Question about Durabrand DWT1905 TV
Won't receive digital signal
I have a Durabrand 1907, and it says on the screen, "Digital Signal Low", however, I receive the digital signal on all other televisions in my house. What seems to be the issue here?
Thanks
  • Durabrand Master
  • 520 Answers
Call the customer service number on the set.
Posted on Oct 30, 2008
Can not tune tv since change over
The KV-32FS100 only has an analog tuner (NTSC). Unless there is a low-power analog station still broadcasting in your area, you will not be able to watch OTA stations. (I've got one in my area that barely comes in.) If your local cable still sends an analog signal, you won't need a set top box to watch that subscribed service.
Otherwise, you need a set top box to watch TV. A digital to analog converter (the boxes that were available with the government coupon before the switch over) will give you over the air stations. The basic models only provide SD output; there are a few HD models available. Otherwise, you can use a satellite reciever, cable box (for digital cable service), or something like the Boxee or Sling with tuner. (There are a few different models of the Boxee; one added a tuner with a USB dongle. The newest model of the Boxee has the ATSC tuner built in.)
Note: OTA digital signal quality is either a strong enough signal for the tuner or no signal will be present. You need to point the antenna in the correct direction to receive the signal from your local transmitters. The type of antenna and its placement will also change the number of watchable channels. You can use antennaweb.org or tvfool.com to get more information. Antennaweb assumes an outdoor antenna but gives a conservative list of stations. If the signal is split to several devices, you may need an amplifier to get a watchable signal. (Sometimes amplifiers fail and you won't receive any stations, so test without the splitter or amplifier by using a direct cable to one TV.)
I hope this helps.
Oct 26, 2012 | Sony FD Trinitron WEGA KV-32FS100 32" TV
Tried to hook up a HD antenna but it won't work
HD is pretty critical and if a indoor antenna do not expect much or anything for that matter.
Jun 17, 2012 | Televison & Video
All ready used box once. Now going back to antenna. Not receiving display or menu on T.V. screen.
All TV over the air is transmitted as a digital signal now. In order to see it on an older TV (read Analog), you must have a signal that you can receive(antenna hook up) and a digital to analog converter box. That box allows you to see your digital signal on older TVs. The signal is sent from the antenna to the box via a RF connection, and decoded to channel 3 or 4 (your choice). for further information see Consumer Report at:
http://www.consumerreports.org/cro/electronics-computers/tvs-services/non-digital-tvs/digital-converter-boxes/digital-tv-converter-boxes-first-look-3-08/overview/digital-tv-converter-boxes-first-look.htm
Jan 09, 2011 | Insignia Digital-to-Analog Converter for...
"no signal"
"no signal" means that the monitor is not receiving a video signal from your computer or laptop. This is normal if the compouter is OFF and the monitor is ON. Is the computer still on and connected to the monitor?
Mar 27, 2010 | Princeton Digital VL1514 Monitor
DURABRAND TV MODEL DU 1901
Very easy to find out just plug it in.Have an antena,get picture ur tv work with digital,their no more analog signal out there.
Dec 16, 2009 | Durabrand DU1901 TV
I'm trying to set the digital channels on my durabrand tv and i get the message that digital channel signal strength is low. what do i need to do?
If you are using a regular antenna to receive the signal, then you would need to either find a signal booster of some sort, or improve the antenna. There are many antennas out there for the digital era, most of them are set-top multi-/omni-directional ones, but they have their limitations. Unfortunately to get a better signal, typically an outdoor antenna is needed, or a large expansive one in the attic.
Nov 19, 2009 | Durabrand DWT1905 TV
We bought a 20" analog/digital tv the analog channels come on fine but we it scans for the digital channels it says no siginal will we be able to watch it when the change takes place even though we can't...
This could be caused by two different issues.
  • Digital signal reception is bad. The digital signal must be locked in, digital signal reception is either on or off (not like analog signal reception where you can receive a low signal and a fuzzy picture). You may need to adjust you antenna direction and height or obstructions around your antenna, reference the web site for your specific location (address) for antenna compass headings. http://www.antennaweb.org/aw/Address.aspx
  • Television is faulty, digital receiver is bad. Your new television has two receivers, an analog receiver and a digital receiver. A simple power surge will knock out your digital receiver. Make sure you have a quality surge suppressor connected to the television power and the antenna is properly grounded. Return the television for a replacement and purchase a quality surge suppressor.
You must add a quality surge suppressor to your digital television! http://ezinearticles.com/?Power-Protection-in-the-Home-Theater---Use-of-Surge-Suppressors-to-Guard-Expensive-Electronic-Gear&id=41318
Good luck.
Jan 03, 2009 | RCA 20F420T 20" TV
Does my tv have a digital tuner (RCA Model E13320, 2/2001)?
The digital tuner has nothing to do with the new signal you will be receiving in February of next year. The new video signal is a digital signal. The old video signal is analog. Your television receives the analog signal and converts it to what you see on television. You need a converter box to convert the new digital signal back to an analog signal your television can convert.
Jerry
Nov 07, 2008 | Televison & Video
Sub Problem with Dennonavr- 1907
Go into setup and make sure sub is turned on and set sub for LFE + main otherwise sub will only work with Dolby Digital LFE signals. LFE plus main setting will allow sub to output low freq's that would normally go to Front Speakers. Refer to Owners manual setup Info.
Feb 11, 2008 | Denon AVR-1907 Receiver
Durabrand DWT1905 TV Logo
78 people viewed this question
Top Durabrand Televison & Video Experts
matt martin
matt martin
Are you a Durabrand Televison and Video Expert? Answer questions, earn points and help others
