Question about SAMTRON 55V 15" CRT Monitor
Problem In Control Panel
My SAMTRON monitor 56V is having a problem now.. The control menu of monitor settings which will appear when the monitor control panel is pressed(Brightness,Contrast....) is coming frequently at my monitor without activation... Now when the monitor is turned on, the control panel will come,and will not go even if we change the settings.. The control panel is switching between the CONTROL LOCK and UNLOCKED mode during each 5 seconds....So now I cant see anything on my screen at the middle of the screen due to this overlaying settings panel. I is giving the same effect as the Menu key is pressed in the panel..(exit,-,+,Menu). This problem started some 1-2 weak before.. Today I hav put some etylene cleaning solution through the gaps to clean from dust... still no change... If somebody having a remedy please help me.. Plz clear this problem
  • tinx69 Nov 28, 2008
    me 2 have the problem
Near microprocessor change c945b transistor, this may help u
Posted on Sep 15, 2006
Well this problem is almost seen in samtron 56v monitor. to ignore the control lock, u just need to follow the 10 steps that is given below... Step 1: Open the MY COMPUTER. Step 2: Open the C Drive, else the drive where u have installed the OS. Step 3: Open the PROGRAM FILES. Step 4: Open the COMMON FILES. Step 5: Open the MICROSOFT SHARED Folder. Step 6: Open the MSDESIGNERS98 Step 7: Go to RESOURCES Folder Step 8: Go to 1033 folder Step 9: After open the 1033 folder, relax for 5 minutes. Step 10: Now take deep breathe and close all what u have opened. I hope all your problem might have been solved. If still its not working..... kindly contact me at this no: 09447400011
Posted on Jul 21, 2007
2 Suggested Answers
SOURCE:
techman
  • 3130 Answers
SOURCE: Problem with Control Panel
It sounds like theres a front panel button that has become intermittant and making contact all by itself. Sometimes when you clean the screen, the cleaner will drip down between the crt face aqnd the cabinet and make the switch in front go bad. Im not sure if this is the case in your problem but its a start. If you didnt spill anything or drip anything into the front panel then your maicroprocessor could be causeing the problem, or the 5 volts that feed the micro could be noisy ie, bad filter capacitor in the power supply. Now as im sure your aware of the hi voltage inside these sets? Its best if you dont have the training to get a pro to assist you as this hi voltage can hang around inside the set even if its unplugged. Good Luck
Posted on Jul 03, 2006
Menu bar appears automatically in front of monitor and automatically uses it.
This problem started some 2-3 months before..
Sep 11, 2010 | Computers & Internet
Samtron 56v monitor control is locked
hold the menu button for 10-15 seconds.this shld unlock the menu. if the menu window still keeps popping up then u shld change either memory ic or power regulator..
Jul 17, 2009 | SAMTRON 55V 15" CRT Monitor
Control Lock Issue in Samtron 56V
d problem is in a transistor costing little, situated near d monitor's osd control ic (microprocessor), it is probably short....[refer the connection n area around the front panel cn connector and crystal clock generator]..beware u must b a professional
Jul 12, 2009 | SAMTRON 55V 15" CRT Monitor
To unlock your monitor, Press and hold the Menu button for 5 - 10 sec. and the OSD menu should be released.
May 27, 2009 | SAMTRON 55V 15" CRT Monitor
Monitor Problem
please clarify your problem.
what video card are you using??
Oct 22, 2008 | Computers & Internet
How to unlock control lock of samtron 56v monitor ?? plzzz tell me on my email ; kranthirj@yahoo.co.in
PRESS Menu button 30 sec (or) to remove Zener diode at front panel PCB (It is comming Main PCB to front pannel sacket nearby
Aug 14, 2008 | SAMTRON 55V 15" CRT Monitor
Samtron 56V monitor
Even i was also having the same problem. We can unlock the control lock by holding the menu button for 10-20 seconds.... But now my problem is the message "Controls locked/" appears continuously. Screen width also reduced. If anyone know the solution for this please help. thanks in advance.
Surya
Oct 16, 2007 | SAMTRON 55V 15" CRT Monitor
Samtron 56v
change the 5v regulator 7805 which is the supply for microprocesor
Aug 26, 2007 | SAMTRON 55V 15" CRT Monitor
Samtron 56v monitor user control locked
hi
press and hold menu button 20 seconds or up to till mesage show as control panel unlocked
V.Giridharan
Aug 15, 2007 | SAMTRON 55V 15" CRT Monitor
Jul 03, 2006 | SAMTRON 55V 15" CRT Monitor
SAMTRON 55V 15" CRT Monitor Logo
244 people viewed this question
Top Samtron Computers & Internet Experts
William Miller
William Miller
pankaj rautela
pankaj rautela
Richard Lilja
Richard Lilja
Are you a Samtron Computer and Internet Expert? Answer questions, earn points and help others
