Question about HP LaserJet 1320 Printer
What is orange light with ! in the middle. It is on and won't go off
I have cked. and printers are seeing computer. The orange light is on that has ! in the middle of a triangle. I can't get it to go away and the printer won't print from any of our computers. We are on a network and have never had this problem before. HELP!!!
We have 2 of these in different offices that occasionally have the same problem. The web browser doesnt respond and the only way to get the printer to work again is to switch it off & on. We tried a brand new 1320 and this has the same problem. We solved it by fiting a timer to the mains lead so the printer is switched off at night.
No firmware upgrades from HP and we've tried all sorts of drivers but the problem seems to be it doesnt like being left on for long periods of time
Posted on Oct 30, 2008
  • 66 Answers
maybe your printer has a jam paper, try to locate it at fuser assembly and inside the printer and released the jam.if it's not work, it maybe you need to drop it on a service center to fix that kind of problem...
Lenovo blinking orange light only
1) try to turn on the computer and after the BIOS appear press key f8 and select safe mode.
2) click the icon my computer click the properties and select took, use check now with chkdsk, and fix folders too.
3)run the antivirus+malware+update windows,
4) You can get support from LENOVO via ONLINE get the sofwtare diagnostic, or use the installed in your equipment RUN it. for to see if there are conflict hardware vs software.
God bless you
Sep 27, 2012 | Computers & Internet
Orange light on SIDE (not top) of HP LaserJet P2015 Series printer won't go out. Have disconnected all leads and re-booted printer and computers (2) to no avail. There are no paper jams and have
Is there any text to indicate what this light refers to?
In general, you might want to remove paper trays, and use a compressed air can to spray inside the printer, especially the paper path. Oftentimes, paper dust will impede a photo-optic sensor, and keep an indicator light lit when there i no real reason for it. It can also give you a paper jam indication when there is none.
So blow out all paper dust to get the printer to work correctly now.
Cheers!
-a.
Apr 10, 2012 | HP LaserJet P2015dn Printer
My desktop has an orange light no beep sounds when starting it won't boot up the back where ethernet plug goes is orange too the fan makes a burning smell also
Orange light usually means the harddrive or computer is processing and loading, But it can also mean that there is a problem with the hard drive. Start your computer and wait. If you see orange light it means its working to boot up, it might take a while, you might see your screen black for a while but eventually will work.
To fix this problem you need to upgrade more hard drive space, RAM memory and processor speed
Nowadays a computer should have a minimum of 2GB of RAM memory, at least 120GB of Space, and about 2.0Ghz of processing speed.
You can also buy great refurbished computers which are cheaper. Most of them come with 4GB of RAM memory, 250GB HD Space and 2.5Ghz processing speed.
May 24, 2011 | Dell Computers & Internet
Alternate green and orange lights flashing, tried to remove battery pack and left off for half hour, still problem, if i hold green button down orange light blinks 15 times which i saw in the manual to...
Hi I have a ip100 portable printer and both green and orange lights flash. Green flashes twice and the orange light flash at what seems to be a random disorder.
May 17, 2011 | Canon iP100 Portable Printer
Alarm and ink buttons all orange flashing E and 3 What do i do? first time both inks low cannot replace as do not stop in the middle holding down reset button turning printer on and off
You need to reset the Printer
Clear the EEPROM
1) With the printer powered off but connected to a power source, press the Power button while pressing and holding
the Stop/ Reset button.
2) When the Power LED is lit, press the Stop/Reset button two times while pressing and holding the Power button.
3) When releasing the Power button and the Stop / Reset button (regardless of order), the printer will move into a
service mode. (Waiting for menu selection)
4) When the LED lights in green, press the Stop/Reset button the specified number of time(s) according to the
function listed in the table below.(Each time the Stop/Reset button is pressed, the LED lights alternately in
orange and green, starting with orange.)
The number of the Reset
button pressing
LED Function Remarks
0 time Green Power off
1 time Orange Service pattern print
2 times Green EEPROM print
3 times Orange EEPROM reset
4 times Green Waste ink counter reset See waste ink counter reset
procedures below.
5 times Orange Destination setting See Destination setting
procedures below.
6 times Green Print head deep cleaning
11 times Orange Button / LCD checking
12 or more times Returns to a menu selection
Jan 05, 2011 | Canon Office Equipment & Supplies
We are in the middle of printing our Tax Return and an orange light keeps blinking on the top of the printer - and it has stopped printing.
Hi and thank you for using fixya:
On this specific printer model this light means that your paper has jammed, you need paper, or your ink is low. Please re-start your computer and printer and try again. If problem persists check ink levels on the printer settings (computer)
Good luck
Apr 13, 2010 | HP DeskJet 932c InkJet Printer
Paper jammed in the middle and orange light started blinking. How do i make this print again. tried pressing orange and green button to no avail
canon printer. remove all traces of paper in the paper path. remove the power plug and replace after about 30 seconds. restart the machine and clear the orange button.
Oct 17, 2009 | HP LaserJet 1015 Printer
I cant print from hp laserjet 1320, orange light is always on.
there is something wrong in your cartridge may be its empty.. replaced a new one
May 19, 2009 | HP LaserJet 1320 Printer
Cant print, middle orange light always on
replace the cartridge, even a used one will do. If this solve the problem take the chip from the good cartridge and place it on the defective one.
Printer out of paper error on HP694c
  1. Turn the printer off and open the cover.
  2. Lift the right black rectangular paper sensor (located in the middle of the printer just below cartridge slides) clean it up, try with vacum cleaner first if it does not help use coton swabs and clean it.
Good luck
RC
Jan 30, 2008 | Computers & Internet
HP LaserJet 1320 Printer Logo
307 people viewed this question
Ben Johnson
