My computer @Acer Aspire 5101' will no longer record to DVD. It plays DVDs and the drivers are fine. I deleted some files from the registry (on advice) as my DVD drive had disapeared from 'my computer'.
  • wombatski100 Oct 30, 2008
    Still no luck. DVD-RAM DRIVE (E:),properties,under 'recording' the enable box is ticked. The selected drive 'Where windows can store an image of the CD to be written' is ACER (C:). The only other option for this in the drop down is ACERDATA (D:).Should the (E:) drive not be an option for selection?
    Scholar:
  • 195 Answers
Well wombat, removing files from the Registry should not have hurt your drive, but probably screwed up alot of other files because alot of programs share dll's and other pertinent Info. Try opening your Windows Explorer and clicking on MY COMPUTER. If your drive is listed there than your ok. go to your Drive Letter for your DVD and right click on it. Click Properties and see if it is Activated. If Not click on the box and activate it to Record. Hope that does it for ya. Good Luck.
Posted on Oct 30, 2008
Dvd room does not work. Can not read CD, DVD or burn to CDs or DVDs. I have a Acer Aspire 5738ZG.
Hi Welcome to FixYa!
Is this happening on all CDs or DVDs? if it is, the issue that you are encountering could be a software or Hardware issue. Follow the steps below to find out.
1)If its a sofware issue, it could be with the Upper or Lower filters settings for the cd/dvd rom on the registry that is causing you the problem. You could check it by opening Registry Editor. (click on start>type "regedit" on the searchbox and open it. You should be seeing something like the picture below : mondimondz_2.jpg
2)go to this entry: HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\Class\{4D36E965-E325-11CE-BFC1-08002BE10318} That is the key entry for your CD/DVD rom.. Once you are on that key, look at the right panel, and search for Upper Filters or Lower Filters. If you see those entries, delete them. Be careful not to delete some entries on the registry aside from those two.
3)after deleting them, restart the computer.
4)Once you get back into Windows, try to load any cd or dvd and check if it will now be able to read them.
5)if it still does not work, try to go to your computer manufacturer's website and download the latest firmware for your CD/DVD drive.
6)If all else fails, try replacing the CD/DVD drive on your computer.
Hope this could be helpful!
Have a great day!
Jun 22, 2011 | Acer Aspire 5610-4648 Notebook
I cannot detect my DVD-Super Multi DL hardware
When did the problem start? if the DVD drive is not detected on the Computer but you have power on it. it might be a software related issue
You can try to remove the Upper and Lower Filters this normally fix Missing CD-Rom/DVD ROM issue:
*NOTE: MESSING UP THE REGISTRY MIGHT MESS UP YOUR SYSTEM. DO THIS AT YOUR OWN RISK - or you can see some links Below for other T/S Steps.
Clear the upper and lower registry filters
  1. Click the following Microsoft Fix it Solution to clean the registry filters automatically: c01733077.jpg If you cannot use the Microsoft Fix it Solution, continue using these steps to clear the upper and lower registry filters manually.
  2. Unplug all non-essential external plug and play devices, especially cameras.
  3. Click Start c00817930.gif , and type "regedit " into the Start Search field. The registry editor window appears.
  4. Select Computer in the main window.
  5. Click File , Export , type a filename that is easy for you to remember, and click Save . A copy of the registry has saved for back-up purposes to the Documents folder. If problems occur after using these steps, browse to the file and double-click it to restore the registry.
  6. Click the plus sign (+ ) next to the following items in the list:
    • HKEY_LOCAL_MACHINE
    • SYSTEM
    • CurrentControlSet
    • Control
    • Class
  7. Select 4D36E965-E325-11CE-BFC1-08002BE10318 . Make sure you have selected this exact key name.
  8. Select the LowerFilters value and press the Delete key. Confirm the deletion by clicking Yes . Figure 10: Registry Editor: LowerFilters key
  9. If an UpperFilters value is also listed, select UpperFilters in the right window and press the Delete key. Confirm the deletion by clicking Yes .
  10. Delete all other UpperFilter and LowerFilter values within the 4D36E965-E325-11CE-BFC1-08002BE10318 key if they exist.
  11. Close the registry editor and restart the computer. The disc drive should now be recognized by Windows. You may need to uninstall your disc recording software, restart the computer, reinstall the CD/DVD writing software, and then restart the computer again if the software no longer recognizes the drive (see next step).
or try this MISSING DVD ROM FIX
May 11, 2011 | Acer Aspire AS55365142 AMD Athlon X2...
CAN VIEW THE DVD ON A COMPUTER OR THE DVD RECORDER BUT NOT ON DVDS PLAYERS BOUGHT BEEFORE THE RECORDER
This is quite common of older players. Some only work with DVD+R discs and others with DVD-R discs.
Some player also does not read recordable discs (an early form to try prevent piracy)
Also make sure if recorded on your Recorder, that the disc is finalized before you try to play it on an older player. (See your menu / manual on the recorder for the procedure)
Feb 28, 2010 | Sony RDR-VX515 DVD Recorder/VCR
DVD/CD-ROM drive missing
Problem with missing dvd-drive with Acer 5101 solved.
Problem was that depending on boot, even bios couldn?t detect dvd-drive. I
opened my laptop and found out that there were one small screw that wasn?t
connected to anywhere. I opened the screw that locks dvd-drive in to 2.5? slot. In the back of the
dvd-drive is L- shaped peace of metal. One of it?s screws were already dropped
and 2 that were left were loose. I tightened those screws, but drive back and
got my laptop working fine.
http://www.vapaakoodarit.fi/~puontis/cd-drive.jpg
Please feel free to post this solution to other forums as
well.
Jul 12, 2009 | Acer Aspire 5100 Notebook
Acer aspire 5610 dvdram wont recognize any cd/dvds i put in it
To resolve this problem, remove the affected filter drivers. To do this, follow these steps:
1. Click StartStart button, type regedit in the Start Search box, and then click regedit in the Programs list.
User Account Control permission If you are prompted for an administrator password or confirmation, type your password, or click Continue.
2. Locate, and then click the following registry subkey:
08002BE10318}
Caution There can be many instances of the registry subkey that is mentioned in step 2. You must make sure that you are in the appropriate registry subkey before modifying the UpperFilters and the LowerFilters values. To verify that you are in the appropriate registry subkey, make sure that the Default data value is DVD/CD-ROM and the Class data value is CDROM.
3. In the right pane, right-click UpperFilters, and then click Delete.
4. Click Yes to confirm the removal of the UpperFilters registry entry.
5. In the right pane, right-click LowerFilters, and then click Delete.
6. Click Yes to confirm the removal of the LowerFilters registry entry.
7. Exit Registry Editor, and then restart the computer
Mar 17, 2009 | Acer Aspire 5610 Notebook
My Acer Asprire 5100-5674 no longer recognizes the cd/dvd drive.
hi, cd drives do wear out or just break, most time it is software related. but they can just stop working.hope this helps. good luck
Feb 26, 2009 | Acer Aspire 5100 Notebook
Won't play DVDs or CDs at all. Reads error code C-104.
To solve this Code 10 error, follow these instructions: NOTE: After removing these registry keys and rebooting, it may be necessary to reinstall any CD or DVD recording applications.
1) Close all open programs
2) Click on Start, Run, and type REGEDIT and press Enter
3) Click on the plus signs (+) next to the following folders
  • SYSTEM
  • CurrentControlSet
  • Control
  • Class
  • {4D36E965-E325-11CE-BFC1-08002BE10318}
4)This folder is the DVD/CD-ROM Drive Class Description in the registry.Look for any of the following names in the right hand column.
  • UpperFilters
  • LowerFilters
  • UpperFilters.bak
  • LowerFilters.bak
5) If any of the above keys shown in step 4 are listed, right-click on them and choose Delete
6) After deleting the keys, close the
Registry Editor
7) Reboot your computer
8) Open My Computer and check to see if your CD or DVD drives havereturned. You may also want to open Device Manager and verify that theyellow exclamation and error code on the CD or DVD drive is gone.
Dec 27, 2008 | Sansui VRDVD4005 DVD Player/VCR
Wont find cd drive acer aspire 5520
hi .. sir
go and try to open in safe mode .
restart >press F8.
see whether it work's..if not go to the bios setup and see the configuration and sellect . restart > delete . (for bios setup..).
replay me if any problem.. thank u sie. don't forget to fix.
Sep 03, 2008 | Acer Aspire 5500 5570-2609 Laptop
Laptop drive
dear sie
computer acer aspire 1360 pc dvd drive dease not book
dvd driver stop working c drive was over laoded and the computer whent in to disk clean and deletelte the driver for the dvd rom i can no longer play cd dvd or use the crw or dvd RW ASPIRE 1360 2.8GHZ
PLEASE CAN YUO HELP LOST THE DISK THAT CAM WITH THE MACINE
YUORs garyfifiled@talktalk .net
Jul 28, 2008 | Acer Aspire 1360 Notebook
I can't get my computer's dvd burner to recognize dvds when trying to record..This creates problems when trying to record. There is no problem playing dvds
possiboe solutions:
1. download the latest driver for of your dvd player
2. try to use another dvd burner program
3. try this:
Click Start, click Run, type regedit, and then click OK. Registry Editor starts.
Step 2: Delete the UpperFilters registry entry loadTOCNode(3, 'resolution'); 1. In Registry Editor, expand My Computer, and then expand HKEY_LOCAL_MACHINE. 2. Expand SYSTEM, and then expand CurrentControlSet. 3. Expand Control, and then expand Class. 4. Under Class, click {4D36E965-E325-11CE-BFC1-08002BE10318}. 5. In the right pane (topic area), click UpperFilters.
Note An UpperFilters.bak registry entry may also appear. To delete the UpperFilters registry entry, you must click UpperFilters and not UpperFilters.bak. 6. On the Edit menu, click Delete. 7. When you receive the following message, click Yes to confirm the deletion of the UpperFilters registry entry: Are you sure you want to delete this value?The UpperFilters registry entry is removed from the {4D36E965-E325-11CE-BFC1-08002BE10318} registry subkey.
Note Do not exit Registry Editor. You must have this program for the next step.
Step 3: Delete the LowerFilters registry entry loadTOCNode(3, 'resolution'); 1. In Registry Editor, expand My Computer, and then expand HKEY_LOCAL_MACHINE. 2. Expand SYSTEM, and then expand CurrentControlSet. 3. Expand Control, and then expand Class. 4. Under Class, click {4D36E965-E325-11CE-BFC1-08002BE10318}. 5. In the right pane (topic area), click LowerFilters.
Note An LowerFilters.bak registry entry may also appear. To delete the LowerFilters registry entry, you must click LowerFilters and not LowerFilters.bak. 6. On the Edit menu, click Delete. 7. When you receive the following message, click Yes to confirm the deletion of the LowerFilters registry entry: Are you sure you want to delete this value?The LowerFilters registry entry is removed from the {4D36E965-E325-11CE-BFC1-08002BE10318} registry subkey. 8. Exit Registry Editor.
Step 4: Restart the computer loadTOCNode(3, 'resolution');
Jun 20, 2008 | Computers & Internet
Open Questions:
Toshiba Laptop doesn't start up. Black screen [Solved] -Dataalign If you are facing any kind of issues in Toshiba laptops or other products related to Toshiba brand, then you have come to the right place, as this article is an overview of where you can find the right kind of services, required for proper working of the gadgets by any tech savvy person, in particular the ones using Toshiba products. Another beneficial thing about using Toshiba products is its reliable Toshiba Customer Service , which can be reached any time for assistance with guaranteed satisfactory results. Toshiba customer care services are provided by highly efficient and knowledgeable tech support technicians having years of working experience in the field of providing dependable services to the customers of Toshiba. Toshiba support services provided by Dataalign are the best in class for their consistent services and highly advanced way of resolving tech issues faced by the customers. Dataalign tech support team comprises of expert technicians and they make use of high class technology for fixing the issues in Toshiba laptops and other devices as they have proper knowledge of all kind of issues with their perfect resolution. Dataalign technicians can be reached easily anytime from anywhere through the toll free helpline number +1888784-9316. Dataalign assistance providing Toshiba Tech support engineers are selected through a rigorous process of selection which makes them efficient for providing right support in minimum time with high accuracy. Technicians of Dataalign assist the customers in the most polite way with the assurance of providing highly accurate solution for every issue. For the answer of any kind of query related to Dataalign or for help regarding tech issues contact Toshiba support on their toll free helpline number.
Jun 21, 2018 | Toshiba Computers & Internet
Computers & Internet Logo
David Payne
David Payne
