Question about Microsoft Xbox 360 Console
X-box live When I try and connect it wont let me, and when i check it, it says my IP address is wrong, and wont connect.
  • sammyd115 Oct 29, 2008
    settings on the x-box or modem? not sure.
Have you gone to settings and checked your IP compared to your modem?
Sorry, it's not much. I don't specialize in this aspect of the 360
Posted on Oct 29, 2008
  • Anonymous Nov 01, 2008
    On the xbox, if you go to the settings tab on the dashboard, there will be an option somewhere for Xbox Live/Connection. Make sure all of those settings are equal to those of the modem or router that you're trying to connect off of. IP Address, DNS, etc.
XBOX WONT LET ME SIGN ON LIVE,SAYS IT CANT OBTAIN IP ADDRESS FROM ROUTER
go on your pc / mac search for your ip address on your pc.... your going to have to manual imput it .. otherwise your wep to your connection is wrong...
Sep 26, 2011 | Microsoft Xbox 360 Elite Console - Black
My laptop wont connect to hub when wireless, says ip address wrong
Try manually locating ip address to your laptop Right click on the local area connection icon and then click on Status, click on the properties this will help you to be able to Change the Local Area Connection Properties, Click on the Internet Protocol(TCP/IP) Click the properties button under then click on use this IP address provide the required IP address, Subnet mask and Default gateway and also click on use this DNS server address and then fill the field as necessary after try repairing the Local Area Connection.
Mar 18, 2011 | Computers & Internet
I have wirerless internet and my xbox wont connect why
Here is xbox support:
http://support.xbox.com/en-us/pages/xbox-live/how-to/default.aspx
For Linksys routers:
Hooking up an Xbox with Linksys routers:
Open an Internet Explorer browser page.In the address bar type - 192.168.1.1
Leave username blank & in password use admin in lower case...
Click on "Applications and Gaming" tab and then click on "Port Range Forwarding" subtab...
1) On the first line in Application box type in ABC, in the start box type in 88 and End box type in 88, leave the protocol as both and under ip address type in 192.168.1.20 and check the enable box...
2) On the second line in Application box type in PQR, in the start box type in 3074 and End box type in 3074, leave the protocol as both and under ip address type in 192.168.1.20 and check the enable box...
3) On the third line in Application box type in XYZ, in the start box type in 53 and End box type in 53, leave the protocol as both and under ip address type in 192.168.1.20 and check the enable box and click on Save Settings...
3) Once you return to the set up page click on the Security tab and uncheck Block Anonymous Internet Requests and click on Save Settings...
4) Click on set-up and change the MTU Size to 1452 and click Save Settings...
5) Goto the XBox Network Settings and IP Address Settings and select manual IP Settings and assign the following on your Xbox
IP Address :- 192.168.1.20, Subnet Mask :- 255.255.255.0, Default Gateway :- 192.168.1.1...
6) Also assign the DNS Addresses on the Xbox
Primary dns :- 4.2.2.2...Secondary dns :- 192.168.1.1
7) Turn off your modem, router, and Xbox...Wait for a minute...
8) Plug the modem power first, wait for another minute and plug the router power cable, wait another minute and turn on the Xbox and test it...it will connect...
Dec 02, 2010 | Computers & Internet
Can't connect to xbox live
Restart your modem or router. Give it a little while and try again. If it still does not work try the tips that x-box live recommends.
May 29, 2009 | Microsoft Xbox 360 Console
I cant get an IP adress what i it it says faild
If the X-Box is trying to connect wirelessly to your network, you might need to access the router page and check the wireless settings and make sure that you have the correct encryption or network key, Check the MAC address filtering of the router and make sure that it is disabled or it is off, If you are using a D-link router it is under the Advance tab, Network filter, on the other routers mostly they are under security options, Now after checking those on your router follow the following steps
- Go to the X-Box Dashboard
- Go to Network settings
- If the X-Box is wireless you should have on option for wireless at the bottom of the page
- Select your wireless network and test the X-Box Live
- If it is a wired connections
- Test X-Box Live It should now all connect and confirm the IP, DNS, ICMP
- NAT may show as strict but it should be able to connect to X-Box Live
- If you want to Set the NAT to Open
- Check the IP address of the X-Box by going to Network settings then Edit settings
- Then go to the computer again
- Access the router page
- Go to port forwarding normally located under an advance tab
- Open the ports UDP 88, UDP 3074, and TCP 3074 (here's one example, http://www.portforward.com/english/routers/port_forwarding/Dlink/DIR-655/Xbox_Live_360.htm)
- The IP address field must be filled with the IP address you got from the X-Box
Hopefully this solve's your problem sir
brakke_usaf..Good Luck and Merry Christmas to you and your family..
Dec 25, 2008 | Microsoft Xbox 360 Elite Console
What is a ip address
Literally,
IP address an Internet Protocol (IP) address is a numerical identification (logical address) that is assigned to devices participating in a computer network utilizing the Internet Protocol for communication between its nodes.
If it is about your X-Box,
It is the IP address that is assigned to it from your router or from your modem, depending on where it was connected.
This is determine whether the X-Box is connected to the Internet or not.
To see where the IP address of your X-Box, here's an example,
http://chasms.com/xbox/xbox360cfg.htm
Hope this helps sir willie764.
Dec 23, 2008 | Microsoft Xbox 360 Elite Console
WRONG IP ADDRESS
download the for the exact type of router you have and check also the manual of setting there should be descrive all configuration you need to set.
Dec 10, 2008 | Computers & Internet
IP address
Try this fix:
http://xbox360help.blogspot.com/2007/04/ip-failed-xbox-360-live-test.html
Apr 13, 2008 | Microsoft Xbox 360 Console
Wrong ip address
Are you trying to get an IP for your computer, or for your modem? Assuming your using a high-speed connection, possibly a router?
Mar 28, 2008 | Computers & Internet
Microsoft Xbox 360 Console Logo
19 people viewed this question
Top Microsoft Video Game Consoles & Games Experts
Tre Elkins
Martin Murray
Stu Morris K
Are you a Microsoft Video Game Console and Game Expert? Answer questions, earn points and help others
