Question about Epson Aculaser C1100 Printer
Printer won't recognise new toner cartridge
I have replaced the yellow cartridge but when the printer warms up a message continually tells me to replace the yellow. I've replaced others on this machine but now I'm at the wall.
  • theivies May 02, 2009
    i HAVE THE SAME PROBLEM ABD HAVE TRIED 3 NEW CARTRIDGES AND ALSO CLEANED UP THE INSIDE OF THE CARTRIDGE PLACEMENT
  • 628 Answers
Is the new cartridge made by Epson? Also check the contacts on the cartridge and in the printer where the cartridge contacts mate. Sometimes there is foreign material that blocks the signals. It's also possible that you have a defective cartridge. Check with the place you bought it.
Posted on Oct 29, 2008
Printer Supply Error 10.1004
This kind of error are cause for a toner cartridge, install a new HP toner, a your problem go.
Jan 12, 2014 | HP LaserJet 2840 Printer
Cartridges error on a lexmark
Error: "Invalid Toner Cartridge"; Error: "Invalid Refill"; Message: "Change Cartridge"
Solution
One of these error messages may appear on the printer display immediately after or shortly after a new toner cartridge is installed into the printer. Note: This may not be specifically a toner cartridge problem; the error may be due to a stuck cover open switch on the printer.
To see if the cover open switch is the cause of this problem, open the top front cover and observe the message on the printer's display panel. The display should read Close Door or Insert Cartridge.
If this message is not displayed, the top cover open sensor and switch will need to be replaced. In addition, the printer may have damaged the new toner cartridge. If the cover open sensor is not operating properly, a new cartridge can be incorrectly flagged as a refilled cartridge by the printer. If this happens, the new cartridge will continue to cause an Invalid Refill or Invalid Cartridge error even if you try reinstalling it or installing it into another printer. If this should occur, please contact the point of purchase of the cartridge to find out how to get the cartridge replaced.
Caution: If the cover open sensor is not operating, do not install another new toner cartridge until you have completed the directions below. Inserting another new cartridge can cause that cartridge to stop working as well. Should this situation arise, please take the following actions:
Place the original working cartridge (the empty or near-empty one) back into the printer. This should clear the error message.
Turn the printer off. Doing this will disengage the cover open sensor.
With the printer switched off, open the top lid and remove the old toner cartridge.
Now replace the old cartridge with another new Lexmark toner cartridge.
Power the printer back on. The printer should now read this cartridge as a newly installed toner cartridge and the error should be cleared. The printer and toner cartridge should function properly now, but the top cover sensor on the printer will still need to be replaced.
If your printer is still under warranty or covered under a service contract, please contact Lexmark Technical Support or your service provider for further recommendations and instructions. Until you can get the cover open switch replaced, remember to have the printer powered off whenever you replace the toner cartridge.
If the top cover switch appears to be working fine, or if you have followed the above steps and your printer continues to post an Invalid Toner Cartridge or Invalid Refill error, make sure you are using a new original Lexmark toner cartridge. A toner cartridge remanufactured or refilled by a third party can cause this error.
To help identify a refilled cartridge, look for the yellow label attached to the toner drum and the body of the toner cartridge. If this is damaged or removed, the cartridge may have been refilled.
If you are using a third-party refilled or remanufactured toner cartridge, it is recommended that you install a new Lexmark brand toner cartridge. Lexmark cannot guarantee the compatibility of any third-party toner cartridges with our printers.
OR
1 Switch on the Lexmark X83 printer.
2 Lift open the cartridge door at the front of the device, below the scanner unit. The printer automatically moves the cartridge carrier to the correct position.
3 Pull each ink cartridge toward you to unclasp it from the carrier. Lift the cartridge out of the cartridge carrier.
4 Clean the copper contacts on the bottom of each cartridge with a clean, dry lint-free cloth. Use a gentle, circular motion to clean the contacts.
5 Insert the ink cartridges back into the cartridge carrier. Push back firmly on each cartridge until it snaps into place.
6 Repeat each step in this procedure again. Close the cartridge door.
Oct 04, 2012 | Office Equipment & Supplies
Hello - my Lexmark E120 will print a test page, but won't print anything that I send to it. I just get an error message. There is a green light next to the 'lightbulb' on the printer. The...
The light next to the lightbulb on the printer Toner low/replace PC kit. The printer is ready to receive and process data. In addition, the toner in the toner cartridge is getting low.
Solution:
? Press continue button to clear message and continue processing job.
? Remove the toner cartridge. Gently shake the toner cartridge from side to side and front to back several times to redistribute the toner, and reinsert it. Repeat this procedure multiple times. If the print remains faded, replace the toner cartridge.
For further assistance, please contact Lexmark Technical Support
Sep 12, 2011 | Lexmark E120n Laser Printer
54.15 error code
Error Code 54.XX
Control Panel Message: Printer Error
Description:
15 Yellow CPR sensor
Recommended Action: Turn the printer off and then on, and then check the following itmes
Check the connections. Replace the color-registration detection assembly.
Description: Printing cannot continue. There is a sensor malfunction.
XX Description
15 - Yellow toner remaining sensor (J1014 toner level sensor)
Jun 24, 2009 | HP LaserJet 4700 Printer
Toner exhausted replace toner in Laser Printer SCX-4300
My laser Printer shows a message and do not prints any document. When i try to print any document. My printer shows a message "Toner Exhausted, Replace Toner". Plz tell me how can i solve my this printer's solution.
Mar 25, 2009 | Samsung SCX-4300 Monochrome Laser...
Error message: invalid toner yellow
If the toner is empty it will display this message and the only way I know of getting rid of it is to replace the cartridge. They do make refill kits with extra chips so you can cut the old one out and sticky tape another on. As for a clearing code I am unaware of one for this unit as the information is store in the toner cartridge.
Sorry
Jan 06, 2009 | Samsung CLP-600N Laser Printer
Won't recognize toner cartridge
go to: www.fixyourownprinter.com
the solution is to reprogram the eproms on the cartridges, easily done.
Dec 17, 2008 | Samsung CLP-510 Laser Printer
Yellow run out how can i still use printer?
Hi , You can try to do a disable cartridge check in the printer menu? But more than likely in order to get the full printing you might have to wait. Also you should check to see if the toner low message is set to on or otherwise when the printer runs out of ink it stops completly. Good Luck!!!
Nov 29, 2007 | HP LaserJet 3600dn Printer
Insert Yellow toner
There is a cheap under the toner... it is probably corrupted... with a screw driver you should take it out and replace it with the old cartdrige toner.
Nov 08, 2007 | Dell 5100cn Laser Printer
Konica minolta error
I had the same problem and found that one of the toner cartridges must have not been seated properly. I removed the black toner cartridge and re-fitted it. The printer now works fine again with no errors. 17H is a code relating to a fault in the rotation ......... possibly one or more toner cartridges need checking. Use the menu on the printer to turn it to the appropriate position (i.e. engine menu then select replacement of whichever toner you are checking).
Hope this fixes your as well.
Chris
Aug 27, 2007 | Konica Minolta magicolor 2300DL Laser...
Epson Aculaser C1100 Printer Logo
143 people viewed this question
Top Epson Office Equipment & Supplies Experts
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
