Question about Panasonic (PT-LC56U-DEMO) Multimedia Projector
Leds ON I have a Panasonic PT-LC56U that is presenting the following problem, when I turn on it, the three leds (INPUT, LAMP and TEMP) remain on and it does not do anything more. Often only stay on INPUY and LAMP. Other times only stay on the LAMP led. other times STANDBY/ON stay on in red, other times in red and yellow, at the same time. Which is the problem?
2 Suggested Answers
jyackle5
  • 8197 Answers
SOURCE: PT-AE700U Lamp led flashes red
Reset the lamp hours. Here is the manual on how to reset lamp time.
http://www.projectorcentral.com/pdf/projector_manual_2606.pdf
Good Luck and Please Rate Fixya!
Posted on Mar 12, 2009
I have a 6 yr old Panasonic PT 50 LC13 and I need to know how th reset the lamp. i just replaced the bulb and i cannot get the tv to turn in
To reset the lamp follow the steps below.
Press and hold "Volume down(-)" at the front panel and "TV/Video" on the remote control for more thatn 5 secs in power off condition to activate the Service mode map. You can now reset the lamp.
After that check if the symptoms still there. If yes, let me know the status of the led light(Power, Temp, Lamp) and its color to determine where the fault came from.
Jdvillanueva
Sep 08, 2011 | Panasonic PT-50LC14 50" Rear Projection...
I have a panasonic pt-lc56u projector but need a remote for it. any ideas ? its a very old model but truly a great machine
You can go on logitech.com navigate to the remotes where you can see if they support your projector. Then you get one of their harmony remotes.
Mar 25, 2011 | Panasonic PT-LC56U/76U Remote Control
Hi. I have a InFocus dp2000x. It has no lamp. I try with a flashlight in the lamp chamber (the flashlight is battery operated) When I turn on the projector with a vga or video input, the power led start...
Projectors are designed to be used with a lamp and will turn off when there isn't one present. You would have to purchase a new lamp to use the projector.
Feb 19, 2011 | ASK Proxima Proxima DP2000X Multimedia...
As all the posts on here I have the same problem. My panasonic pt-lb10u turns on, green light flashes, fan comes on. Then the green light turns red and the red lamp indicator light comes on. No light emits...
If your projector won't fire up then you can't reset the lamp counter so that is not the problem.
The combination of LEDs you have given does not correspond to an error message. There should be two LEDs, one of which is the Lamp Indicator, and the other is the Temp Indicator.
It's possible that an overheating problem has caused this. Make sure the projector is in an area where the temprature is between 0 °C (32 °F) and 40 °C (104 °F) and the humidity is between 20% and 80% (with no condensation). It shopuld have unobstructed air flow around it.
Disconnect the power. Remove the lamp and place it aside. Clean the air filters, using a hoover, being careful not to damage the filter which is located on the underside at the front of the projector under a flap.
Carefully reinstall the lamp (when you say you replaced the lamp, did you buy a new PANASONIC lamp from a reputable source?) Try to fire up the projector. Note down any combination of LEDs if the projector doesn't work and post hem back here.
Feb 14, 2011 | Panasonic PT-LB10VU Multimedia Projector
Panasonic projection TV does not turn on.
Power LED flashes orange 1 x 5 secs. = 1 of 3 fans stopped. TEMP LED flashes 1 x 5 secs, = Temperature error. Lamp LED flashes 1 x 5 secs. = lamp ballast error. (check lamp 1st.)
Hope this helps.
Apr 18, 2010 | Televison & Video
Ml-r4667w timer,power,stanby/high temp leds on front panel blink replaced lamp w/original pt
If you replaced the lamp and it illuminates and three blinking leds still appear the you have a bad Color Wheel.
Apr 07, 2010 | Samsung HL-R4667W Rear Projection...
When turned on green light flashes and no picture
Check the Lamp if no picture, audio may be present. Screen is completely dark. Lamp LED flashes 2X every 5 seconds, Power LED flashes GREEN for 140 seconds then flashes RED.
Check the ballast if no picture, audio may be present. Screen is completely dark. Lamp LED flashes 3X every 5 seconds, Power LED flashes GREEN for 140 seconds then flashes RED.
Dec 24, 2009 | Panasonic PT-50LC13 50" Rear Projection...
I have a Panasonic 50" LCD TV PT-50LC13 and the power botton blinks orange 2 time and there is no pic but i can here the fn runing what can i do???
if the tv keps trying to turn on three times and later the lamp led stays steady red. (see owner's manual to replace the lamp process) the lamp is damaged. ones you open the lamp door and take the lamp out you can see the lamp damaged even before to buy it.
Apr 08, 2009 | Panasonic PT-50LC13 50" Rear Projection...
Panasonic pt-52lxc66 power light blinks
There are actually two red leds present on your tv and depending on which one is flashing is going to tell you what to replace. 3X on the Temp led will point to a faulty thermistor and you would want to replace this part. If the 3 red blinks are the lamp light than this is a error on the iris position and you would need to have the optical block replaced.
Josh
Feb 09, 2008 | Panasonic TH-42PD50U 42 in. Plasma EDTV
Panasonic PT-LC56U Multiple pictures
iF YOU HAVE SERVICED THE SAME, THEN YOU HAVE TO ALIGN PANELS. CHECK THE ATTACHED CABLES ALSO..
Jan 17, 2007 | Panasonic (PT-LC56U-DEMO) Multimedia...
Panasonic (PT-LC56U-DEMO) Multimedia Projector Logo
61 people viewed this question
Top Panasonic Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
HEMANT GROVER
mahesh y.h
mahesh y.h
Are you a Panasonic Office Equipment and Supply Expert? Answer questions, earn points and help others
