Fridgidaire washer problem
I noticed you asked someone about the basket spinning freely after their washer stopped spinning. My LTF2140ES0 stopped working during a load of towels. Now the indicator lights come on, the pump runs briefly then nothing. It won't spin on any setting. I did check the belt and while it seems fine, there is a tiny trickle of oil coming from the center shaft where the large pulley is. Any ideas on what's up?
  • mmmmurray Jan 08, 2009
    I had the same problem, washer had a large load, sounded as though the pump was trying to start so that the spin would engage but nothing further would happen. The repair person now says that it needs an entire electronic board which apparently is not covered by warranty.
    The washer is only 3 years old! Any suggestions.
    Novelist:
    Champion:
  • 261 Answers
As a front loader it is different than a top loader. It sounds like your pump is dead or there is an issue with the drain hose or how far it sits in the drain. A clog and/or a siphoning condition can lead to this as also how much and what type of soap is used. A suds lock can cause this also. If the machine agitates fine and the timer advances then the motor control unit is fine. Lets see the only other problem I see is an imbalance. I will post a pic so you can see your machine better.
Posted on Oct 30, 2008
Fridgidaire front-loading washing machine model # LTF2140ES0 will not spin
Good Afternoon Friend,
I understand that your Frigidaire washer, model# LTF2140ES0, will not spin. To try and resolve your washer not spinning, please try the following:
    1)Check your washer door and make sure it is completely closed.
    2)Check your dispenser drawer and make sure it is completely closed.
    3)Your load might be too small. Add 1 or 2 similar items to help balance the load.
    If the above does not work, I suggest resetting your appliance, by either unplugging it or shutting the power off at your home's circuit breaker, for 3-5 minutes. Turn the power back on and try any cycle. I ask that you please follow up with a comment on the post, at your convenience, to advise if further troubleshooting is needed or if your appliances status has changed successfully.
    -Best Regards-
    WP
Jun 20, 2014 | Frigidaire Washing Machines
Whirlpool cabrio washing machine doesn't spin
Try to turn the drum by hand, if it hard to turn, there may be something stuck underneath spin basket. If it does turn freely but makes a loud growling sound, you probably have a bad bearing. You should notice black oil and water mixture at bottom of washer, on the rotor. It will usually throw a f51 error code. This unit has service bulletin on this problem.
Apr 05, 2014 | Whirlpool WTW6400SW Cabrio Washer
Hello, I have a Kenmore Elite Oasis 110.27062603 washer that is displaying error code F 50
The F50 error code indicates that the RPS (rotor position sensor) detects no motor rotation. Check to see if the basket spins freely. If not, you could have an item caught between the outer tub and the inner spin basket. A toy or other item underneath the washer could also prevent the basket from spinning and would result in this F50 code.
If the basket spins freely, you could have a wiring failure that would prevent the motor from spinning.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Aug 11, 2010 | Kenmore 24032\24036 Top Load Washer
My Kenmore Elite Oasis HE model # 110.2706 stopped working during the middle of a load and showed an F 50. Tried to unplug it, restart it and tried the clean machine mode. Nothing is working.
Jul 27, 2010 | Kenmore Elite 45986 Front Load Washer
I am working on a Kenmore Oasis washer, model
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question^%$#@
Jun 29, 2010 | Kenmore 24032\24036 Top Load Washer
I am working on a Kenmore Oasis washer model 110-27062603 which fills a little then code F-50 comes up and it will not run. I can cancel and drain water. I read through diagnostics-found no reading on...
Jun 23, 2010 | Kenmore 24032\24036 Top Load Washer
Whirlpool washer wtw6400 giving F50 error message. i need it fix quick.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question@#$%
Jun 21, 2010 | Whirlpool WTW6400SW Top Load Washer
ERROR MESSAGE F50
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question%^&*(
Jun 14, 2010 | Whirlpool Cabrio WTW6600SBT Top Load...
I am trying to wash clothes with my whirlpool cabrio he but it keeps stopping and saying f50. what should i do?
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question!@#$
Apr 06, 2010 | Whirlpool Ultimate Care II LSQ9564J Top...
My Whirlpool Cabrio 6600sw2 has lots of problems, it stops and flashes F50 over and over again, it also flashes many of the other codes, it doesn't fill with enough water and it is not washing the clothes...
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question****
Jan 03, 2010 | Whirlpool Cabrio WTW6600SBT Top Load...
Washing Machines Logo
81 people viewed this question
Top Washing Machines Experts
