Hi...need help I have a Whirlpool Duet (i HATE it) nothing but problems .... I am getting an f-23 or f-22 ?? we have taken off the panel and cleaned out the trap that you unscrew from the round cylinder...my Q is ...how do we access the "Impeller" ?? I can feel it with me fingers and it is moving.... nothing seems to be lodged ? but when I run a "drain & spin" the error still comes up?? I was able to blow on the drain line and it is clear...leaving the pump. I wish you can help me ... I have 3 kids and the clothes are piling up and I just can't even imagine calling a repair person...as I just don't have the money . * the machine is a little over 2 yrs (just out of warranty) Thanks so much for any info :) Fondly ~ Teri
  • jmpnjackass Oct 30, 2008
    Thank You ! Thank You! Thank You !
    I'll try these things and let you know what happens :)
  • 5,911 Answers
In order to access the impeller, you need to remove the pump and separate the motor from the pump housing. There are several screws that hold the two halves together. Now...with that in mind, it does not take much to damage these small drain pumps (I know its a crappy design). If there was something caught in the drain pump for any significant period of time, chances are the motor may be damaged. I have also seen where the impeller was still intact, but was stripped and free spins on the motor shaft. The result: the pump "appears" to be running, but isn't pumping anything. You cannot purcahse any of these parts separately (that I know of) as the pump is sold as an entire assembly. Another possibility before we jump right on the bad pump bandwagon, is to check the drain line just PRIOR to the pump inlet. This is the line that runs from the bottom of the wash tub to the pump. There is a plastic ball valve inserted in the line on some models that prevents objects from getting pulled into, and possibly damaging, the drain pump. I have found on occasion, however, where a small sock or wash cloth gets lodged in this area and will cause a no drain problem. The pump is normally full of water at all times. If something plugs the inlet, this will also give errors on the front panel display.
Here's an easy thing to try in determing a clog in the drain line I mentioned. Remove the drain line from the standpipe at the wall and take a wet/dry shop vac and pull a suction on the line. If there is a clog anywhere between the drain line, pump and wash tub, the vacuum will strain. You will also notice the drain line(s) collapse at the poinit where the clog is.
If you have already tried all of this, the only remaining option is to replace the drain pump. You can purchase a new one at searspartsdirect.com. Just type in your model number and look under the "Pump and Motor" parts heading for (I believe) item number 10. The reason I mention ordering on line is because this isn't normally a standard part an appliance repair store would carry in their inventory. They would need to order it anyway. If you determine you have a bad pump and wish to replace it on your own, the following link gives you the steps neccessary:
http://www.fixya.com/support/r385845-checking_drain_pump_in_whirlpool_duet
I do hope this information helps you in some way. If you have questions, or need further assistance, please let me know.
Posted on Oct 29, 2008
  • Jeff Rockwell
    Jeff Rockwell Oct 30, 2008
    I just noticed I posted the wrong link for replacing the drain pump. The link above explains how to CHECK the pump for clogs. Although, the steps are not too much different, I want to make sure you have the correct information (if needed);
    http://www.fixya.com/support/r401845-rep...
    Hope this helps.
Describe your Whirlpool Duet GHW9150P Front Load Washer Problem the control lock button is on
Hello & Welcome to FixYa
This is a common issue with Whirlpool Duet washer however; your whirlpool duet washer needs a reset to resolve the control lock problem. Press and hold the END OF CYCLE/CYCLE SIGNAL button for 15 seconds to reset the control. Please get back to me if you have any other questions.
Kevin
Aug 15, 2011 | Whirlpool Duet GHW9150P Front Load Washer
Why is my whirlpool duet gas dryer is take too long to dry? even the bed sheets.
If your
dryer is not drying like it once did or if you just have not taken the time to give yourself a clean dryer in a long time then you need to do that. At least once a year the dryer cleaning should take place. Lint build up in the dryer duct is one of the main causes for your dryer to fail.
Here is the rest of this tip about
Dryer Maintenance
heatman101
Jan 14, 2011 | Whirlpool Duet 7.0 Cu. Ft. 7-Cycle Super...
G.E. WHIRLPOOL DUET DRYER MOD.# GEW9200LW0 my grandma has this dryer and the problem where having is it will start,run,get hot but takes 2 hrs to dry, vents are clean, and i put my clothes in it and it...
If your dryer is not drying like it once did or if you just have not taken the time to give yourself a clean dryer in a long time then you need to do that. At least once a year the dryer cleaning should take place. Lint build up in the dryer duct is one of the main causes for your dryer to fail.
Here is the rest of this tip about Dryer Maintenance
heatman101
Dec 27, 2010 | Whirlpool GEW9200L Electric Dryer
F21 clogged line on a new Duet Sport less than a year old???
Hi, regarding the F21 Error on the Front End Whirlpool Duet, I was able to resolve the problem with the instructions from here, just want to stress cleaning out the filter by removing the front panel. Very easy and the error code is now gone. (screws are underneath front panel at bottom, remove stacker drawer for easy access, remove screws, pull panel off, remove the filter cap, turn to the left and pull out-that's where you will locate the clog.
Oct 02, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Hi. I have a Whirlpool Duet Washer and Dryer. The washer is a GHW9150. My problem is that when I put the "he" liquid laundrey detergent and clothes softener in their specific spots they do not feed down...
.Their are a number of small holes in the top of the housing that let the fresh water down into the tray causing the soap or the softener to run into the washer these easily become clogged thru no fault of your own and can not be properly cleaned Another problem could be is the cam assy. that's mounted on top of the dispenser housing is not working correctly, This is the same model I have here at home and had the same issue.My solution was just to replace the entire dispencer assy parts about $65.00
Sep 08, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool dryer is not completely drying my clothes, appears to be getting overheated. Any suggestions
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
heatman101
Sep 04, 2010 | Whirlpool Duet 7.0 Cu. Ft. Super Capacity...
I have a Whirlpool Duet HT. Moved it to clean behind it and now control panel won't work. It has power because when I plug it in the light that says contro panel locked is on. Nothing else works and the...
Hi
Thanks for using FixYa. To resolve this and unlock the controls you’ll need to press and hold the END OF CYCLE button for 10-15 seconds. Please do rate the solution if the issue is resolved or post a comment for further assistance.
Thanks
Rylee
Aug 28, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool duet sport front load washer
the panel below the door has 3 screws under the bottom lip of the panel. remove the screws to get the panel off youll see the pump right in front of you. you can unscrew the cap on the pump and remove it to clean out the punp. thats where 99% of clogges are on that washer
Nov 25, 2007 | Whirlpool Duet GHW9150P Front Load Washer
Washing Machines Logo
37 people viewed this question
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
