Question about Nikon D40x Digital Camera
D60 Shutter Speed
When I set the camera on "sports" and use it outdoors for baseball or football, the shots are great even when the person is moving quickly. But when I use the camera indoors with the same setting for volleyball or basketball all of the action shots are blurred. The shutter speeds show to be much slower indoors than out. I am sure that is because of the amount of light indoors. My question is "Can I take action shots indoors?"
    One Above All:
    The expert with highest point at the last day of the past 12 weeks.
    Top Expert:
  • Nikon Master
  • 102,366 Answers
Yes. The question is how good they'll turn out.
You're right that it's because it's darker indoors. You can compensate for this at least in part by raising the ISO. This runs the risk of increased noise, but given the choice between a noisy pic and no pic...
A fast lens may get you a stop or two, but they're expen$ive.
A third option is to increase the amount of light. Multiple flashes around the basket, for example. Or floodlights mounted on the roof...
Posted on Dec 30, 2009
What setting is for sports
That depends on the sport, the location, and what you want the pictures to say to the viewer. You won't necessarily shoot a daytime football game outdoors the same way as a basketball game indoors.
In general you're going to want a fast shutter speed to freeze the action. To get the fastest shutter speed possible, use the Aperture Priority mode by turning the mode dial to "A" then select the largest aperture by using cursor-up/down to get the smallest f/number.
Having said that, sometimes you might want a slower shutter speed to convey a sense of motion. Select Shutter Priority by turning the mode dial to "S" and use cursor-up/down to select the desired shutter speed.
Feb 03, 2014 | FUJIFILM FinePix S4000 / S4050 Digital...
Basicly my problem is that I want to take pictures of my son's playing soccer or baseball and in both sports the pictures is not good. I would like to know which setting I should use to have great
You need to adjust the shutter speed....Because they are not still pix they will almost always come out blurry .What kind of camera do you have?
Jan 10, 2012 | Cameras
Pictures are blurry
There are a few things to consider:
-- Are your hands steady as you take the shot, and are you moving the camera before the shutter actually clicks? As a test, put the camera down on a table top and take a picture without moving the camera until well after the shutter clicks. If the resulting image is not blurry--you just proved that your holding technique needs improvement!
--This camera has image stabilization to help you deal with camera shake--do you have this feature turned on in the menu?
--If your subjects are moving and your shutter speed is slow (meaning that the shutter stays open a relatively long time to gather enough light) then you will get blur. And, even if your subject is not moving but the shutter speed is slow, then your camera shake will come back to haunt you.
To fix slow shutter speed, you can either use a flash to freeze the action, or you can manually increase the ISO setting to a higher number, or you can choose a preset like "sports" which will tell the camera you want faster shutter speeds. A higher ISO setting will allow for faster shutter speeds, but it can also result in a grainy look, called "noise" if you set it too high.
Most likely it is your holding technique and the setting you are choosing that is causing the blur. If you are in decently bright light outdoors, you hold your camera steady and wait for the shutter to click, and you have image stabilization on, then you should have sharp pictures. If you are indoors, expect to need a flash.
Nov 25, 2010 | Canon PowerShot SX100 IS Digital Camera
Hi! I just got an SB-900 flashlight to go with my
Personally, I'd go with Manual on the camera so as to have complete control over both aperture and shutter speed, and iTTL on the flash. Bear in mind that a single SB-900 isn't going to light up an entire basketball court or wherever you might be photographing. If the pics are too dark, it's most likely that the subjects are too far away.
If you take a picture of a chair in the middle of your living room, does that come out too dark?
Dec 28, 2009 | Nikon D60 Digital Camera
I have the Nikon D60 - Ive taken sport/action pictures
The main difference between the two shooting conditions is the amount of light you have to work with. For the indoor action shots, set the ISO setting to the highest available through the menu (1600 ISO) to maximize the ability of the camera to work with the diminished light. The other (but more expensive) way to achieve better indoor shots is with the use of a "faster" lens, ie one with a lower maximum f stop number (f2.8 is faster than f3.5, for instance). Also ensure you are shooting with your lens at its widest f stop setting (lowest number).
Jul 26, 2009 | Nikon D60 Digital Camera
When on sports setting, my camera shoots slow and blurry when indoors
More than likely, your exposure- specifically your shutter speed settings- are too low. When you have fast action, you must have a higher shutter speed (Higher, meaning that the DURATION of the exposure is less. So, an exposure of 1/250th of a second is more desirable than an exposure of 1/30th of a second when shooting indoor sports. (This difference equates to about 400% more exposure, duration-wise). When shooting sports indoors, a "Fast" lens, meaning that the front of the lens is bigger, which allows more light into the camera at one time. (This normally equates to "F-Stop" settings. So, a 50mm F1.4 lens will be a "faster" lens than a 50mm F2 lens. The lower the F number, the "faster" the lens. This also equates to higher prices...) Another consideration for shooting stop-action sports photography indoors is using higher ISO settings. When you double the ISO number, you cut the amount of light required to make a good exposure in half. So, ISO 200 requires half the light of ISO100, and 400 requires half the light of 200 and so on. Typically, I use a setting of ISO 800 or higher for indoor sports (Which, BTW is my speciality...). The trade-off for using higher ISO settings is that it introduces more noise into the image, which many people find less desirable. I also wrote a few articles for POPULAR PHOTOGRAPHY & IMAGING about shooting sports. The "football" article will more than likely be the most help to you. Basically, ALL sports photography is shot the same way, and if you use these techniques, your work will greatly improve. Here is a link to those, and hope they help!
http://www.popphoto.com/Blogs/Sports-Photography
http://www.popphoto.com/Features/Shooting-Talladega-Superspeedway
http://www.popphoto.com/Features/How-to-Photograph-Football
Jul 10, 2009 | Nikon D60 Digital Camera
Nikon D60 Digital SLR--Slow Shutter Speed
Your're probably using a flash with TTL disabled. So 1/200 is the highest sync possible with that kind of flash. Did you try removing the flash off the body and setting faster shutter speeds?
Apr 28, 2009 | Nikon D60 Digital Camera with 18-55mm lens
Shutter Speed too slow on indoor sports for Nikon D60
Maybe. Assuming you can't add more light, you can either increase the ISO and/or open up the aperture. Try going to A (Aperture) mode and opening up the lens all the way. This will give you the fastest shutter speed possible under the conditions. That may or may not be fast enough.
Nov 02, 2008 | Nikon D40x Digital Camera
Blurred football pictures
low light means the shutter stays open longer to capture the image.   Try changing exposure settings.
Sep 30, 2006 | Canon Digital Rebel XT / EOS 350D Digital...
Nikon D40x Digital Camera Logo
134 people viewed this question
Top Nikon Cameras Experts
Steve
Are you a Nikon Camera Expert? Answer questions, earn points and help others
