Question about Jensen VM9510 Car DVD Player
Have no sound when the cd and dvd is played
I have a uv8 phase linear i have sound when my radio is played but when i play my dvd or cd i have no sound .. can anybody help
  • powerboat Nov 02, 2008
    i have UVA PHASER LINEAR when i try to play dvd i have sound but no pic. and i have the pink wire grounded and i still have the blue warning screen that pops up...heres the funny thing before i was getting a pic but no sound when a played a dvd or a cd . i took someones ..advice that my instock amp wire needs to be switched .. so i did and it worked i have sound cd and dvd but know no pic... if someone can solve this promblem ..u damm good lol lol
  • 3 Answers
You have a factory amp in your vehicle so what you need to do is take out the uv8 and make sure the remote wire from the unit " blue and whit stripe " is connected to the remote wire of the car harness.
the way you have it now is the power antenna wire " solid blue " the is connected to the remote wire of the unit
Posted on Oct 31, 2008
Jensen uv8 sub works with radio an dvd but not with cd
quiero instalar mi dvd car radio y violar el codigo de parqueo se que hay opciones para poder estar el vehiculo rodando y poder verse el dvd gracias
May 19, 2009 | Jensen VM9510 Car DVD Player
Phase linear uv8= parental control problem
Is setup for default read the manual to get the password.
Mar 25, 2009 | Car Audio & Video
Unlock region code on my Phase Linear UV8
I had the same problem and I was able to fix it myself. call me and I can help you over the phone 951-334-2297 ask for George.
Feb 14, 2009 | Audiovox UV8020
No cd audio from my phase linear uv8
It sounds like you have a factory amp in the vehicle. Check behind the radio to see if you have the blue wire from the deck hooked up to anything. You probably do. So take the blue with white stripe wire coming from the deck and hook that up instead of the solid blue wire.
Jan 20, 2009 | Phase Linear UDV9010 Car DVD Player
The UV8 needs to use The Pink wiere to play an CD audio?
I got through to tech support. For problem of no audio from DVD or CD (can only hear radio), reverse the Blue wire (power antenna) and the Blue/White wire (external power amplifier). This should solve the problem.
Nov 26, 2008 | Jensen VM9510 Car DVD Player
My phase linear uv8
The Laser Diode inside the UV8 that reads the DVD media is most likely set too weak for the amount of dust built up in over time. This dust block the laser optics and causes the player to not read DVD's. You will want to go get a bottle of air from Radio shack and blow the DVD player out. The reason it is reading CD's is that its laser diode may be set stronger and is able to break through the dust. There are two Laser Diodes, one for CD, and one for DVD. Good luck.
Sep 04, 2008 | Jensen VM9510 Car DVD Player
Phase linear uv8020
To change the region code on the UV8 you must have a dvd playing and 1. with the remote press setup 2. then enter 5, 4, 3, 2, 1. This gives you access to firmware menu. 3. arrow down to tools "system settings" (you should be able to use the touchscreen) enter on region a menu opens and select "0" to make it region free. You can also go down to the brake bypass menu here to to put in "off" mode so you can see movies while driving.
Sep 03, 2008 | Phase Linear UDV9010 Car DVD Player
Uv8 problem!!!! please help
Ipod controls usually go to the cd changer input or auxiliary input. They might have just updated the the looks but usually the inside is the same, especially if they have the same model number. By the way you can get that ipod cable really cheap on ebay.
May 21, 2008 | Jensen VM9510 Car DVD Player
Phase Linear UV8
go to setup hit 543210 but hold 0 then turn the bake override on and then hit the X
Dec 11, 2007 | Jensen VM9510 Car DVD Player
Jensen VM9510 Car DVD Player Logo
206 people viewed this question
Top Jensen Car Audio & Video Experts
xxxxxx xxx
Are you a Jensen Car Audio and Video Expert? Answer questions, earn points and help others
