Question about LG Computers & Internet
Monitor shuts off during boot. Let the machine boot full up, hit the power button, the monitor flashes windows for a split second, and goes back to power saving mode
My monitor just went to power saving mode right after I was playing CoD4. I've got an older monitor hooked up just to keep going, but, I was needing to know if this monitor is trashed, or, if there's something else I can do to fix it. It's a LG Flatron L1932TQ-BF. I'm running an BFG 8800 GT OC and have tried both analog and digital. Once the machine is up and running, I can click on the power button and windows will flash for a split second, and then it will go back to power saving mode. Any suggestions?
  • 1 more comment
  • celius Oct 29, 2008
    I take back what I stated about the power saving mode. It will start to boot, monitor will come up showing the boot sequence, and then go blank. It stays powered on (blue light), and will flash windows when I turn it off and right back on. I've tried two different machines, both with the same outcome.
  • celius Oct 30, 2008
    No luck...Refresh rate is set at 60 and the others are hidden. I had been running the same setup for more than a year. It just died out on me after a game of Crysis. Power light is still on, but if I turn it off and back on real quick, the screen will pop up w/ windows for about 1 sec and then go black again. Has me stumped...
    I'll give it a shot after work this afternoon. Hopefully that's the case. I've got it hooked to my son's machine right now and am having the same prob, but I'll try to go into Safe Mode and see if I can get into it or not. I'll let you know how it turns out. Thanks again!!
  • 1,498 Answers
Hey there Celius,
Chances are the 'Refresh Rate' somehow got set too high for the monitor. On flatscreens , the result is a black screen.
If you have an old monitor (crt type) hook that up temporarily and reboot.
  • Right Click the Desktop
  • Click Properties
  • Click Settings
  • Click Advanced
  • Click Monitor
  • Lower the refresh rate or set at optimal
  • Check the box 'Hide refresh rates this monitor can't display'
Shutdown, Switch back monitors and try it now.
Good luck
Mike
Posted on Oct 30, 2008
  • Justin Case
    Justin Case Oct 30, 2008
    You're right about this being a stumper.
    How about trying to boot in safe mode (hit F5 or F8 during startup). If the monitor stays running at least we know it's not the monitor.
    Mike
  • Justin Case
    You've already tried it on a different machine? Same results?
    Try the Safe Mode thing anyway. You never know what you're going to find out out on the weird ones.
    Mike
AOC 2036S won't connect to laptop
Is the cable working? try reducing your laptop screen resolution and connect to your monitor. Your monitor may not support full hd resolutions....
Jan 09, 2014 | AOC 2036S 20 INCH BLK LCD MONITOR
Monitor will not stay powered up
It is possible that the monitor is going back into "Sleep mode" meaning it is not detecting a valid signal from whatever device it is plugged into. I would try replacing the cable that is connecting the monitor to the PC or Console. As a trouble shooting step try pulling up the "Menu" on the monitor itself by pressing the "Menu" button on the front panel of the monitor, if this does come up then we can say that the LCD itself is most likely working.
Nov 10, 2012 | HP Compaq WF1907 19 LCD Monitor
Dell E172FPb monitor black screen green flashing power button
We have a dis-assebly and repair guide posted on our web site at:
www.ccl-la.com/monitor_repair.htm
The problem is usually the driver transistors, our guide shows where they are and what to replace to get your monitor back running again.
I hope this helps, If so please rate my solution.
Buddy
Corporate Computer
www.ccl-la.com
Jul 30, 2009 | Dell E152FP 15" Flat Panel LCD Monitor
Blank Screen & flashing button
It is one of three things, One is that it's not recieving a signal, mine flash when the computer is shut down, several monitors do this now. The second is that the either the video card is in need of service, or if you don't have a video card in your machine, it is either a connection that is intermittent, check the other end of the cable, or the monitor is in need of service, there is a circuit board that gives it a boost on start up. How old is the monitor and what brand? all the info is needed to go any further, thanks, if it is 5 years old more or less it is the monitor gone bad, more than likely
Apr 09, 2009 | Dell E172FP 17" LCD Flat Panel Monitor
T6420 E-Machine won't/Reboot W/O F8 Key
No sync means no video signal to the monitor. The rest sounds like a corrupted OS. This could be from a number of reasons, including a virus. If you have NORTON or MacAfee, Your open to a lot of attacks. Get AVG free, and use Mozilla instead of IE.
The reason the fans come on full speed is the MB senses a high temp on the CPU, until the bios fan control takes over after POST. This is normal on most systems.
Aug 22, 2008 | E-Machines eMachines Desktop PC
Is this a Software/Config/Hardware Problem ?
hmmm..sounds like a sleep or screen saver conflict...try booting up on Safe mode(F8) on turn on, and then see how that works. Set your screen saver for Never, and see what happens.
You may be hitting a thermal issue with your video circuitry.
Feb 18, 2008 | Dell Dimension 4600 PC Desktop
Monitor flashes on and off!
Sounds like you have a bad connection from your monitor to your computer. First check and make sure the connection between them is tight. Does your computer boot up and run though? If your computer is not booting up the monitor will default back to the flashing green power light
Nov 29, 2007 | Dell E173FP 17" LCD Monitor
Black screen
How old is the computer? Make sure that the power light comes onto the monitor when you plug it in, should be orange and then turn green when video card syncs with it when PC is turned on. If you are getting black screen when PC is powered on:
1. Bad video card
2. Bad video cable
3. Bad monitor
1Solution: Try using a different monitor attached to this same PC and see if it works. If it does, then its the monitor, its cable, or its power supply. If it doesn't work, then its the video card or the video cable coming from monitor.
Nov 24, 2007 | Daewoo L700C 17" Flat Panel LCD Monitor
Monitor flashes image for split second then goes blank but green LED flashes as well
while the monitor is still powered on, but with the LED flashing, unplug the monitor from the PC. press the power button, and the monitor should go off, now plug the pc back into the monitor. Turn the monitor back on and it should work.
Occasionally this will not work for me, but if I repeat it it normally works
Hope this helps - my problem is intermitant so it may be different to what u guys have
May 02, 2007 | ViewSonic VX924 19" LCD Monitor
Screen turns black
problem with the inverter chek it
Mar 18, 2007 | Daewoo L700C 17" Flat Panel LCD Monitor
Computers & Internet Logo
790 people viewed this question
Top LG Computers & Internet Experts
Alun Cox
Are you a LG Computer and Internet Expert? Answer questions, earn points and help others
