Question about Bell & Howell Copiscan 8000 Spectrum Series Path-Through Scanner
Lines on front image
Lines running down the lenght of page
  • 490 Answers
Cleant the galss with Isopropyl alcohol, dont use solvents
S. Mohan, India
Posted on Mar 03, 2009
Front brake lines
hi ,having troubled with rusted lines?best way to do it is getting a few pre-double flared segments of brake lines of different lenght,a couple union and a bending tool(it could be a special pliers or a rounding shape tool,very cheap at harbort freight or any major autopart shop) tha would be of a lot of help and far as the base of the question(routing the lines) this particular vehicle has extra holding clips to add another line,so the procedure is eliminate the factory brake lines and just another line(s) by just following the course and contorsions of the older ones and bleed the lines once you done.the image it's not from a suv but basically same concept. 40aef758-c2bb-4b89-a046-88ad8b9424bf.jpg
Jul 14, 2014 | 1997 Mercury Mountaineer
I'm getting a straight line of no text or image running from the top of the page down to the bottom of the page. The print started getting fainter and fainter until there was no print at all in a 1/8 to...
Please run a printer alignment exercise. Then do a print head cleaning exercise. If these does not solve the problem then try to reset you printer. Clear the printer memory. Please follow the user manual to perform the steps.
Dec 21, 2010 | OKI C5100 Laser Printer
Brake line leak
brake lines are available in several lenghts, you can do it in two pieces which will make life easier, use a use a brake union not a compression fitting, if the line is too long coil it near the master, it will absorb vibration
Jul 27, 2010 | GMC Yukon XL Cars & Trucks
Hi, I just aquired an HP 4600n color laser printer, it is used but it works good for text but when printing pictures it prints a really bad quality mainly due to a buch of (mostly yellow)lines running the...
First. Examine the toner cartridges by inspecting the surface of the drum of each color cartridge. Score marks? Replace toner cartridge(s).
Next. for vertical lines from top to bottom, you will want to inspect the fuser real quick to see if the Hot roller is scored or worn or discolored or any adhesives are adhered to roller. Should be perfectly smooth and uniform in color.
Next, do the consumables life page which is in a menu function.
Information --> Supplies Status Page.
This will tell you the life remaining of the image transfer kit (C9724A) as well as fuser unit. These indicators will help you decide if the consumables are the first cause of the print quality issues you are observing.
Feb 12, 2010 | HP Color LaserJet 4600n Printer
When I copy or scan a picture a line is down the center of the picture
When scanning the page it is passed over the scanner, a mark on the scanner will then be copied down the full lenght of the page. I not sure how much access to the scanner you have with this model but you need to examine the scanner for a spot of dirt/correction fluid and clean it, you may need to scratch it off with an old credit card or similar
Sep 09, 2009 | HP OfficeJet k60 All-In-One InkJet Printer
Brake line
I'd suggest getting a piece of string and running it the length of the existing line, then add about 10% to come up with an approximate lenght
Apr 07, 2009 | 1996 Chevrolet Cavalier
Epson aculaser c9100 error code Eo86
After a repair person came and worked on the Epson Aculaser CX11NF, I have vertical line, full lenght across every printed page
Oct 08, 2008 | Epson AcuLaser C1900 Printer
Single black line down center of newly copied page when using Auto feeder to copy
I had this same problem but after while it went away - so my solution would be to just keep using it, and perhaps it will solve itself.
Jun 03, 2008 | HP Photosmart C6180 All-In-One InkJet...
Hp laserjet 2200d
If the toner smears after the page comes out of the printer you may need a new fuser. The fuser is the heating unit in the printer and can usually be seen from opening the back door. Check and see if it has a line worn down the same side as the mark on your pages.
Feb 15, 2008 | HP LaserJet 2200D Printer
Bell & Howell Copiscan 8000 Spectrum Series Path-Through Scanner Logo
91 people viewed this question
Top Bell & Howell Office Equipment & Supplies Experts
Are you a Bell & Howell Office Equipment and Supply Expert? Answer questions, earn points and help others
