Question about Mitsubishi WS-65809 65" Rear Projection Television
Blurred Picture Mitsubishi WS-65809 65"
I have trouble with the entire picture. Barely watchable. Picture is blurred. Can barely, if at all read letters. Is the lamp bad?
  • 2 more comments
  • NICOLE_MISKE Oct 31, 2008
    Is it expensive to fix? Would I be better off just buying a new tv?
  • Casey Nov 07, 2008
    I have the same problem I think. After I watch for a little bit, it goes into almost like a 3d effect, or something like this. Ill wack the side of the tv with my shoe, and, all is ok for a couple mins. But, then goes right back to 3d. Im, pretty good with electronics, but not the lingo.
    Thanks
  • Anonymous Nov 14, 2008
    I have the same problem so does everyone with this model. I have found that the IC's are the problem.
  • jason May 11, 2010
    do you know about the conversion ic's? or settings?
  • 905 Answers
The convergence IC's will most likely need to be replaced as well as a resistor or two
electech
Posted on Oct 31, 2008
My mitsubishi wd82738 starts normally green light flashes and then stays on,i get sound and blurred bars that are barely visible
Probably a lamp problem. They aren't very expensive and relatively easy to replace. If not the lamp, possibly the color wheel. If it makes a high pitched sound from time to time, it's definitely the color wheel. Good luck
Aug 26, 2014 | Mitsubishi Wd82738-wd-82738 82" 3d Ready...
Picture borders bow inward and blurred. Only focused in center of picture .Kinda looks 3dish
your convergence IC's have gone out. Lot of pins on these bad boys if you don't know how to solder then call a repairman, but expect a heafty bill.
Aug 06, 2009 | Mitsubishi WS-65809 65" Rear Projection...
Borders bowed inward,blurred red,blue, & green
the next time it is not working go into the customer menu with remote and call up the convergence grid and look---there---if convergence is way off and or comes and goes---this set uses 2 Stk-392-570 ic's and it is quite common to see them become intermittant.
Aug 03, 2009 | Mitsubishi WS-65809 65" Rear Projection...
I have a Mitsubishi 55 inch rear projection tv, ws55819 on which the convergance is gone bad. I'm getting a concave picture with multiple colors and black lines with a blurred picture. this happens mutiple...
Your reference to concave picture suggests a high voltage problem and not convergence. If the raster can't scan from left to right , top to bottom, your having High voltage trouble. if your colors are not dropping on top of each other that is convergence. I would suggest it may be time to consider a purchase of the new HD set for the cost of this repair. good luck
Jul 03, 2009 | Mitsubishi WS-55819 55" Rear Projection...
Colors are bleeding and picture blurred. Can't adjust convergence settings.
Replace the two Convergence amp ICs they are both STK392-570 Ics you can get replacements at the following link with free instructions on how to remove the old and replace the new ones.
http://servicemanuals.vstore.ca/
May 23, 2009 | Mitsubishi WS-55819 55" Rear Projection...
My son purchased a rear projection Zenith Z52Z95D for next to nothing. It I would guess is an older television and I would like some input on whether or not it's worth it to repair. The picture is dark and...
I HAVE A 48" REAR PROJECTION (SONY) THAT WAS PURCHASED IN 1997. IT FINALLY WENT OUT LAST WEEK. PARTS ARE NO LONGER AVAILABLE UNLESS YOU WANT TO PAY A HEFTY PRICE. I AM NOT GOING TO REPAIR MINE AS IT IS NOT AFFORDABLE TO DO SO.
Jan 05, 2009 | Zenith Z52Z95D TV
Picture turns to red & green and becomes blurred.
This is likely solder connections cracking on your convergence ICs. If you can bump the tv and it goes back to normal, it just needs resoldering, but if it doesn't, then it needs the ICs replaced. If the convergence is out, you will see a bowed picture and the red, green, and blue will be separated. Worth repairing if you can find a company to do it affordably, I can help you repair yourself if you have disassembly and soldering skills.
Dec 03, 2008 | Mitsubishi WS-65809 65" Rear Projection...
Mitsubishi WS-55511 Convergence problem ? Unable to adjust. Picture is blurred with green shadows around images on screen
Convergence ICs and the two pico fuses need replacement. You can get replacements at the following link with instructions.
Nov 23, 2008 | Televison & Video
Picture Blurred
If you head a pop then your color wheel may have gone out. You need professional support to get this replaced.
Aug 23, 2007 | RCA D52W20 52" Rear Projection HDTV-Ready...
Mitsubishi WS-65809 65" Rear Projection Television Logo
128 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
