Question about Legacy Audio LA770 Car Audio Amplifier
Legacy 1200 watts
I have a legacy amp installed and it keeps going into safe mode while im driving along....but when the car is parked the amp works fine,can someone help me find the problem ??
  • taff hussain Sep 09, 2006
    i have 2 amps in the car 1 amp powers my rear speakers and the other 1 powers my sub they are all powerd by the same live wire the 1 for the rear speaker stayes on ,but the 1 for the sub goes to safe mode... then i switch the stereo off and then on and it works for a bit then goes to safe mode again....
    Scholar:
  • 72 Answers
I agree with Techman, But when I was 16 I had a system with the same problem. Car not running the system ran perfectly start the car and it would drop off. Took it apart three different times even added an air induction cowl to keep amplifier cooler. did not change anything. What I did not take into consideration was when the car is on the voltage is used to power lights, coils, computers, and all the other things needed to make the car go and I was using a long run of light gauge wire. When a downbeat would come the voltage to the amp would drop down, and the amp would sense it as a problem sent the amp into protect for a second and back on it would come again. Better wire, Better amplifier, and five alternators later. Do not know if this is your case but it just reminded me of that.
Posted on Sep 09, 2006
    President:
  • 3,130 Answers
First thing to look for would be pinched speaker wires,or a bad ground, or a loose b+ wire. The next would be to have the amp bench tested and the tech should bang and tap on the unit to see if there are bad or cold solder connections inside on the printed circuit board assy.
Posted on Sep 08, 2006
SOURCE:
Will the amp blow my speakers?
If you bridge the amp and get 1000 watts RMS and that is split going to two speakers then you will get 500 watts RMS at each speaker. If you have your amplifier on maximum gain it may blow your speakers, not because they are overpowered but because you might run into "clipping" issues running the amp at maximum capacity. Just to be safe I would dial the amp's gain down to 3/4 of the way to full gain. That should give you ample power and keep your amp from clipping and running hot.
Aug 11, 2015 | MTX Car Audio & Video
What size fuses do i use for legacy la1095?
if it really uses 1200 watts, that would call for a 140 amp fuse, which is outrageous. for that power, if turly approachable, you would need a v8 engine, and midified alternator(s) arrays, and a capacitor.
Aug 01, 2014 | Legacy Car Audio & Video
I HAVE A 1200 Watt Legacy Rebel amp and when I power it on the lights turn on but no sound comes out. Please give any help
You need to make sure that the subwoofer leads are connected correctly. It may be that the subs aren't connected properly. That would cause the amp to turn on without any sound coming out.
Mar 06, 2011 | Legacy LA2259 Car Audio Amplifier
XM-2002GTW Car Amp: i have 2 dual 2-ohms solobaric speakers and im try...
I researched your amp and it looks like its not even 2 ohm stable :( the problem with these companies is they lable there amps 1200 watts MAX, that means they tested the amp in a perfect enviroment and the amp fried somewhere in the ball park of 1200 watts, your best bet is to save your money and buy a nicer amp that is two or one ohm stable... that being said the best way to wire your subs is in series
May 17, 2010 | Sony XM-2002GTW Car Amp
Is my 1200 pioneer amp a good match for my 1200 watt pioneer sub
this is too close, your speaker wattage is alway's higher than your amplifier's wattage alway's to be safe because the hard pounding will make the speaker work harder, and this will cause your speaker burn out easily, though you can adjust your amplifier anyway's
May 08, 2010 | Pioneer TS-W307D2 12" 1200 Watt Champion...
LA-1030 Protect Mode
you have an unloaded channel,so the voltage is exceeding what the protect circuit is supposed to see.you have to connect an 8 ohm resistor across the output of the unused channel.
do not drive a signal into it or you will smoke the resistor.
a 10 watt will do ok with zero signal input
May 23, 2009 | Legacy Audio LA1030 Car Audio Amplifier
Mmat amp 1200 watt
If the amp is in protect mode, it probably has shorted output transistors.
What model amp is it?
Aug 20, 2008 | Car Audio & Video
Problem with LEGACY BLUE DIAMOND AMPLIFIERS LA1080
never attemp to bridge your amps specially this type of amps. this are too very complicated. you may blow your amp if you will attempt it again.
Jan 22, 2008 | Legacy BLUE 4 X 250W CAR AMP Car Audio...
Legacy amp 1200 watts
i have had the exact same problem with the exact same lagacy amp that you have posted, put your ground in a different spot or try double grounds in two different spots this should solve your problem here. good luck
Oct 06, 2006 | Legacy Audio LA770 Car Audio Amplifier
Legacy Audio LA770 Car Audio Amplifier Logo
140 people viewed this question
Top Legacy Audio Car Audio & Video Experts
Dalynn Turner
Mark Skinner
Richard Lukszys
Richard Lukszys
Are you a Legacy Audio Car Audio and Video Expert? Answer questions, earn points and help others
