 20, 2010 | Riso RZ220 Duplicator
Error Code -534 on my Riso RZ 390. Drum is stuck in machine and won't release.
D04-534 means incorrect ink cartridge set. This could be caused either a) it IS the incorrect ink cartridge, or b) the RF tag that is struck to the end of the ink bottle is damaged. Try a new ink bottle.
Make sure to use RISO ink designed and made specific for an RZ230.
Jan 03, 2010 | Riso RZ390 Duplicator
Riso RZ 220UI
1-need to find out if image is on the drum, make a copy and stop it open and look is there toner on the drum itself? yes then the problem is with the Seperation
2-No, then the problem is with the Transfer
Sep 05, 2008 | Riso RZ220 Duplicator
RZ-220 Error Code P04-513
that is the ink overflow sensor.
Jun 20, 2008 | Riso RZ220 Duplicator
Lexmark 4039 10r
I'm pretty sure this is a printer not a copier.
Take out the cartridge and turn it upside down, you will see a (Usually) green cylinder, does it have a ring of toner, or does it appear to have been scrathed ?
Take the copy and put it next to the drum, does the lines match? Then replace cartridge.
If not open back and take out fuser ( two screws for cover and two screws for fuser, are the rollers o.k? replace fuser.
Oct 02, 2007 | Riso RZ310 Duplicator
320 people viewed this question
Top Riso Office Equipment & Supplies Experts
Marius Chiriac
Adorjani Laszlo
Are you a Riso Office Equipment and Supply Expert? Answer questions, earn points and help others
