posted by moozer on Sep 08, 2006
Water does not come out of the door. Push it and water drains out the bottom from somewhere. Help Lynn
Best Solution
posted on Nov 10, 2006
Sounds like the tubing coupling isn't connected any longer or broken. At the base of the refer you can pull off the grille area. Look for the plastic tubing down there, they usually have a coupling device for the tubing that comes from the frige to the tubing that goes up the door hinge area. See if that coupling is still hooked up keeping the two lines together. You can also use a flashlight to see where the water is coming from if you have someone else push the dispensor lever while looking under the refer. If those lines are unhooked just press the tubing into the coupling as far as you can, they grab automatically. To release a tube (if ever needed) you press the little ring down on the coupling and that will release the tube so you can pull it off.
Was this solution helpful? Show your Appreciation by rating it:
Suggest a new solution for this problem
Post a New problem for Kenmore 50522 / 50524 Side by Side
Email this problem
Email this problem
This Problem Also Relates To:
Coleman 5640B807 Compact Refrigerator
GE (PSS26MSRSS) Side by Side Refrigerator
GE GSS25JFPCC / GSS25JFPWW Side by Side Refrigerator
GE GSS20IEPWW / GSS20IEPCC Side by Side Refrigerator
Bosch Classixx KGV28323 Bottom Freezer Refrigerator
Electrolux 25.9 Cu. Ft. Side-by-Side Refrigerator with Thru-the-Door Ice and Water - Stainless-Steel
Haier (492420265334) Refrigerator With Ice Box
Can you Help with these Refrigerators problems?
Kenmore 50522 / 50524 Side by Side...
kenmore model #106 55522400
ice maker is making ice but not... Answer This...
kenmore mod.# 50522101
just bought used- plugged in... Answer This...
kenmore side by side
Refrigerator side is not... Answer This...
Refrigerator stopped cooling...
With no notice the whole... Answer This...
Kenmore # 50222000 Refrigerator...
The original defrost heater was... Answer This...
Repair Service
Find Refrigerator Repairman Near You:
Find Parts
