Question about Sony Grand WEGA KF60XBR800 60" Rear Projection Television
GHOSTING Increasing amount of ghosting
  • tcmike64 Nov 17, 2008
    can someone please e-mail me back a resolution to this problem??
  • Anonymous Dec 28, 2008
    Similar ghosting problem, increasing in severity over a period of months.Does anyone have a solution?
    jmlngma@yahoo.com
Hey joseph, actually replacing the optical Block is not necessary at all, all you need to do is get into the "Service Mode" of the Tv and change a few setting around, did it a few weeks ago and now my TV looks perfect, no reason to waster $1200 as sony is trying to get over on all us consumers.
Posted on Jan 02, 2009
  • ron in Jun 09, 2012
    how do you get into service mode?
Bad optical block, had the same problem with mine. Sony Service Tech told me it was the technology and that it was happening to his 50inch xbr set. Wanted like a $1200 to replace optical block. I decided to give it to my sister since it wasn't all that bad then and put that $1200 toward a new set. So the solution would be to replace you Optical Block within the TV also while you replace the block you should replace the lamp as well start off with a new lamp from the get go.
2 Suggested Answers
ctf1800
  • 4402 Answers
SOURCE: Sony KF60XBR800 Ghosting
yes send me your email address
Posted on Mar 26, 2008
Why am I getting ghosting on my monitor screen
It can be caused by several things, so eliminate the least costly first. If you have added a new peripheral to the PC or other electronic device near by, at about the same time the ghosting started, turn the device off and see if the ghosting goes away. If that is not the trouble try moving your monitor to the extreme right or left side and see if that effects the ghosting. Next try running the internal test on your video card. Next look at your settings in the control panel and set the options to default. If it is still ghosting try reloading the driver. Since you didn't give the make and model of the monitor or PC that is about all I can tell you.
Nov 03, 2014 | Lenovo Computers & Internet
3d ghosting
is the splitter rated for 3d??
Nov 17, 2013 | Startech VS440HDMI 4x4 HDMI Matrix Video...
Sony bravia 52 kdl xbr ghosting
Michael, does the ghosting go away of you tap the set? Or if you turn off the set and let it cool off and turn it back on, is the ghosting still here? One of the most common causes of ghosting or double image problem is due to a defective LCD panel tab. Sony's are known for this problem. I would recommend getting a diagnoses done on the set to be sure. If it turns out to be a LCD tab problem, the only true fix is to replace the panel.
Nov 24, 2012 | Sony BRAVIA Televison & Video
My Remington Noiseless 1939 typewriter has ghosting on the letter keys. I have put on a new ribbon but this just shows up the ghosting of each letter more than ever. I notice when typing the carriage
Could also be that your paper is too fibrous of finish. I found this page because my typewriter was ghosting, too. I adjusted some of the settings and there was not a trace of ghosting. I put the settings back and still no trace of ghosting. Then I realized that I tested for ghosting on paper that has a much smoother finish. I was ghosting on cheap paper we use here at work. So, I don't blame the typewriter. I blame the cheap paper. My typewriter just likes good paper.
Nov 14, 2011 | Office Equipment & Supplies
Ghosting on hdmi channel on my sony bravia
With HDMI there should be no ghosting. And being a Sony Bravia it should be no ghosting. My 52" Sony is great.
You've got connection issues.
Nov 25, 2009 | Sony Televison & Video
GHOSTING
go to image revison in menu and try. auto, 0, 1, 2, or 3 for best picture
Jul 05, 2008 | Sony Grand WEGA KF50XBR800 50" Rear...
Ghosting image after 3 years of perfect operation
ghosting is a memory problem, the monitor has a memory chip this helps with the video rendering to display the image, the chip can over time become damaged like any other memory chip, its its read use delete type but some times it can take longer to delete this then gives you the ghost shadow. it can sometimes be the software glitching, but there is no way to fix the firm wear on the monitor as the chip is pre programed before the monitor is assembled.
Aug 11, 2017 | Hyundai ImageQuest Q995 19" CRT Monitor
Sony Grand WEGA KF60XBR800 60" Rear Projection Television Logo
217 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
