Question about HP LaserJet 1005w Printer
Can't download driver for HP LaserJet 1005 Printer
I tried to download the driver for my HP LaserJet P1005 Printer from the HP website but it fails. At one point in the downloading, it asks me to click on "unzip" files, so I did so. It then says "unzipping" and asks me to wait, and after that it says "successfuly unzipped 62 files". And then the tiny window is closed. So aparently the downloading isn't finished but it stops downloading from that point !! Why does it do that ?
Thanx
  • 4 more comments
  • Nathgiord33 Oct 29, 2008
    Ok... I think I found all the folders... what should I do now ?
    (Thanks for your help !!!)
  • Nathgiord33 Oct 30, 2008
    There is no setup.exe file, but I see which one you mean. There are 61 others though ! They are :
    WinNTA4 vs1005.dll
    apptune ZGDI32.DLL
    apptune 5 ZJBIG.dll
    dour45w Zlang.dll
    dour46w Zlm.dll
    dour65w Zlmhp1.dll
    dour66w zPJL.dll
    fwdl zpp.dll
    hp1005A zpppcl.dll
    hp1005W ZPRINT32
    hpflash1 ZSHP1005
    HPlicen ZShp1005.dll
    HPLJ1005 ZSPOOL32
    HPLJ1005.DOI ZSPOOL.DLL
    IMF16 zstatus
    IMF32.DLL ZTAG32.DLL
    imfnt4.dll ZUNINST
    imfnt5.dll zUSB1005
    IMFPRINT.DLL zUSB1005
    pcldll6l.dll I hope you will be able to make something of this ... :S
    QDPRINT.DLL I will certainly give you a fixYa ! Thanx a lot
    read1st
    readme
    sd4
    SD4.DLL
    Sd32.dll
    SDDM32.DLL
    SDDMUI.DLL
    SDhp1000.DLL
    SDhp1005
    SDHP1005
    SDhp1005.UNZ
    SDIMF32.DLL
    SDNT5UI.dll
    SDNTUI.dll
    SDNTUM4.dll
    sihp1005.img
    spldr
    Sr32.dll
    SUhp1005.dll
    USBMON.DLL
    USBPRINT
    I hope you will manage to read them... The comment was too long so I had to put some next to one another, and write next to one too. Sorry about that.
    Ok... the Read1st is about :
    Contents
    1. Introduction
    -- Purpose of this Readme File
    2. Status
    3. Installation Issues
    -- USB CD-ROM drives
    -- USB mice with USB hubs
    -- Unpowered USB hubs
    -- Windows 2000 install fails with "function driver..." message
    -- Install always uninstalls
    -- Browse for install directory does not work
    -- Add Printer message "... printer could not be installed ..."
    -- Incompatibility with other printers installed on same LPT port
    -- Missing Required dll Error
    4. Printing Issues
    -- Printing double byte characters from Office 97 can cause a GPF
    -- Spooler32 Error
    5. DOS Printing Issues
    -- Write fault error
    6. Technical Assistance and Support Information
    -- Obtaining additional information from HP Services
    -- To obtain information via the Internet
    -- To speak with trained service technicians
    7. Legal Statements
    -- Trademark notices
    -- Legal Notice
    -- Copyrights
    And the "readme" one says it can't open Word 06 on this windows.
    My PC runs with Windows XP.
    Yes I'm quite sure...
    Actually, if you want to know the problem since the beginning, I was trying to download the driver because my PC doesn't have a CD player and I could therefore not use the setup CD. The 1st thing I tried to do was to use a friend's computer and put the driver on my memory stick and then in my computer. There, I found the setup.exe file. However, at one point in the setup, it says that it is looking for the printer (which I connected to my PC via the USB cable and which is well switched on) but it says that it cannot find the printer. This is strange because it does appear in the control panel. I tried to print the test page but it says that the printing failed (which is normal if the setup isn't finished). The 2nd idea I had was therefore to download the driver via the internet, to see if it worked better that way. But aparently it isn't working either...
    Sorry for this very long story !!! Do you have any ideas as to what I could do ? If nothing works I think I'm going to buy an external CD player and set it up normally.
    Thanks for all your help !
  • haldane Dec 20, 2008
    How to print from dos to a hp p1005 printer
    President:
  • 2,712 Answers
Most likely the files have been unzipped to a TEmp folder. You can do a search for these files, or alternately, make a folder on your desktop and change the destination of unzipped files to that folder. You could also try using the 'Classic" view in WinZip..
Posted on Oct 29, 2008
  • 3 more comments
  • Swilin Sampson
    Swilin Sampson Oct 29, 2008
    Most welcome!
    You should most likely find a file called setup.exe or something to that effect. Double click that file to run the installer. Make sure that your printer is not connected to the PC at this point. Plug in only when instructed to do so. Should you not find this file, please post the names of the files and folders here, so i can tell you which one to run.
    If you found the solution helpful, kindly give it a Fixya! rating. Should you have any further queries, please post them back here.
    Cheers!
    ID
  • Swilin Sampson
    Swilin Sampson Oct 30, 2008
    Hmm..those are all Dynamic link Library Files (DLL), but no executable (exe). Ok, did you read the read me.txt and read1st.txt files? they could give a clue as to what you should run. In the meantime, I will try to download the driver to my PC from the HP website and investigate. BTW, what OS are you using? XP or Vista?
  • Swilin Sampson
    Whoa! that is a 195 MB download from the HP wesite, and will take me forever...Did you read the two .txt files and see what they had to say?
  • Swilin Sampson
    Well, all i can suggest is try to download the file again. There HAS to be an .exe file, or else it cant be installed. Are you sure all the files have been extracted correctly to a specific folder, and not Temp?
  • Swilin Sampson
    Well, one thing I can say is that it is ALWAYS good to have CD player (preferably DVD) for your PC..always handy. They're not that expensive as it is, and are basically an essential part of any PC.
    Another thing. before progressing with any printer setup, it would be wise to unistall any instances of an older printer previously installed on the PC. You can do this through the Add/Remove programs on the Control Panel and also the Device Manager. Also, plug in the printer only when advised to do so during the installer program and not before.
    You could also try a clean install, which will avoid conflicts with other software during installation. Check these tips I posted:
    http://www.fixya.com/support/r545614-ins... (For XP)
    http://www.fixya.com/support/r643558-cle... (For Vista)
    (Just replace the word 'camera' in the tips with 'printers' ..procedure is the same.)
    But then again, you would still need the .exe file. Are you sure you downloaded the complete driver and not an update?
WHERE CAN I BUY A CD TO INSTALL A HP P 1005
You can download the HP printer drivers from their support WEB site. Please click on this link and select your model printer to download :- http://welcome.hp.com/country/us/en/support.html
Sep 04, 2012 | HP LASERJET P1005 Printer
I want HP LaserJet 1005 printer software
You can get the software from the following link:
http://h20000.www2.hp.com/bizsupport/TechSupport/DriverDownload.jsp?prodNameId=3435675&lang=en&cc=us&taskId=135&prodTypeId=18972&prodSeriesId=3435674
Sep 14, 2011 | HP LASERJET P1005 Printer
My hp 1005 cant be instaled on windows 7 32 bit ?? why ??? where i can found driver and software to solve this problem??? the printer worked fine on winxp
To properly install your HP Laserjet P1005 Printer on Windows 7 32 bit, you will have to download new drivers. You have two options:
  1. Option One: You can download the new driver as well as the corresponding software package here: Click Here.
  2. Option Two: You can download just the driver, but must follow a specific set of instructions if you do not want the accompanying software package. You can do this by going here: Click Here.
Hope this helps. If it does, please accept and rate the solution! Contact me with any more questions you may have. Thanks for using FixYa!
May 23, 2011 | HP LASERJET P1005 Printer
Good morning, I have an HP laserJet P1005 Printer, I have to install it but I do not thave the CD, please help to get the installation steps.
HP laserJet P1005 Drivers
You can download the drivers from HP Official Support for FREE.
Select the drivers according to the Operating System you have on your PC. Run the Installer and follow the on-screen instructions to install the printer.
Hope it helps! Good Luck!
CreativeTECH
Apr 15, 2011 | HP LASERJET P1005 Printer
How can i download a driver software from the internet for my hp laserjet p1005.
google it with the brand name and id.......you will have ur driver.
Feb 11, 2011 | HP LASERJET P1005 Printer
My brand new hp laser 1005 says out of paper and wont feed any of the paper through?
HP LASERJET P1005
PROBLEM: it was out of paper, new paper was installed, but printer wouldn't feed or print
SOLUTION: Lift the top cover of the LaserJet (where the printed paper would come out) and close it again. This resets the printer. Now the printer should feed and print again.
Jan 11, 2011 | HP Hewlett Packard LaserJet P1005 Printer
When i connect the printer hplaserjet p1005 using window xp it says usb device not recognised
This error gets due to of printer usb cable problem. If the cable is good, check your usb post, it means some voltage problem in udb port, last one drivers.
Try to download drivers from hp.com of other websites and in stall it.
http://go4download.com/hp-laserjet-1005-printer-drivers
http://h20000.www2.hp.com/bizsupport/TechSupport/DriverDownload.jsp?prodNameId=214539&lang=en&cc=us&prodTypeId=18972&prodSeriesId=240170&taskId=135
May 20, 2010 | HP LaserJet 1005w Printer
Need a driver for a HP laserjet HP1005 printer that works with MAC computers
Actually you three types drivers available for hp 1500 printers.
Basic drivers, full features Drivers, network Drivers. So the fluu feature software is comes with total features. You can download those drivers from below link:
HP LaserJet 1005 Printer Drivers
Nov 18, 2009 | HP LaserJet 1005w Printer
I'm trying to find the software to install hp laserjet p1005 printer on my laptop
http://h10025.www1.hp.com/ewfrf/wc/softwareCategory?product=3435676&lc=en&cc=uk&dlc=en&lang=en&cc=uk&submit=%C2%BB
Sep 13, 2009 | HP Hewlett Packard LaserJet P1005 Printer
HP LaserJet 1005w Printer Logo
2,626 people viewed this question
Ben Johnson
mukhtar21 shaikh
mukhtar21 shaikh
