Question about HP PSC 1315 All-In-One InkJet Printer
Hp laserjet 3380
Hot to clean the inside part of the glass. Every time I print I'm getting two wide black masrks in my documents
thanks
emilio
  • Frank
    Frank May 11, 2010
    did the black mask appear printing from copy or just printing??
  • 322 Answers
The problem is not your scanner, is in the rollers, the rollers are smudged with ink or other mateial or your glass is smudge, remove the four star bolts on the top and clean the undersurface of the glas with a conventional glass cleaner wipe and re install the top cover.Be careful with the ribbon cables connected to the circuit board.
Posted on Nov 25, 2008
When using our HP 6500A plus printer/copier we are getting a black line on our documents.
open the scanner door like you were going to pull out a stuck document, look inside there and you'll see a strip of glass either on top or on bottom or both. this glass needs to be absolutely clean, even a speck of dirt turns into a full line on prints or scans... please mark fixya if this helps...Click here
Jul 14, 2011 | HP LaserJet 3050 All-In-One Printer
HP Laserjet M1319fMFP Copies have a line down the
if it only happens when COPYING AND NOT PRINTING there is a long thin glass that "reads" your originals inside the document feeder. It probably has whiteout on it. clean it with your fingernail. this glass is about 10 inches left to right and 3/4 inch long. Your manual should point this glass out to you.
Dec 14, 2010 | HP Laserjet M1319F Laser Multifunction...
I cannot print more than 1 copy of a document in Windows 7 (Office Word) using my HP LaserJet 3380 -- also, it won't let me select which pages in a document to print; I have to print the whole document, no...
according to the issue you should be using the plug and play driver that comes in win 7, the advice that i can give you it's to download that universal print driver for the printer go to this link to download it.
http://h20000.www2.hp.com/bizsupport/TechSupport/SoftwareDescription.jsp?lang=en&cc=US&swItem=ja-45284-14&prodTypeId=18972&prodSeriesId=378060
this driver is for win vista but it works for win 7, give it a try and let me know!
Jul 29, 2010 | HP LaserJet 3380 All-In-One Printer
How can I change the baud rate on my HP Laserjet 3380?
There is no baud rate to this printer, it's either parallel cable or USB cable. Baud rate refers to the old serial cable connections, com1 or com2. You can add memory to this printer to make it print more documents faster. Try this location:
http://reviews.cnet.com/multifunction-devices/hp-laserjet-3380-all/4505-3181_7-30822993.html
May 11, 2010 | HP LaserJet 3380 All-In-One Printer
HP Laserjet 3380 line the length of the paper.
Lift up the document feeder and clean the small scanner glass.
Mar 10, 2009 | HP LaserJet 3380 All-In-One Printer
HP 3055 printing black lines when using collate feature to copy
All you need to do is to clean the small wide glass (that at the LEFT of the main flat big class). The Auto Document Feeder (ADF) specifically uses this glass to scan for copy (and fax). When it is dirty (such as small dirt or particles on the surface which is easy to gain in long run), it will create thin vertical line(s) as the result.
Jan 28, 2009 | HP LaserJet 3055 All-In-One Printer
New problem with hp 3380
hiii...
change the fixing unit....film inside fuser.....
Sep 15, 2008 | HP LaserJet 3380 All-In-One Printer
Scanner Error - Power On > Power Off
Sounds like the scanner has died. Sometimes restarting can help out. If you can print try printing out the configuration page and let us know what the error codes are.
May 27, 2008 | HP LaserJet 3380 All-In-One Printer
HP PSC 1315 All-In-One InkJet Printer Logo
79 people viewed this question
Ben Johnson
mukhtar21 shaikh
mukhtar21 shaikh
