Receiver shuts off abruptly when loud sounds are heard.
My receiver abruptly shuts off when loud sounds are heard. For example; explosions or loud action scenes. When I turn it back on it says "Check SP Wires". I've checked every wire and they are not touching nor are they reversed. I've had the receiver for about 5 years and never had a problem before. I first thought the input selected had a problem but it occurs on any input selected.
  • 2 more comments
  • Christopher Parrillo
    Christopher Parrillo Oct 29, 2008
    The speakers were bought with the receiver. I just finished remodeling the room in which the receiver is in, making it more of a home theater, so i've been listening to movies and tv at louder levels. It seems shut off only after sudden loud bursts, like explosions.
  • danielcmasse Nov 28, 2008
    I have the same model and same problem. Moved unit around a bit lately to clean and it is now shutting off even when no loud noises.
  • savoiejoey Dec 26, 2008
    i have the same problem with a denon 789. after moving my speakers farther from were i sit.
  • Geddon Jan 30, 2009
    HTR-5860 that says "check SP wires" when you first turn it on. Fine at low volumes, but once the sound gets a little loud, it shuts off.
    Only started after system was disconnected and moved to replace the flooring in the room. Speakers are properly cabled to the system, there are no frays or stray wires anywhere. All speaker wires are "jack" style and patch into a wall plate .
    I thought it could be a power supply issue, any ideas?
Are they new speakers you are using? some receivers have a overload seting so you don't mess up or blow anything, sometimes this can interfear with your music, etc..
Posted on Oct 29, 2008
Hi, I have a Yamaha HTR - 6130 that seems O.K. until loud action scenes & explosions,then it shuts itself off.
There are two causes for this. One that there is a fault on the amp that is causing an overload circuit to trip and shut itself down. Or the settings of your speakers levels are wrong. So you are turning it up to hear the quiet parts of movies and therefore when louder sections come along your are driving the amp too much.
Some DVD discs that have THX on them have a sound set up on them. If you have one access the THX sound menu on the disc and adjust your speakers to produce the correct levels. If it does happen after that there's a fault.
By the way most of the George Lucas films (Star Wars) will have THX on them.
Aug 05, 2013 | Yamaha HTR-6130 Receiver
VSX 60 pioneer receiver shuts down on loud action dvd
Sounds like a bad speaker or speaker that is being over-driven.
Jan 09, 2013 | Pioneer Audio Players & Recorders
My Pioneer VSX-519V shut off after I setup my surround speakers ,I did a last test to be sure they were set correct ,I heard a loud pitch come from each speaker rather that the softer shhh sound ,my amp...
I'd disconnect the surrounds and try to bring up the receiver again. If it works you may have only cooked the surrounds. If not, you've possibly cooked the receiver. Disconnect all speakers and try again. If it still won't work then you need a tech to look at it.
What make/model speakers were you trying to set up?
Jan 16, 2011 | Pioneer VSX519VK A/V Receiver
My onkyo cuts off during loud sounds also. What can I do to stop
This seems to be a fault with your Amp,so needs to be replaced
Aug 15, 2009 | Onkyo TX-SR606 Receiver
Whenever a little bass sound - explosions, gunfire, helicopter blades, etc., ''PROTECTOR'' flashes on LED and shuts down receiver. Seems to happen more frequently lately. Subwoofer cable sturdy, no...
The protection feature on these units will shut off the receiver when there is too much power draw or when a speaker wire is touching another wire. First, check all of your speaker connections and make sure the wires are nicely twisted and inserted into the speaker and receiver with no stray wires touching. Secondly, if this doesn't correct the problem, try going into your speaker settings menu on your receiver and select "small" for each speaker. Let your sub handle the bass. The sub cable should have no effect on the protection feature of the receiver. The speaker wires, however, are the most common culprit of a receiver turning off (protector). Hope this helps.
May 03, 2009 | Sony Televison & Video
No sound from a yamaha AV receiver preouts connected to ext in
Do not use the ext in plug into the aux, or video input of the denon
Jan 28, 2009 | Denon AVR-3300 Receiver
Receiver Blinks PROTECT
how many speakers have you got on to it
Dec 07, 2008 | Teac AG-V8060 Receiver
My Onkyo Receiver TX 601 is turning itself off
Several things can cause this: Loud signal passages can momentarily draw high currents at the mains, especially if you have unit plugged into power stripe with other equipment. Or if unit is plugged into isolation transformer, current draw may exceed output of transformer. Too many speakers hooked to output or if one is bad (partially shorted due to overheating)
Apr 04, 2008 | Onkyo HTR500 Receiver
YAMAHA HTR 5660 MAKES POPING SOUND WITH LOUD NOISE AND BRIGHT LIGHT
Looks like you've got the best connection available - initially I thought it might have something to do with decoding the prologic signal from the analog input, but obviously not! And since you've got the audio separate from the video it is unlikely there is any interference from the video signal in the cable. Have you tried a different DVD player (I reckon that is most likely)? Also try connecting the video signal DIRECTLY from DVD to the TV if you aren't already doing so (you are anyway aren't you - the HTR 5660 doesn't have HDMI out does it?) Finally, if you have some spare cables around, try changing them - see if you get the same response when using component video cable instead of HDMI.
Jan 26, 2008 | Yamaha HTR-5660 Receiver
May not help, but I had the same thing when I turned up the volume.. off it went.. then I found my two surround sound speakers had the wires shorting. Looks like a safety switch if there is a problem. Could check if the wires are crossed, shorted, and/or thick enouch to handle the volume.. test it by just having the stereo speakers enabled. Cheers,
Jan 11, 2008 | Onkyo HTR500 Receiver
351 people viewed this question
 Grubhead
Grubhead
