Question about Yahoo Mail
E-mail address book
Cannot call in address book to forward e-mail to multiple addresses.
  • eggert Oct 30, 2008
    Nothing happens when I click on "Insert Addresses". Any other ideas???
    Scholar:
  • 89 Answers
Click compose to get to where you can write a message. Either click Insert Addresses, or click on the address tab you want to add addresses to (To: CC: BCC:)
Posted on Oct 30, 2008
  • dcomputerman Nov 01, 2008
    Have you switched from Beta to old version or vice/versa? Appears to cause some issues. Possible--do you have popups blocked? Set your blocker to allow popups for yahoo.com, see if that helps. Thanks
I want to delete my old email address and create a new one
Do not forget to place a mail forwarding on your old email address, or to not lose your contacts from the Address Book
Nov 12, 2016 | Computers & Internet
I have over 5000 of the same name in my yahoo contact list,unable to delete it or merge,there is no address,just name
Remove Duplicate Contacts from Yahoo! Mail
To remove duplicate contacts from the Yahoo! Mail address book:
  • Follow the Contacts link in Yahoo! Mail.
  • Select Tools ' Clean up Duplicates... from the toolbar.
  • Click a suspected duplicate.
  • Make sure all address book entries that do not belong to the one you're consolidating are not checked (for Merge this duplicate) under Duplicates.
  • Click Edit under Merge Preview to remove any extraneous data or make other desired changes to the newly merged contact.
  • Click Save and Next.
Using Merge all EXACT on the duplicates list, you can quickly eliminate any dupes that are precise copies without differences.
Jul 29, 2014 | Toshiba Computers & Internet
How do i send my yahoo address book to another yahoo e mail address book
Hello, To import your Yahoo! Mail address book, save your file as a Yahoo! CSV, Instructions are available at: http://help.yahoo.com/help/us/ab/impexp/
Nov 13, 2011 | Computers & Internet
I could not search my mail more then 10 mails how can i search my all mails
I don't know why you would have more than 10 e-mail address, but hey, to each their own.
Set up one email address in you e-mail client.
Go to you other address and just have them forward all their messages to the one address set up in the e-mail client.
You can have the client automatically sort the e-mails into folder according to the address it is coming from.
You can then have multiple SMTP servers set up so you can send responses from any of the e-mail accounts.
One thing to be careful of if you do this. You will not be able to simply hit "reply" in the e-mail client. That would simply send a message back to your first e-mail address and not the original sender.
Dec 06, 2010 | Computers & Internet
My "from" address is not stable
Dear Sir, First you will have to sure that you have received the mail through the comcast address...then if you go for reply or forward the same email address will pop up....Means on the basis of receiving address the mail address comes to forward/reply.....Another option you can use Just from Homepage after log in ...Click Options>Mail Options. than another page will open for account setting....Just click Mail mail options page will open....>From Management Coloumn Click Mail Addresses, there will be showing your email addresses those you listed to send and receive the mails from sender.Use the Add/Edit option to set your desired address to use as default email address ..Good Luck
Jul 31, 2009 | Yahoo Mail
How can I forward my gmails to multiple recipients?
To forward a mail to multiple recipients add addresses separated by commas.
Jun 20, 2009 | Google Gmail
Automatic address, compose, forward, does not work.
Completing addresses when addressing an email works a bit different as Outlook doesn’t have an AutoComplete feature but has an AutoSuggest feature a Check Names feature instead.
The subtle difference between the two is that the AutoSuggest feature doesn’t have a direct relation to your Contacts folder or other address lists configured in your Address Book. Instead, AutoSuggest uses a cache which contains a list of addresses that you’ve previously used.
Outlook also has another feature which is similar to AutoComplete; Check Names.
Check Names can work interactively and by default also works as a background process.
Check Names – Interactive
To use Check Names interactively, you type part of the name or address and then press the Check Names button on the Toolbar or Ribbon or press its keyboard shortcut (for most localized versions this is CTRL+K). This will search in your Address Book for that part of the name. If only a single address is resolved, it will directly show this in the To-field (or CC or BCC field). If multiple addresses are found, then it will prompt you with a dialog to select the correct address from.
Check Names – Background
When you only type part of a name or address and then switch to the message body, Check Names will perform a background search in your Address Book. If only a single address is resolved, it will autocomplete the address for you. If multiple addresses are found, it will underline the address with a red scribble line.
When you press the Send button while an address is not fully resolved, you’ll get prompted to select the correct address.
To turn of this background feature of Check Names go to;
Tools-> Options…-> E-mail Options…-> Advanced E-mail Options-> disable option: Automatic name checking
Apr 21, 2009 | Computers & Internet
Need to set up new Email adress
The only way to do that is to create the new e-mail account and let everyone know. There are multiple ways to do this.
One is that you can forward all your mail from your old e-mail address to your new one.
Another is that you can check your old gmail account in your new one. This one is a little more advanced and is not recommended if you are not planning on still using the old e-mail address in the future.
Another idea is to forward your old e-mail and set an automatic vacation response that sends back to anyone that e-mails your old account a message with your new e-mail address for them to change in their records.
Changing to a new e-mail address is a drawn out process that takes longer the longer that you've had your e-mail address. The good thing about gmail is there extremely high quota, which allows plenty of time for you to start using your new e-mail address without missing out from your old e-mail.
Feb 11, 2009 | Century Floodgate Bulk E-mail (2CM60001A1)
Address Book page does not open, whilst forwarding emails received.
Is this say yahoo mail?, outlook mail?, google mail?
Dec 22, 2007 | Computers & Internet
Yahoo Mail Logo
100 people viewed this question
Top Yahoo Computers & Internet Experts
micky dee
Mike
fixrfast
Level 1 Expert
Are you a Yahoo Computer and Internet Expert? Answer questions, earn points and help others
