Question about Toshiba Computers & Internet
Equium Laptop Headphones Not Working
I have a Toshiba Equium laptop running Vista Home Premium. When I plug in headphones the speakers should go off and sound come out the phones, but this is not happening -- speakers stay on and no sound on phones. I'm pretty sure this use to work OK once upon a time.
  • dave 412 Nov 03, 2008
    I found two things that resolved this issue --
    First I had to make Headphones the Default device in Playback settings in Hardware and Sound in the Control Panel
    Second I discovered that just plugging in the phones does not necessarily actively switch the sound output. For some applications (e.g. RealPlayer) it doesn't see a change of device on-the-fly, but you have to close and re-open the app for it to start using the phones. Similarly if you are listening on phones and then unplug them.
  • 32 Answers
The jack might be disconnected from the mobo,or it's simply broken or the headphones don't touch the contact metal properly
Posted on Oct 30, 2008
Headphone jack not functioning properly
This is the normal way for this laptop ..leave it always with the headphones on selected in that list ..cause if the main speakers don't work well there is no point in using them ..This way you will run whatever yo will plug in ..speakers or headphones..The only setting difference in headphones and stereo out ..is that for headphones will but the speakers of the laptop when plugged in ..This way it will even help you if the speakers are making weird noises cause they are damaged ..
Dec 22, 2011 | Computers & Internet
External speakers not working for Alienware laptop using windows vista
first, make sure the speakers actually work before you mess with your laptop. plug into tv, transister radio or iPod or whatever. Once you have verified, make sure it is plugged into the right port. Usually the headphones port is the one you want. To verify port, use headphones. If still not working, click on the speaker icon in the windows tray on the status line, click mixer, verify speakers is not muted or turned down.
Jun 13, 2011 | Computers & Internet
Windows 7 cant hear 5.1 surround sound through laptop audio jack
Are you sure that the soundcard supports 5.1 on your laptop?
Dec 13, 2009 | Computers & Internet
My computer's sound doesn't auto switch from hdphn to spkrs.
Two possible causes one is the headphone jack and the other a driver issue.
The headphone jack has a metal leg that is pushed out of the way when you insert the plug. It then switches from speakers to the jack. That's how it is supposed to work. The third leg can get dirty or bent or loose and not switch correctly. If it is dirty you can sometimes clean it just by inserting it and pulling it out a "few" times. If it is mechanical ie loose then it needs to be replaced which means replacing the main motherboard. You can check for warranty but from experience it might just be one of those things to get used to instead of trying to get them to replace a main board.
If it is a driver all you can do is hope they update the drivers. You can check the drivers versions and release dates on the Toshiba website. Just go to www.toshiba.com then support then laptop and then find your model. Drivers and sort by your operating system. Unfortunately Toshiba seems to have a history of unresolved sound card driver issues.
Nov 04, 2009 | Toshiba Satellite A135-S4527 Notebook
No sound from external speakers with toshiba dynadock
if using XP, go to start control panel , sound and audio devices.Under the audio tab make sure the C Media CM106 sound device is selected under sound playback. Then under the volume tab set the volume somewhere in the middle or at the top if you don;t have active speakers . Then Under Speaker settings advanced, make sure the speaker setup is set to Laptop Stereo speakers. Also make sure the speaker volumes are up on the speaker volume button. click ok. If no result check that the cm106 sound decvice was cemented in as I saw it dissaper when I thought i had slected it. I think the key thing here is the device and the laptop speakers setting.
Aug 26, 2009 | Toshiba Dynadock Port Replicator, Docking...
Laptop audio issues
Right click on the white speaker icon,by the clock ,Select Playback devices,when the sound box opens,select the play back tab,double click on speakers,click the enhancements tab,select disable all sound effects,click on the advance tab,select 24 bit 48000 Hz (studio quality) click test,if you hear sound,click apply and close the open boxes.Now double click on the red speaker by the clock,plug in the headphones,check the box at the bottom that says headphone virtualization,click ok.that should do it.
Please rate this solution
Jan 17, 2009 | Dell Inspiron 1420 Laptop
Why our head phones on Computer are not working
Is there a switch to turn on the headphone port? Is there a control on the headphones to adjust the volume (on a volume level on the side of the laptop)? Also, when the headphones are plugged into the laptop, go into your sound settings and turn up the master volume (and wave volume if it is low.. If that works, make sure to turn it back down when disconnecting the headphones).
Also, do the headphones work in another device (stereo, etc..)?
Mar 26, 2008 | Toshiba Satellite P105-S6104 Notebook
Toshiba satellite laptop
Before going to any shops, here is a suggestion that can't hurt anything.
Go to the Control Panel and click on Sounds and Audio Devices. On the Volume tab at the bottom, you will see "Speaker Settings". Click on the Advanced button. Change that setting to "Stereo headphones". You should hear the sound only through the headphones then.
Feb 14, 2008 | Toshiba Satellite A105 Notebook
Toshiba Equium Laptop m50-164
Hi, Alex,
I think you may have deleted your audio file driver on your laptop the only way to get your sound back is to re-install your audio driver for your laptop as the sound card on your laptop is ok you can find sound card drivers on the internet if you don`t have the drivers for your sound card
Jan 08, 2008 | Audio Players & Recorders
Sound for toshiba laptop
headphone jack maybe damaged from wrong insertion of some material,, try to insert headphone very slowly until sound will transfer to headphone..
Dec 29, 2007 | Toshiba Satellite A135 Notebook
Computers & Internet Logo
145 people viewed this question
Top Toshiba Computers & Internet Experts
pankaj rautela
pankaj rautela
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
