Question about Lexmark X2500 All-In-One Printer
Cancelling/stopping a printing job
I was scanning a document a few days ago and was having trouble. i went out of the program and when i turned the printer on the next day, it began printing the document and it wouldn 't stop! how do i cancel/stop a printing job? thank you.
  • Lexmark Master
  • 5,568 Answers
Open the Control Panel from either the Start menu or by opening 'My Computer.' Find your Printers and Faxes folder and open that.  Double-click on the icon of the X2500; if more than one, choose the one with a check mark and double click on that icon. This will open a 'job list' showing those which were not completed for some reason, click on it (them) and delete it from the list.
Posted on Oct 29, 2008
How can I stop it from printing over and over again
you have clear the print buffer in the computer.
by clearing out the buffer, unplug the computer after ward and than also unplug the printer too, that should clean the memory in the printer itself.
GO TO START CLICK ON START GO TO DEVICES AND PRINTERS, OPEN THE FOLDER CLICK ON THE PRINT YOU ARE HAVING ISSUES WITH DOUBLE CLICK IT WILL SENT YOU TO CHECK LIST OF OPTIONS THE FIRST ONE.
1. SEE WHATS PRINTING, CLICK TO OPEN
2. HIGH LIGHT PRINTER THAN SCROLL DOWN TO CANCEL ALL DOCUMENTS.
YOU SHOULD BE DONE
BUT YOU STILL HAVE TO CLEAR THE MEMORY THAT STORE INFORMATION IN MEMORY INSIDE THE PRINTER
BY TURNING OFF MAY NOT BE ENOUGH YOU MITE HAVE STILL UNPLUG IT TO CLEAR ANY OR ALL MEMORY FILE
THANK YOU ROD
Mar 03, 2015 | HP Office Equipment & Supplies
2001 Bonneville! Several weeks ago, had trouble turning the key in the ignition - sometimes would turn, sometimes wouldn't. Then the Service Engine Soon light came on and the car stalled out a few times...
Service Engine Soon came back on and the car is again stalling ????? Did you have it checked for DTC'S - diagnostic trouble code's ? Service engine soon light on , codes will be present !
Apr 20, 2017 | 2001 Pontiac Bonneville
I want to cancel to print and my printer doesn't have a cancel icon to do this. do I just turn off my printer? My printer is PH Photosmart. Please advise - I'm new to all this. Thank You.
When u print it goes to a "cue" on the pc and stays there untill done. Turning off your printer will not work as the "job in the cue" is still there. When u turn on your printer the job starts up untill finished.
Ok to stop a print job turn off printer.
........Hope you are running windows 7
1.) Open devices and printers
2.) double click your printer
3.) select see whats printing dialog
4.) select the items in the list then right mouse click
5.) select CANCEL
6.) The job is now deleted from the que so when you turn your printer on it will not start until you print your next item.
Apr 01, 2011 | Office Equipment & Supplies
Hi fixya i have presented this problem a few days
Go to Start\Programs\Panasonic and look for the "Network MFP Utilities"
There is a "Network Scanner Configuration" software that create
s a "Location" for the scanner. The location can well be a network drive or a shared folder on your computer.
Once you create the location, the scanner will pick it up automatically so when you want to scan, you will be able to select the destination (i.e. the location you created)
You can create several locations to be able to save scanned docs in more than one place.
Jun 27, 2010 | Computers & Internet
Ir3570 Takes Half Hour to start printing 3 pages - help!!!
Sounds like you have the wrong driver installed, go to canon website and download a new driver for the machine
Jul 06, 2010 | Canon ImageRUNNER 3570 Copier/Printer
Cancelled a job and it stays in queue
Cancel all the documents in the print queue, (just do it whether they are actually deleted or not), press "cancel" on button the printer and restart your system and also the printer. If possible, please leave the printer switched off for few minutes and don't forget to use the "Power" button to turn if off or on. This will help your printer to restart new print job, all the jobs on the print queue will be deleted/cleared. Good luck, Thanks for using FixYa.
Jun 08, 2010 | HP DeskJet 5550 InkJet Printer
How do I cancel a print job?
just turn the printer off...and delete the commands from the error and job folder...you have to insist ...and try to open it from control panel or Hp in all programs .if it doesn't work from tray system ...this is the way to annul the commands...if it does not want to ..restart and try it again until it get rid of it ...restarting will make it not see that is used by another device ..
Nov 11, 2009 | HP DeskJet 895cse InkJet Printer
Having problems deleting pending documents
Assuming you have a modern windows pc, You will need to manually stop the print service. Do this by running the command "net stop spooler" from the "run" line. Then go to "C:\WINDOWS\System32\spool\PRINTERS" and delete all the files from there. After these files are gone, start the spooler service again by running "net start spooler". You should be all set after that.
Jun 09, 2009 | Office Equipment & Supplies
Lexmark, scanner asks for pin code and won't scan without it.
This drove me mad for about 2 hours (I've just experienced the same problem), but have finally found the solution!
Firstly, it depends on what Lexmark you have (as different printers use different software)...
For my Lexmark which is an S600, I went into the program 'Lexmark home' which was in the lexmark folder on the start menu and in my lexmark software folder, went to 'settings' and then 'Network computer name'. From here you can set the pin.
According to people experiencing this problem with other Lexmarks, you can do this via the equivalent 'productivity suite' program through 'network settings'.
Hope this helps.
May 17, 2009 | Lexmark X6650 4-In-One Wireless InkJet...
Lexmark X2500 All-In-One Printer Logo
77 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
