Question about Saeco VIA Veneto Espresso & Coffee Maker
Soggy Pucks & Portafilter retains water Saeco Via Veneto
I own a Saeco Via Veneto I have owned it for a little over five months Lately, my espresso tastes lifeless. I have my espresso preground because I do not have a conical burr grinder. I store my espresso in a cool dark place, if I have it for than a week and a half I store it in the refrigerator. I have spoken with many Saeco reps, and Cafe West dist. reps, but none of them can pinpoint the problem. They claim that it may be the grind, or that the machine needs to be descaled. I doubt it is the grind because the grind I use has not changed and the espresso pucks used to come out tight and dry. I did descale the machine, but this has not helped. If it is not the grind, machine, or portafilter what is left? I would really appreciate any input becaue the machine is about to be out of warranty Thanks for any advice that is given
    New Friend:
  • 4 Answers
It sounds like you are short on water due to a blockage somewhere...either in the flowmeter or the group head. You might also have a faulty pump, and you're not getting enough pressure during the shot. If you're not getting crema, then it's most likely pressure related...shots will also have a burnt smell and very bitter taste.
Posted on Mar 14, 2017
4 Suggested Answers
SOURCE:
EsWorld
  • 1618 Answers
SOURCE: Replacing orange gasket in top or portafilter
here is a picf920683.png of the portafilter for the saeco
Posted on May 14, 2009
  • 3 Answers
SOURCE: Need portafilter plastic support peg
This merchant carries Saeco/Gaggia parts. You may have to get the disc and peg as a set. Part number/description is: "GG1038/01/A Crema disc for portafilter. Use with 2-cup basket"
Merchant site is here:
http://www.saecoparts.com/StarbucksSirenaespresso.html
The item is on the 3d row, 4th column
Posted on Nov 26, 2009
  • 1089 Answers
SOURCE: No water coming through portafilter to make espresso.
You have a stuck check valve. Try running the pump with the steam knob open, then shutting it then, opening it 4 or 5 times and see if it will pop open. Make sure that you don't have the portafilter in at the time you are doing this.
Posted on Dec 03, 2009
Frothing works perfect....water is extracted just fine. BUT when I put coffee in the basket and tamp it down and put it in the machine it just makes noise like it is about to drip and nothing comes out,...
I have a brand new Via that never worked right out of the box. Could barely get any espresso to come through the portafilter. Got a new portafilter and the espresso now flies out of the machine beautifully. Seems they are shipping2_bing.gif units with faulty portafilter. Bad news is a new portafilter is like $65. See if you can get them to give you a new one. I had the same issue as you, very little espessso comes out.
Dec 29, 2009 | Saeco VIA Venezia
Coffee does not flow into shot glasses. water and coffe grounds seap and sprew from around the top ad down the sides
I had a brand new Via Venezia that I could barely get to make espesso, nothing or very little came out. Got a new portafilter and now it work beautifully, espesso flies out of the thing wonderfully. Bad news is a new portafilter is like $65. I can't believe they are shipping these with bad portafilters, but they are.
Dec 26, 2009 | Saeco VIA Venezia
Broken portafilter!
Dec 18, 2009 | Saeco VIA Venezia
Dec 03, 2009 | Saeco VIA Venezia
Coffee not pouring through portafilter
if your grounds are tamped down too tight, the steam can't get through it.
Dec 30, 2008 | Saeco VIA Venezia
Via Veneto will not prime
Yes, unfortunately the Via Veneto is a difficult machine to prime, however, I have a simple way to prime the pump if you run into this problem. Simply remove the water tank, fill a clean turkey baster with water, open the steam valve fully then mate the baster tip with the water tank flow valve on the espresso machine. Wrap a towel or paper towel around the flow valve/baster tip then inject the water (agressively, but not forcefully). It's works for me every time.
Sep 18, 2008 | Saeco VIA Veneto Espresso & Coffee Maker
Via veneto won't make coffee
I removed the top filter where the water comes out and cleaned it good with a pin for all the holes, then I did the same for the coffee filter. I found alot of the holes plugged which would avoid the from alowing the coffee to come out.
Now it works like new.
May 24, 2008 | Saeco Magic Cappuccino Espresso&Cappuccino...
EXPLODING SAECO VIA VENETO
I think your machine is overheated, try to replace the thermostat on the boiler.
May 25, 2007 | Saeco VIA Veneto Espresso & Coffee Maker
Saeco VIA Veneto Espresso & Coffee Maker Logo
555 people viewed this question
Top Saeco Coffee Makers & Espresso Machines Experts
Pierre Laplante
Ray Murphy
eyecam
Are you a Saeco Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
