C4380 HP Printer
It makes noise while printeing
  • nanceehop Nov 15, 2008
    I have the same problem- it prints fine, but when it runs, it makes a noise like it needs oil. Is this possible?
  • 628 Answers
Does it make noise when it first feeds paper or when the print module sweeps across? It's possible that there is some obstruction in the paper path or in the way of the print module. Is the noise constant or only when a certain action occurs? Let me know.
Posted on Oct 29, 2008
  • 233 Answers
SOURCE: hp laserjet makes a continuous screeching noise when plugged in and will not print.
remove cartridge, does it do it?
Posted on Jan 12, 2008
  • 1142 Answers
SOURCE: Can't scan on HP Photosmart C4380 even tho printing works fine
Try scanning without HP imaging software
HP Photosmart C4380 Direct Scan button doesnt function in VISTA
Use the built-in feature of the Windows operating system, called Windows Image Acquisition (WIA), instead of the HP software to scan. Follow these steps to perform a WIA scan.
  1. Make sure that the product is on and that the cable is correctly connected.
  2. Click Start , and then click Control Panel .
  3. Click Printers and Other hardware , and then click Scanners and Cameras .
  4. Look for an icon representing the product, and then review the following information for further instructions:
  5. Double-click the icon to start the Scanner and Camera Wizard . Follow the on-screen instructions to scan images or documents to the computer
  6. If the WIA scan was successful , use the Scanner and Camera Wizard to scan instead of the HP software. To use the HP software, continue to the next step to continue troubleshooting. However, it is not necessary to do so.
  7. If the WIA scan was unsuccessful , continue to the next solution.
  8. Fully uninstall and reinstall the HP software Follow these steps to completely uninstall and then reinstall the HP software. Step one: Uninstall the software Use one of the following methods to uninstall the software. Method one: Uninstall the software using the product CD If the product software CD is available, follow these steps to uninstall the software. Otherwise, skip to the next method.
    1. Insert the software CD into the CD-ROM drive on the computer.
    2. If the Welcome installation screen appears, click Exit to close it.
    3. On the Windows task bar, click Start , and then click Run (c01463550.gif ). The Run dialog box appears. Figure 4: The Run dialog box c01463551.gif
    4. Click Browse . The Browse window appears.
    5. Navigate to the CD-ROM drive that the software CD is in, and then double-click the drive.
    6. From the list of folders and files on the CD, double-click the Util folder.
    7. From the list of folders and files inside the Util folder, double-click the CCC folder.
    8. From the list of folders and files inside the CCC folder, double-click the Uninstall_L3.bat file or Uninstall_L3_64.bat if a 64-bit operating system is installed on the computer. The Browse dialog box closes, and the path to the Uninstall _L3.bat file appears in the Run dialog box. Figure 5: Uninstall file path in the Run dialog box c01463552.gif
    9. Click OK . The software uninstaller opens in a command prompt window.
    10. Press Enter to begin the uninstall.
    Method two: Download and uninstall the software If the software CD is not available, follow these steps to download the software and then uninstall it.
    1. Click here to go to the Software & Driver download page on the HP Web site .
    2. Type the product number in the search field, and then click Submit (c01425574.gif ).
    3. If necessary, click the link for the product model number.
    4. Click the correct operating system.
    5. In the Driver section, click HP Full Feature software/driver , and then click Download only .
    6. When the File Download - Security Warning dialog box appears, click Save .
    7. Save the file in a location that is easy to remember.
    8. When the file finishes downloading, double-click the file to extract it.
    9. Click Exit on the Welcome installation screen.
    10. On the Windows task bar, click Start , and then click Search (c01463553.gif ). The Search Results window appears.
    11. In the Search Results window, click All files and folders .
    12. Click More advanced options , and then select Search hidden files and folders .
    13. In the All or part of the file name: box, type Uninstall_L3 , and then click Search . When the search is complete, the file appears in the Search Results window.
    14. Double-click the Uninstall_L3 file, and then follow the on-screen instructions to complete the uninstall.
Posted on Oct 25, 2008
  • 32 Answers
SOURCE: HP Photosmart C4380 not printing
Is the printer connected to your system with a USB cable? If so, try these steps
Go to:
Start -> Run
type in "control" without the quotes, and hit OK.
Go to Printers & Faxes icon.
Find your printer, does it say "Offline" underneath it? If so, right click on it and hit Use Printer Online
Double click on your printer, there shouldn't be anything listed in the window that pops up. If there is, go to Printer at the top of the window and select Cancel All Documents. This should clear out the queue. If it doesn't, reboot. Sometimes it needs to be reset to clear everything out.
If that doesn't work, check the port:
Select your printer by right clicking on it and going to Properties (Last item in the list). Click on the Ports tab at the top. What is it set to? Generally, it should be USB001, maybe USB002. If it is set to LPT1, change this back to USB001. This is assuming you are using a USB cable. If it is connected with a Parallel cable, you'll choose LPT1.
If this is set correctly, try changing the port on the back of your computer that the printer is hooked up to. Try a different USB cable. Also try unplugging the power from your printer and plugging it back in. Maybe it just needs a good old fashioned restarting. Try restarting the computer, even.
Failing all this, I would try another USB device plugged into the same port with the same cable as the printer. If it works, you know the USB ports on your system aren't broken. In this case, it is most likely the printer itself and would need to be replaced.
Posted on Jan 06, 2009
  • 58 Answers
SOURCE: paper jam - hp c4380
Make sure that there is no paper stuck inside the paper, try cleaning the rollers, if the issue stil persit perform the below steps. Reset the All-in-One to the factory default settings by using these instructions: 1) Press ON and CANCEL buttons simultaneously 2) Display reads ?Enter Special Key Combo? 3) Press BLUE button, Green button and Grey button 4) Press Grey button continuously until "Resets Menu" is displayed. 5) Press Green button. 6) Press Grey button until "Semi full Reset" is displayed. 7) Press Green Button. This should resolve the issue.
Posted on Sep 27, 2009
SOURCE: My Hp Photosmart C4380 is working fine for
You need to install a twain driver. Try updating your printer driver software at the HP website.
Posted on May 04, 2010
I have an hp c4380 photosmart printer. It prints very slow. Please help.
Try different modes - fast, draft, set correct type of paper
Nov 20, 2010 | HP Photosmart 3210 Printer
HP Photosmart All in one Printer Wireless printing problem
try reset printer network settings and test again, and check for any high power electronics, nearby printer. because the magnectic fied is a wireless wall that reduces wireless signal.
Jan 03, 2010 | Xerox DocuColor 12 Printer
Does the computer make a 2 pitched noise when you put the USB cable in w/ the printer on?
Jan 06, 2009 | HP Photosmart C3180 All-In-One InkJet...
HP C4380, Wireless Printing Problem
Do you have other printer drivers installed, if so thre may be a driver conflict. wireless printing requires network connection and also printer drivers. This appears to be a driver issue since the printer shows up on the network. I would try reinstalling the drivers.
Aug 27, 2008 | Office Equipment & Supplies
Blurred printing
You should be able to re align the printheads using the software package on the computer which you installed whenn you installed the printer
Jul 22, 2008 | HP Office Equipment & Supplies
HP Photosmart C4380 All-in-One printer
check the ports first.. make sure that the printer is set as default ( make sure it has the green tick and the status "ready" or "online" on the printer icon in the printers&faxes. and if u want to connect it wirelessly, you have to install it as usb first before changing to wireless........
Jun 01, 2008 | HP Photosmart C3180 All-In-One InkJet...
296 people viewed this question
