Question about Whirlpool 25.6 cu. ft. Side-by-Side Refrigerator with In-Door-Ice Dispensing System
How to get the icemaker overlay off the freezer door on modeled25rf
Trying to getthe trim off around the icemaker water dispencer it ha rust coming out under the bottom of the trim
  • 59 Answers
Slip a puddy knife or flat screw driver under the bottom edge and then twist and pull the trim out until it snaps free. There are two slots on the bottom that will easily accept a screw driver.
Posted on Nov 02, 2008
Icemaker making ice
If icemaker is in good order, it will then depend on how cold the freezer compartment is and how available the dispenced water is. The ice maker draws the temp. from the freezer to allow activation.Size of ice depends on level of water in ice trays.
Jun 04, 2010 | Samsung 26.1 Cu. Ft. Side-by-Side...
No water to icemaker.......fridadaire frs26zth....... i have no water to icemaker but a good flow at the door dispenser... i tried a hair dryer around icemaker in case of a frozen line...also jiggled metal...
if you are getting pressure at the dispencer are and the fill tube is not frozen then it can only be the water valve replace it and that should fix it but be sure that the fill tube is not frozen first
May 30, 2010 | Refrigerators
How to defrost the water line coming into the icemaker? The water line that goes from the fridge to the freezer is frozen and the icemaker does not have water to make ice and the water dispencer does not...
Good day,
The machine has problems and they hve to be addressed.
The machine needs to be shut off, and the food moved.
I do not recommend using a hair dryer since it can melt things you never want to melt.(Those components are plastic and vinyl).
The DUAL WATER VALVE in the bottom back of the machine, needs replaced at the same time, since it's the cause of your problems.
As well, the line to the water outlet could be frozen, which means defrosting the freezer door completely.
Looking at a 12 hour minimum off time, with the machine unplugged.
Using a floor fan blowing into the freezer compartment will reduce that time to approx. 8 hours.
Dec 29, 2009 | Kenmore 57029 Side by Side Refrigerator
Icemaker is not working, but water dispencer is OK Model Kenmore Elite 106.45422800
Hi...
Try to check this
Good luck !!
Regards
PCmania
Jul 08, 2009 | Kenmore Refrigerators
Icemaker
Do you hear it trying to draw water into the ice tray? If so, there might be an internal problem you can't fix yourself. especially since the fridge is dispencing water. Is the arm inside the ice maker pushe down? This is what tells the ice maker to fill and make the ice.
Let me know if this helps.
Jan 02, 2009 | Frigidaire FRS266ZDSB Side by Side...
Ice maker
I have kenmore two door fridge. My icemaker is not working but the water dispenser is. Model#DU800DWGQ1 Serial#FJ1814737
May 14, 2008 | Refrigerators
Kenmore Coldspot w/Ice Maker Not Making Ice
hi LOP7,
In most cases you can easily solve this problem.
step one would be to make sure your freezer is getting cold enough. If you have icecream in your freezer is it frozen solid or is it soft. Most icemakers cycle around 0 degrees and if your freezer is not getting to 0 then it will not cycle and it will not make ice.
Step two would be to make sure you icemake is cycling. To do this simply lift the little shut off arm on your icemaker and wait about an hour then go back to the icemaker and drop the arm down. The icemaker should start going through a cycle. You should notice the arm slowly begin to raise and the ice dispencer fingers will begin to turn. Then you will hear it call for water. You may hear a humm.
If the freezer is cold enough and the icemaker is cycling that only leaves the inlet valve. replace the valve and enjoy the ice.
If the freezer is cold enought and the icemaker does not cycle, then you have a bad icemaker. Simply replace the icemaker and viola.
Third if the freezer is not cold enought 0 defrees. Then you may have a defrost problem. In this case post more info and I will be happy to help. Good luck mca0824@aol.com
Apr 30, 2008 | Kenmore 18.3 cu. ft. Top Freezer...
Icemaker and water dispenser not working GE GSS25JFPA stopped working and i thought it was water filters (have not changed in 4 years changed the internal filter and a aux one in basement in line no...
generic troubleshooting video: http://gei.portals.streamos.com/cc/channel.php?emcid=1416&empid=4533&packageid=0000
as the video shows a kinked line may be the culprit. or
if your ice maker is making ice and it is your ice dispencer that is not working along with your water dispencer and when you press the dispencer button the light dims on the door. I would replace the main board. I experienced the same problem and the board fixed it This board is shared by many models and brands of fridges and the transformer goes bad from power surges this board powers the solenoid valves that open for your water
Apr 03, 2008 | Refrigerators
Maytag MFD2561HES
Texas, sounds like your water reservoir is frozen up. Remove your 2 cripser drawers, you will see the reservoir behind them. Take a hair dryer and go over the tank and tubing ends. See if the water starts flowing. I find a lot of frozen water reservoirs on these french door models. They have a insulation kit for them. Catriver.
Sep 29, 2007 | Maytag MFD2561HE Stainless Steel Bottom...
Whirlpool 25.6 cu. ft. Side-by-Side Refrigerator with In-Door-Ice Dispensing System Logo
114 people viewed this question
Top Whirlpool Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Dan Webster
Dan Webster
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
