Coffee and Espresso Makers
Problem for Coffee and Espresso Makers
Generic problem for all Coffee and Espresso Makers
KRUPS XP7220 error 06 problem
By goraslan on Oct 29, 2008
Hi i thought maybe you can help me. Thanks in advance :)
You see i have a krups xp7220 i took it from a friend of mine. Its like new i saw inside information only 10 cups were made.
So my problem is that its not making coffee the first time when i took it it made 1 cup of coffee then stopped and gave me an error code of 06. I like playing around withe machines so i opened it from up i cleaned inside there is a hole i cleaned that too i noticed that when i turn on the power its doing a test mode and it stops during the test mode giving me that error 06. So what i noticed is that i think that its not pumping in water.But when its turning on its taking some water from the water tank because i see it.I noticed also that when th er is no water and i refel water its turing on normally but when its trying to make coffee its grinding its taking inside but its not giving water at the end because when i see the rubbish of the coffee its not wet. i put it one bu luck in cleaning mode and ther was water coming or i dont know maybe the air pressure was working. Also you can put a water filter in the tank but i dont have one. Is it possible to be from the filter? Because in the manual its not saying that you sould have the filter on always.
my email is goraslan@hotmail.com
please give me an idea what to do i cant find a technician to fix it
Popular Solutions for Coffee and Espresso Makers
Questions and Unsolved Problems for Coffee and Espresso Makers
Answer
Where in North-Central London can I purchase a replacement gasket for a 1-2 cup vigano stovetop... (More)
Answer
How do you disassemble the black and decker undercounter spacemaker coffee maker. I've removed the... (More)
Answer
My Keurig one cup maker has been malfunctioning and water and coffee grounds gush up and out the... (More)
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For Coffee and Espresso Makers:
Top Coffee and Esp... Experts
Rank: Guru Guru
Solutions: 898
Experience: im the jack of all trades but a master of none! and being an old git you get to learn a fuw tricks
Ask Me
Find more Coffee and Esp... Experts
Top Small Appliance Repair
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
