Question about Sony KP-53HS30 53" Rear Projection HDTV-Ready Television
About the sony tv
Hey i'm trying to get in to the service menu cuz i want to tweak the colors and fix the image cuz i think it's a little off center....can i do that on the service menu?
What else you recomend?
thank you.
  • Sony Master
  • 586 Answers
If you have use this menu earlier and have some knowledge then you can, But if you don't know much about it then i will not suggest you to do this because if some other thing changes its data then you have to face other problems along with previous one's too.So, this is the better way to contact any expert nearby to you.
Hope you will understand my saying.
Thanks.
Posted on Oct 30, 2008
Hey eel the picture on the tv is like a three d image and can't seem to fix the problem and well I think that it is to do with the projecting please help? But I've done all I can.
It sounds like it is probably a convergence problem. Is the second image a different color? Did it go out suddenly? If so you'll want to take it in for repairs because a component has croaked on you. This will require replacing parts and going through a tedious adjustment. If it is only slightly out there should be an adjustment in your menu. Good luck.
Apr 24, 2011 | JVC AV-56WP74 56" Rear Projection...
Double image and 3d color
Projection TV sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the video to look normal. When its out of alignment the video will look 3D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the TV menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired.
This is a very common failure on these projection sets and a fairly simple DIY fix. All projection sets including Samsung, RCA, Sony, Philip Magnavox, Panasonic, Pioneer, Akai, GE, JVC, Toshiba, and others at some point will have the same problem.
Common Symptoms include....
  • Screen looks 3D
  • Colors don't line up
  • One or more colors can't be adjusted when using the convergence menu.
  • Screen is bowed or warped.
  • TV shuts off after powering on. Power light will blink. TV may also make a chirping noise.
Here are some photos of convergence problems.
Here is a quick test....
Using your original remote go-to the settings menu then goto the convergence section.
Try to adjust the red and then the blue convergence.
You should be able to move RED and BLUE in all directions - up, down, left, and right. And you should be able to get the grid straight.
If you can't move them in all directions or cant move them far enough your convergence chips are bad and should be replaced. This is a common problem.
Note: If you TV has as flash focus or magic focus button only try pressing the button. If it fails to fix the convergence your need to fix it. See below for a fix
69189a5.pngCONVERGENCE SOLUTION
You can see some more examples and find a fix using this link on Fixya http://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Jan 17, 2010 | Sony KP-43T90 43" Rear Projection...
Picture Quality
Clean the lenses and mirror. - Carefully with no liquid, just a micro-fiber cloth. They can be accessed by removing the front screen.
There are items in the service menu that can tweak color drive and grey scale, but you can really mess up a TV if you do not know exactly what you are doing. You can also do a comprehensive convergence in the service menu.
Sep 08, 2009 | Sony KP-57WS520 57" Rear Projection...
When connected DCR-SR42 to TV, video and images showing in B&W
yes ur TV might be set to color system PAL /NTSC and ur cam corder in opposite format there is color system changing button on every tv remote just try changing it to PAL or NTSC see if colors work and let me know and pls rate me if i fixed ur problem
Feb 25, 2009 | Sony Handycam DCR-SR40 Camcorder
FOGGY COLOR
Sure, you can fine service menu with universal remote control. Just find properly code number for Sony tv.
Aug 11, 2008 | Sony KP-46S25 TV
Ghost image on sony lcd 5 years old
This problem is a defect in the optics block. There is however an adjusment procedure to correct this problem. Please send me and email to misssiontracetv@msn.com and I will send you back the detailed alignment process on Monday.
Feb 23, 2008 | Televison & Video
Color has too much red
Is this happening when you are switching between color tempature (Normal,Warm, and Cool). You wont be able to access it in normal menu.
You will have to accesss the service tech menu. enter "062596 then info", if u enter the code correct at bottom of screen you will see a warning menu only access by a service tech , continue in menu you will see on main option screen "alignment" enter this. Go to white point adjust the three temp settings (Normal, Warm, and Cool) settings as follows.
Color Temp. I Red I Green I Blue I
Cool 122 120 121
Normal 125 118 108
Warm 127 110 75
( These are factory specs u can tweak them to your own perference)
After u set these press left on remote and exit back to main service menu and store these setting before turning TV off set these settings
I see this alot when Philips manufactured the TV. The did store the settings.
Jan 22, 2008 | Philips 50PFP5332D 50 in. Plasma...
SONY 61" Rear Projection TV
you will need to get a service manual for the tv and enter the service mode. then you will need to readjust the convergence.
Oct 24, 2007 | Sony KP-53S65 53" Rear Projection...
DOUBLE IMAGES
How do we adjust convergence? I went to the service menu and all I see is alot of settings none of which help me out.
Can anyone explain this in further detail?
TIA
Aug 26, 2007 | Sony KP-53HS30 53" Rear Projection...
Sony KP-53HS30 53" Rear Projection HDTV-Ready Television Logo
Top Sony Televison & Video Experts
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
