Question about Minolta Office Equipment & Supplies
Malfunction C-1102 is shown on display screen.
  • Minolta Master
  • 6,168 Answers
What model sir/mam?
Posted on Dec 28, 2014
Display of vb100 pro tablet malfunction
What kind of malfunction are you getting? Colour distortion? No display at all? Lines down the screen? Black spots? White spots? No backlight?
Mar 20, 2014 | Televison & Video
Kodak Easyshare camera DX4330- Does not take or show picture on screen
Hello, Internal malfunction with unit, time for service/repair or replace.
Nov 24, 2012 | Kodak EasyShare DX4330 Digital Camera
I have a GE15350 mechanical timer i am not sure how to -Fix ya
Question is not complete.
Copy following link to view 120Volt GE15350 timer manual and example wiring.
http://waterheatertimer.org/GE-timers-and-manuals.html#15306
To set current time, rotate dial until correct hour lines up with the word time located on lower right of timer dial.
GE timers are made by Tork. Tork P47 trippers attach to timer dial as shown following link:
http://waterheatertimer.org/images/Tork-1102-3-500.jpg
Jul 13, 2012 | Hardware & Accessories
I loaded a new colour cartridge in a lexmark p4350 it gives me a code 1102 i have cleaned the heads and still it gives an error 1102
The 1102 error message is caused by a communication failure between one of the printheads (cartridges) and the All-In-One (AIO). Please refer to this article to determine and resolve the issue: 1102 Error Message on the Lexmark P4300 Series All-In-One.
Apr 13, 2011 | Lexmark P4350 All-In-One InkJet Printer
I download 4 applications for my ipod touch and only one apps.is shown in the ipod screen. The other 3 is not shown but indication showing that i have 4 apps. downloaded. What seems to be the problem?
The iPod Touch displays apps across multiple 'Home screens'. To display your other apps, swipe across the screen with one finger from right to left. This will display the second home screen.
Apr 03, 2011 | Computers & Internet
Error 1102 Refuse to print PC screen says incompatible cartridge although I'm using original lexmark cartridge.
The 1102 error message is caused by a communication failure between one of the cartridges and your printer. Please visit the Lexmark website and refer to this article on 1102 Error Message on the Lexmark P4300 Series All-In-One. If you need additional assistance, please contact Lexmark technical support.
Hope this helps.
Feb 25, 2011 | Lexmark P4350 All-In-One InkJet Printer
My calculator won't turn off completely no matter how many times I try it, and replacing the batteries doesn't work, unless I take them out for around half an hour or more, which is extremely inconvenient...
There are several reason why the Ti89 family of calculators might experience this inability to not shut off. Mainly, it has become known that foreign material or, static charges can get into the ports causing this malfunction. Other reasons are related to the OS, APP's and, 3rd party programming.
Generally, reinstalling the operating system takes time and, you can destroy some of your previous work. My aim here is to give you some instructions so, that you can get your calculator operating properly in the least amount of time.
(Procedure 1).
Check and see if there is any dust in the IO ports. Figure 1, shows where and what the IO ports look like and, gives some idea where they are located at the top of the calculator.
oneplusgh_9.jpg Figure 1.
Now look into both ports. Do you see any lose dust or material inside. If so, real gently with something small and non-metal (like a tooth pick), see if you can get any lose dust and debris out of the holes.
Warning! "Do Not Use Force To Get Obstructions Out".
Once you have the ports as clean as you can, blow into them with about a one second bursts. Make sure you do not spit! Now press [2nd] key and the [ON] key to turn the calculator off. Did the calculator turn off? If yes, then your done. If no, go to (Procedure 2).
(Procedure 2).
On the TI-89 family, press and hold the [2nd] key, left arrow, and right arrow; then press and release the [ON] key. This should reinitialize the operating system, in which you should see a progress bar filling on the screen. This is in hope that if any internal program was running it will now be turned off. On the TI-92 family or Voyage 200 can do the same procedure just use the [HAND] key in place of the 2 arrow keys. Now press [2nd] key and the [ON] key to turn the calculator off. Did the calculator turn off? If yes, then your done. If no, go to (Procedure 3).
(Procedure 3).
1. Press [F5], If successful the screen will display as shown below. Goto step 2.
2. Press [Diamond] [Clear], If successful the screen will display as shown below. Goto step 3.
3. Press [alpha] [S] No screen shot could be given. Go to step 4.
4. Press [0], This key is the number zero and, not the letter O. Make sure you enter the number 0 to RETURN to the Home screen. If successful the screen will display as shown below. Goto step 5.
5. Press [2nd] [Quit], If successful the screen will display as shown below. Goto step 6.
6. A repeat of (Procedure2). On the TI-89 family, press and hold the [2nd] key, left arrow, and right arrow; then press and release the [ON] key. This should reinitialize the operating system, in which you should see a progress bar filling on the screen. On the TI-92 family or Voyage 200 can do the same procedure just use the [HAND] key in place of the 2 arrow keys. If successful the screen will display as shown below. Goto step 7.
7. Now press [2nd] key and the [ON] key to turn the calculator off. Did the calculator turn off? If not go to (Procedure 4).
(Procedure 4).
Steps to re-installing the operating system:
• Connect the TI Connectivity cable between the PC and the calculator.
• Click on Start >> Programs >> TI Tools >> TI Connect >> TI OSDownloader
• Follow the on-screen directions to reinstall the calculator's OS.
Oct 20, 2010 | Texas Instruments TI-89 Calculator
Wont run
  1. Clear the ERROR from the screen: Press and hold the MY CYCLES and BACK buttons simultaneously for 3 seconds. The control will display any recorded errors. Please write down what error codes are shown on your screen in case service is needed. If a MORE icon is displayed on the screen, press MORE to list additional errors. When the EXIT button appears, press EXIT.
  2. Remove Power: Follow the onscreen instructions to remove power (unplug unit) and then immediately plug unit back in.
  3. Clear Setup Mode: After power is restored, a setup screen that begins with "Congratulations..." will be shown. DO NOT PRESS the OK button shown at the bottom of the screen. Press the START/STOP and POWER buttons simultaneously until the Home Screen is displayed. Your unit is ready to function normally.
Aug 19, 2009 | GE Profile Harmony WPGT9360E 4.0 Cu. Ft....
Top Minolta Office Equipment & Supplies Experts
Adorjani Laszlo
Norman  J Weimar Jr
Norman J Weimar Jr
David Burkhart
David Burkhart
Are you a Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
