Question about Brother DCP 7010 Multifunction Laser Copier
Brother dcp 7040
Seems to be using excessive amount of toner
  • 320 Answers
By scrolling thru the menu u can click on toner save mode
Posted on Jan 16, 2009
Brother dcp 7040 prints and then prints too light
Before refilling, clean entire cartridge units. Remote its cleaning blade and clean it with an IP solutions and make sure no bends in cleaning blade. Do not mix new toner powder with old one. Also clean plastic portion below the developer roller also. Then the same complaint found, clean the LSU unit of the machine. Now it work properly.
Feb 10, 2015 | Brother DCP-7040 Laser Printer
How do you replace the drum for a DCP-7040 brother printer
The drum is the the part where the the toner is attached to it , I replace mine once a year, I use it a lot, to reset the Drum Open the toner cover on the printer press Clear/back then press up /+ button good luck ce045b2c-0a6a-4f93-aca7-1409863e8241.jpg
May 29, 2014 | Brother DCP-7040 Laser Printer
Brother DCP-7040 Laser Printer Issue
With the computer off will the printer still make a copy? If the printer can still make a copy stand alone, then try deleteing the printer and reinstalling the printer driver.
Mar 31, 2014 | Brother DCP-7040 Laser Printer
Replace the toner with a new one.
Jan 18, 2014 | Brother DCP-7040 Laser Printer
Brother dcp 7040 prints grey film over the page
someone cheaped out and got the el cheapo paper.
The low quality paper has paper dust on every page....
when the printer feeds this cheap paper thru the machine it drops the dust onto the tonor cartridge rollers and causes the roller to accumulate toner on the roller... this in turn is transfered to the pages being printed.
check your machines operation manual. There may be a clean cycle you can try to run to clean the rollers...
I had to buy a new toner cartridge for mine when this happened.
Apr 17, 2013 | Brother DCP-7040 Laser Multifunction...
Error message "put the black toner cartridge back in"
I got this same error message on a newly acquired Brother DCP-7040 that I purchased used off of ebay.
As I was troubleshooting this unit (that I bought untested off of ebay - hey gambling has paid off handsomely for me many times before!), this error message kept popping up.
I checked the COUNTERS (page & Drum life) and found out that the DRUM had 0% life left. BUT, the reason it showed ZERO was because this unit did not have any drum! The toner cartridge (TN-360) needs to sit WITHIN the drum (DR-360) on this DCP-7040 unit, as well as in models DCP-7030, MFC-7340, MFC-7345C, and MFC-7440N.
So perhaps some of these "put the black toner cartridge back in" problems could be related to the DRUM (or lack thereof). A possible tipoff (since the toner cartridge actually does slide into the unit much like other units that do not use Brother's DRUM carrier) seems to be the relative ease with which the toner cartridge slides into the DCP-7040 and really doesn't seem to "lock" into position real firmly.
Apr 23, 2012 | Brother MFC-7340 All-In-One Laser Printer
How to check the toner level of Brother printer
It has no accurate measure of the toner left, it is reset when you put in a fresh toner and just counts prints. The Brother shines a light thru a little window from right to left and when the toner is empty the light shines thru and it says it's empty.
Jan 13, 2010 | Brother DCP-7040 Laser Printer
Toner Life End message on DCP-7040
If your cartridge has a lever on the left side near the rear, it needs to be reset, and there's a lever inside on the left that can stick and cause that error. You need to wiggle and pull that lever until it moves freely again.
Jan 04, 2010 | Brother DCP-7040 Laser Printer
Brother Toner Refills
Yeah you can refill your cartridge. It is really easy and consists of removing the plug on the side of the cartridge, dumping out any old toner and dumping in the new toner. Its very easy. I have purchased refill kits from both of these sites in the past and its worked great:
They also have great customer service. I hope this helps!
Nov 08, 2009 | Brother DCP-7040 Laser Printer
Cartridge error msg
You have a bad toner cartridge or a poorly remanufactured toner cartridge. This condition called "false toner low".
Mar 12, 2009 | Office Equipment & Supplies
Brother DCP 7010 Multifunction Laser Copier Logo
154 people viewed this question
James Cagle
James Cagle
Jim Keysor
