Question about HP Computers & Internet
The hp director has a problem at scan it ask for a disk to be incerted. it should scan and ask for e- mail or fax what is the problem
    Scholar:
  • 195 Answers
When your printer was installed it was with a disk, its looking for that disk again so it can load a driver or dll. It wants to know where that disk is, or where the file it is looking for is located. The director will read that disk or file and load what it wants so your scan will work. In short. You need that Installation Disk. Good Luck.
Posted on Oct 30, 2008
How do i scan a picture to e-mail with HP 1350 all one
"Scan to email" feature is dependent upon the TWAIN and MAPI supported applications. TWAIN and MAPI (Message Application Programming Interface) are standards that relate to "Scanning" and "Scan to email" features respectively. Applications have to support these to make use of HP Director. Not all email accounts are MAPI supported applications. The following are the ones which satisfy the MAPI criteria.
Microsoft Outlook Express 6
Microsoft Outlook Express 5
Microsoft Outlook Express 4
Microsoft Outlook 2000
Microsoft Outlook 98
Microsoft Outlook 97
AOL E-mail Version 8
AOL E-mail Version 5
AOL E-mail Version 4
If you are not using any of the above email accounts, you need to configure your email account with Microsoft Outlook/Outlook Express to use this feature. After configuring, you can use the scan to Email feature by perfroming the following steps.
1. Open HP Director/ HP Solution Center.
2. Click Settings -->> Scan Settings & Preferences --->> Scan to... Setup.
3. Select the available destinations and add them to the front panel destinations.
4. While scanning, you will receive a window showing the scan details which contains the section "Where do you want to scan?". Select "Email".
Dec 28, 2010 | HP PSC 1350 All-In-One Thermal Printer
It will no longer scan and will not receive Fax. It will still copy and print
Kindly install the scanner software for printer..You just re install the driver software cd it will automatically install the missing components.
Which is contains the hp director software. Which shows the scanning option For normal scanning you can choose the option of Scanners and Cameras wizard in control panel. But it is better if you have software disk of printer because it contains more option.
for fax
Go to menu option and choose the option fax and set the parameter like auto receive or manual set the ring auto answer mode after certain ring. If it is in auto receiving mode it will receive the fax after the ring which you set. Make sure the phone wire which you insert in fax machine getting proper dial tone and getting out going calling facility.
Have a nice day and do not forget to rate please...!
Feb 26, 2010 | HP OfficeJet 6210 All-In-One InkJet...
I want to scan a picture on my HP officejet K60 and email to my account. I need to know how to set this up
Hi bee03101962,
When scanning to e-mail, the scanned image is placed in a newly created e-mail message as an attachment. Complete the message, adding addresses, subject, and text, and send it. Here's how you would do that.
  1. Start the e-mail program and connect to the Internet service. For some programs, doing this first avoids confusion about assigning the e-mail a date and time for delivery.
  2. Load the original in the scanner.
  3. In the HP Director , click Scan to E-Mail . The all-in-one product scans the document, and the scan appears in a new message window of the e-mail program. NOTE: When scanning to e-mail, the scan is saved as .jpg file, which generally results in a smaller file size. Regarding file size, if the .jpg file exceeds the ISP's maximum size, consider rescanning at a lower resolution. Microsoft Office 2000 programs may or may not be supported. For more information on supported programs, check the HP Web site: www.hp.com/go/all-in-one.
  4. Process the e-mail message normally.
The scanner software scans into several e-mail and fax programs. If the program is supported, its name may appear in the Send To list in the Scan window. Some e-mail programs appear in the list as Mail. Good Luck, Don't forget to leave a rating. Thanks Mark
Sep 16, 2009 | HP OfficeJet k60 All-In-One InkJet Printer
HP Director is missing
This site has a all in one printer disk>
http://thepiratebay.org/torrent/4345425/HP_Officejet_9100_Series_(9110__9120__9130)_All-In-One_Printer_D
The disk has HP Director on it...
Jul 11, 2009 | HP PSC 2410 All-In-One InkJet Printer
FAX_CDA
do you have a HP Printer/Scanner/Fax?
If you do then reinstall the drivers and all should be ok.
please remember to rate this answer if it helps you
thanks Trev
Apr 09, 2009 | HP Media Center m7250n (ED842AA) PC...
Need steps to scan document to email
The destination of a scanned item can be set to E-mail using the Director screen. Before changing the scan to destination to E-mail, make sure the E-mail program is compatible by checking the following points:
  • The E-mail program must be set up and functioning properly. The E-mail program must be MAPI compliant.
After making sure the E-mail program is compatible, change the scan to destination to E-mail using these steps:
  1. Open the Director window.
Click Settings , and then click E-mail Settings .
This will let you enter info so your printer can find your email program. Also, if you click, Help, Onscreen users guide from the director window. These are usually pretty good with step by step directions. Hope this helps! Happy scanning!
Jan 29, 2009 | HP Officejet 5610 All-In-One InkJet...
NO HP DIRECTOR AVAILABLE AND PROBLEM DOWNLOADING
vista have scanning program already installed.
choose start->all program "Windows Fax and Scanning"
This feature works only with Windows Vista Ultimate, Windows Vista Business, and Windows Vista Enterprise.
Jul 17, 2008 | HP Officejet 5510 All-In-One Thermal...
I would like to know how to scan a document and e-mail it on my HP Office Jet 5610 all-in0-one printer
Hello jzwakman,
HP does make this possible in several different ways. You can scan to OCR software (optical character recognition) or you can scan your document to an image. You may also scan directly to e-mail.
To do this, you will need to become familiar w/ the HP Director Software and w/ managing your scanning from the All-In-One itself.
You can find many helpful links on HP's web site for your All-In-One Machine - including HOW TO'S on scanning. Please, see the links below.
HP 5610 ALL-IN-ONE SERIES
HP 5610 MANUALS
HP 5610 FAQs
HP 5610 HOW TO USE: SCANNING
USING THE ADVANCED SCANNING FEATURES OF THE HP DIRECTOR SOFTWARE
Please, let us know if we can be of further assistance.
Thank you,
BJ
Apr 02, 2008 | Office Equipment & Supplies
The printer will not scann to the computer
Are you able to print? I suspect so. If not your probably looking at a bad cable or corrupt windows drivers.
The director software uses it's own system to talk to the printer via scan / fax though printing is controlled by windows itself. Since scan and fax are the same function to the printer, essentially i would start by re-installing the director software.
1. Remove it via add/remove programs, don't reinstall over. It may work but you'll likely just waste time, you want all it's files gone and replaced with new ones.
2. If that has no effect remove the printer from Control Panel > Printers. Also remove the scanner device from Control Panel > System > Hardware > Device Manager >
3. Reboot, windows doesn't really remove things till you shut it off.
4. Install the director software again, hook up the printer when asked.
Again:
If you can print at all communciation with the device is perfectly fine from a hardware perspective.
If you can fax without the computer then your scanner and such is fine from a hardwware perspective.
So your problem is simple software, either windows devices install or hp director. Both simple to remove and re-input.
It's very
Nov 09, 2007 | HP Photosmart 2710 All-In-One InkJet...
Computers & Internet Logo
42 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
