Question about Toro Lawn Mower With Toro Power Tools
Traction cable I need to install a new traction cable.
  • Anonymous Dec 26, 2008
    I
    am tring to install a new traction cable on a toro recycler push mower. How do I get the plactic piece thru the hole in the deck?
    Scholar:
  • 76 Answers
The black cover on the front of the mower is held on by 2 screws from underneth, remove the cover and that will give you acess to where the cable connects to.then you can use a pair of pliers to squeeze the end of the cable to disconnect it from it's mounting hole.
Posted on Jan 15, 2009
  • Torodude May 25, 2011
    The first cover screw (or bolt - 5/8") is easy to locate. If you're like me and you never wash the underside of your mower, you'll swear there isn't a 2nd bolt but there is. It's located on the edge of the circle that the blade rotates in. If you run your finger along that circular edge, you'll feel a bump and that's the bolt head, but it's undoubtedly caked with old grass, so you'll have to peel that off to really see that it's a bolt head. I found that this part is the most difficult of the entire job.
The drive cable came off as i was engaging it & i can't figure how to replace it
TRACTION DRIVE CLUTCH CONTROL
CABLE
6.1. The drive control is on the right side of the handle bars
6.2. Stop engine and allow it to cool disconnect disconnect
the spark plug and ground it to the engine.
6.3. Confirm that the fuel level is low enough to prevent spillage through the gas cap vent with a plastic bag between the cap and the filler neck.
6.4. Carefully tip the snow thrower forward so it rests on the auger housing.
6.5. Mark the bracket to the frame as demonstrated in figure 5.2
6.6. Detach the z-fitting end of the cable from the engagement handle.
NOTE: The cable routes down to the cable guide pulley that is mounted on the drive cable adjustment bracket.
6.7. Remove the bottom access panel.
6.8. Detach the spring end from the friction wheel support bracket.
6.9. Examine the removed cable: If the cable failed because of something other than normal wear, identify and correct the cause before returning the snow thrower to service.
6.10. Install new cable by reversing the removal proceedure.
6.11. Run/test/adjust the tension on the traction drive
clutch control cable.
Feb 15, 2016 | Craftsman Snow Blower / Snowblower Bottom...
How is the traction cable adjusted on Toro Model 20027, Serial # 20005663. I'm replacing the cable and the new one is slightly different from the old one, but the Toro shop tells me it's the proper...
There is a large black plastic nut at the end where the cable attaches to the mower transmission. Turning it clockwise tightens the cable (engaging traction bar is tighter) and counter-clockwise is loosening the drive. If the cable is a little too long, you have to tighten it more.
Sep 27, 2017 | Toro Power Lawn Mower
Change belt on snapper 722 snow blower
1. Remove the belt cover with a socket wrench. Slide the belt cover off and set it aside.
2. Remove the two belt cover stud bolts with a socket wrench to get to the auger belt guide. 3. Remove the belt guide with a socket wrench.
4. Push down on the belt tensioner pulley with your hand. Remove the old belt and set it aside.
5. Install the new belt and release the belt tensioner pulley to tighten the belt.
6. Re-install the belt guide with a socket wrench and tighten the bolt.
7. Re-install the two belt cover stud bolts and tighten with a socket wrench.
8. Re-install the belt cover and secure it with the cover bolts. Tighten the bolts with a socket wrench.
I pulled the following from a snaper model similar to yours.
The snowthrower has two drive belts, one for the traction
drive-which transmits engine power to the wheels, and
a second for the auger drive-which transmits engine
power to the auger mechanism.
Each of these drive belts are of special construction and
should be replaced only with genuine replacement belts
which match the original equipment belts. These are
available from your dealer.
Traction Drive Belt Replacement
I pulled the following from a snapper model similar to yours. Believe it should help.
1. Disconnect spark plug wire and fasten it away from
the spark plug.
2. Remove belt cover. (Located in back of the discharge shute).
3. Pull the traction drive belt idler pulley arm (See
Figure 24) away from the belt to relieve tension, and
slide the belt off the engine pulley.
4. Slip the belt off from around the traction pulley (See
Figure 29) and pull the belt out of the unit between
the auger pulley and the traction pulley (the lower
cover need not be removed for this step).
5. Reverse the procedure to install the new belt. Be
sure there are no twists in the belt, and that the belt is
properly seated in the pulley grooves.
6. Replace the belt cover.
7. Start the unit, and check the traction drive for proper
operation. See "Traction Clutch Cable Adjustment"
for adjustment procedures.
There are also several videos on YouTube on changing snowthrowr belts. (Didn't see one for your blower, but most similar and should provide a good starting reference).
May 09, 2014 | Agri-Fab Agri - Fab Snow Blower - 42"
New Tires installed, ABS, TRAC, Service Traction Control Lights on
if the tyres that u got fitted are not the same all round that would cause the problem
Mar 19, 2013 | 2003 Chevrolet Impala
Where is the location of the traction control system on a 2008 chevy suburban ?
I have a 2011 Chevy surburban, I just had new tires installed and when I left, the traction control suddenly triggers sporatically. do you think this is abs/ traction control is having this issue?
Apr 08, 2012 | 2008 Chevrolet Suburban LT
Abs and traction control off lights on after new tires installed on buick lesabre 2003
if you have a code reader available,reset trouble codes,if that doesn't work you probably need to have it checked out.they may have dis lodged a sensor when they changed the tires.unless you radically changed tire size it shouldn't be the tires
Nov 18, 2017 | 2003 Buick LeSabre
Traction Belt (new) continues to slip off of drive plate.
Sounds like you may need to replace the pulley as well. It has likely worn out of specification.
I recommend that you contact your nearest authorized service center, or contact Toro directly for assistance.
I trust this information proves useful.
Oct 02, 2009 | Agri-Fab Agri - Fab Snow Blower - 42"
I've got a 1999 Caddy Deville throwing a 0741 code and showing "Serv Traction Control" and ABS lights on on the dash. If I'm on a steep incline on dry pavement the traction control tends to come on when...
No you don't need any transmission work, the parts you listed are part of that. You either have a bad wheel speed sensor or more likey a bad connection at one of the sensors. Sometimes the cables get damaged. The cables are supposed to remain flexible but sometimes the wires inside break. These cables go from the wheel speed sensors and feed information to the ABS system.
Jun 20, 2009 | Cadillac DeVille Cars & Trucks
Cable traction needs adjusted
To adjust the self propel cable, loosen the cable
clamp, pull the cable downward to remove all the slack
then push the cable jacket up 1/8”
and secure with the cable clamp
good luck
Jan 26, 2009 | Toro Lawn Mower With Toro Power Tools
Replacing traction cable
Go to toro.com then customer care then manuals and parts type in model then find owners manual to download.
Jan 22, 2009 | Toro Lawn Mower With Toro Power Tools
Toro Lawn Mower With Toro Power Tools Logo
950 people viewed this question
Top Toro Garden Experts
Jim Parker
Jim Parker
Joseph Mueller
Joseph Mueller
lnbn1975
Are you a Toro Garden Expert? Answer questions, earn points and help others
