Question about Lite On LVW-5005 DVD Recorder
Dvd recorder repair
How do you do a hard reset? I am not an electronic tech. I took the cover off, turned the recorder on and tried to eject again. Nothing. I don't know how to get the disk out of the tray. Do I have to take the front off too? How do you release the tray manually?
  • Anonymous Nov 01, 2008
    What a coincidence. Mine broke again for the second time this year, and I only got around to taking it apart tonight.
    After pulling the DVD drive out of the unit, look at the front of it. On the left side, under the drawer, mine has a curved indentation. When I press the eject button, I see this indentation depress by itself, but it apparently wasn't going in far enough. Just putting my screwdriver in that little indentation was enough to free it up.
    Let's see how long it lasts this time!
  • katpat2 Nov 01, 2008
    I think I need to find a repair facility near me. Nothing is working that has been suggested.
Thanks, I have a dvd recorder lvw 1105GHC and seems not to have any but the door. when I push the eject button i just hear the sound but not open the tray. So, I push the eject button and at same time pull out the plastic door tray with a nail. It worked this time
Posted on Dec 12, 2008
    Genius:
  • 1,550 Answers
Remove the cover of LVW and access the dvd assy,unscrew the 4 screws holding the dvd assy to the LVW bottom.
Remove the top and bottom shield (also 4 screws)and remove the top black plastic cover (4 screws).
You will access the dvd spindle.
Remove the dvd stuck inside.
Posted on Oct 30, 2008
DVD recorder dubbing/playing problems
your disc reader is dirty and needs cleaned..this can be done 2 ways.. one is to buy a can of electronic dusting spray, use the wand attatched to the nozzle .. stick the wand into the dvd slot and spray short bursts into the center area of the slot( dvds record and play from the center-out) the other is to find the screws that hold the cover on the unit(usually phillips head) and remove them..carefully remove the entire cover exposing the inner works of the recorder, again using the duter spray, clean the entire inside of the unit..paying close attention to the lens area of the reader..make sure not to blast it too hard and loosen the base..just enough to dust it off..then replace the cover and run the unit normally.. these units are quickly showing up at resale shops everywhere as folks are getting new digital recorders that record to a hard drive..so you may find a replacement there..I have several..
Jan 19, 2014 | Panasonic DMR-EH50 DVD Recorder
DVDR/VCR Combo_ZV450MW8a. When I insert the VHS cassette...
Had the same problem. took cover off, cleaned the recording heads. Also look on the left and right of casett chassie.You'll see to thin green strips sticking up with a black elctronic device. Chech to see if it is aimed at the clear plastic pin near the little black plastic gear in the middle. mine was out of alignment on the left one. Works know. Good luck
Jan 24, 2010 | Philips Magnavox MWR20V6 DVD Recorder/VCR
A jammed DVD will not eject. Message"Repairing" goes on and on and nothing happens.How can I reject the dvd?
To whom it may concern
Thank you for the offer. I will bear it in mind should I need further assistance.
I solved the problem by removing the cover and loosen the clips where the disc tray is and slid the release tray and by pressing the eject button, the tray ejected the disc.
I have tried other discs by recording, deleting and ejecting and so far the problem has not been experienced again.
Kind regards.
Mr. NTD
Jan 11, 2010 | Funai PY90DG DVD Recorder
Cannot eject DVD or turn off machine or anything
hold your power button down for 8 seconds and the machine will power down
Feb 19, 2009 | JVC DR-MV5S DVD Recorder/VCR
Have a phillips DVDR model#3455H.Inserted dvdrw disc recorded with videos recorded on it in my computer. Disc works fine in my pioneer dvdr but when I put it in the phillips it will not load and it will...
The electronic procedure:
Switch off the unit at the wall plug. On the front panel, hold in the <RECORD> and <EJECT> buttons at the same time, and keeping them held, switch on the power at the wall again. Keep holding the buttons until the disc tray opens.
Apr 03, 2008 | Televison & Video
Vr540 philips
Error 2 and error 3 and error 4 are tech codes.
and if your unit won't reset, you can take it to your local
electronic repair shop. I had error 3 on my Phillips,
and he went to the PM webpage,researched it, and fixed it perfectly for $39.00 total. STILL WORKING!
He said it was some little thing to replace that took him 15 minutes.
If you don't want to buy one of the REALLY cheaply made vcrs or DVD/vcr combos that are out now, it worth a little phone time to find
an electronics repair shop. Or the new DVD recorders with vcr combos are very good, but sturdy ones are expensive.
Dec 25, 2007 | Philips VR540 VHS VCR
Repairing disc message won't go & DVD disc won't eject
By pressing the Power button for >10 seconds you can force the unit to turn off. Immediately as the unit does, press the disk eject button and the defective DVD can be removed. Don't put it back in, or the problem may repeat!
Nov 17, 2007 | Pioneer DVR-530H-S DVD Player/HDD Recorder
My hitachi dz-mv730a won't eject
did u tried to press the eject button for a few seconds (~20sec) wait & see what will happen. or better you use a direct plug of AV adapter. maybe theres a need for additional power on your cam.
Sep 04, 2007 | Hitachi DZ-MV730A DVD Camcorder
Akai DVD recorder tray will not open
I am pursuing the exact problem above. I have found a not so hi tech solution. I firmly rap on the top above the disc drawer. This is while Close is being displayed and the drawer is in. If you hear some spinning and load displays it should now work. It may be back to cycling again on the next ejection though.
Technically I figure it may be a sticky magnetic reed switch or what ever they use to detect the drawer position. Mine displays either open or close when it starts to cycle.
Aug 08, 2006 | Akai DVDRW120 DVD Recorder
Lite On LVW-5005 DVD Recorder Logo
371 people viewed this question
Top Lite On Televison & Video Experts
Jaime Hernandez
Henry  Thomas
Henry Thomas
Are you a Lite On Televison and Video Expert? Answer questions, earn points and help others
