Question about Food Mixers
Kitchenaid Classic -Mixer Head wobbles or shakes back and forth
I was told to tighten the screw that holds the hinge pin in place.
What other options do I have ???
This was a friends mixer and she said kitchenaid told her it sounded like an adjustment problem
  • 2 more comments
  • tom_gan Dec 10, 2008
    My wife seems to be experiencing the same problem, tonight she was making some baking with it and the thing was shaking and knocking around like crazy, googled the problem and found the screw on the bottom tighten trick, tried it and it is better but still knocking around a bit. It's like the locking mechanism isn't holding it solid enough?
  • alexandra7 Feb 14, 2009
    I am going crazy with this. I cannot stand and hold up the head of the mixer shile I mix, but this does solve the problem. It seems like the head falls down too far. I tried tightening the crew, loosening the screw, it still wobbles all over the place. Help!
  • Anonymous Mar 29, 2009
    Mine is doing the same thing. I called Kitchenaid and they said I have to have the pin replaced. From what I read it's 100 bucks to just have them look at it at the service center. Then whatever they charge for the parts and labor. I am really disgusted with Kitchenaid now. They do NOT stand behind their products anymore. I will not buy Kitchenaid again.
  • veronica turner Sep 07, 2013
    I have the same problem with a second hand mixer I bought but my mixer is a tilt head - I see 3 screws on the bottom of mine but they are tightened already as much as they can be. I can move the head of the mixer quite a bit without it being turned on just by moving it with my hand and it is getting so bad I am afraid to use it. I dont know how old the machine is but there is no locking mechanism for the head like they have now HELP
Lay the mixer on its side and look up through the base. You willnotice a small set screw. This holds the pin tight. If the set screw gets loose the pin willl begin to move out and the head will wobble. Simply tighten the set screw. I just did this to my Kitchenaid mixer 10 minutes ago and it now works fine.
Posted on Jan 13, 2011
  • 2 more comments
  • zxvsq Apr 06, 2011
    Also I discovered if you stand the unit normally and lift the mixing arm and look at the joint you can see a screw. It seems to be a spacer. Unscrew it until your beaters can clear the bowl when in use (mine were tapping the mixing bowl each rotation). The mixer should then rest solidly when down and no longer have that play in it which allowed it to be rocked back and forth. I did this and it is quieter and has less freedom to wobble.
  • wecoyote16 Jun 15, 2012
    Right on the money! Fixed the problem in seconds. Previously, I spent almost an hour on the phone with Kitchenaid c/s having me adjust the height of the beater in the bowl. That didn't do it!
  • Mark Bushby Jun 24, 2013
    Thank you. Fixed my baby exactly hype
    I do not see a set screw - there is a nut that has a spring behind it which will not move and 3 screws right on the bottom that are that tight I cannot move them I dont know what to do, getting ready to throw this in the trash
Turn the unit upside down and tighten the screw under the drive, this solves the shaking
Posted on Mar 09, 2010
Possible solution... with my wifes I guess there is an adjustment screw for the head to raise up/down located in the neck behind the top of the bowl, my wife was tweaking while I was google'in and she said the mixer was actually making contact with the bottom of the bowl and lifting the head slightly as it was turning (I would've guessed you'd hear that but...?) anyway my wife said she raised the head slightly and now between that and tightening the screw on the pin it's running pretty smooth.
Posted on Dec 10, 2008
    New Friend:
Yes I agree. Run the mixer dry on a low speed with the balloon whisk attached. Is it brushing the bowl? If so switch off, tilt the head back, and expose a screw in the neck. Turn this anti-clockwise maybe quarter a turn, then reset and try again. Hopefully the head unit has raised sufficiently for the whisk to be running free. If not keep adjusting til the whisk turns freely without striking the bowl.
Posted on Jun 24, 2013
    what do you do for a lift bowl model?
  • Vince Birth Nov 23, 2013
    Turning the screw under the neck counter clock wise does fix the problem as it raises the head up. The reason it shakes is because the head is tilted down and the whisk attachment is banging the bottom of the bowl making it shake.
My kitchen aid stand mixer startnig making noise and wobbling. I noticed that the pin attaching the top to the base has been pushed out halfway and I can't push it back. Any solutions?
Remove the bowl, turn it upside down on a towel, look up inside the pedestal. Right in the middle where the hinge pin goes through there is a screw, unscrew it a little, push the hinge pin back to where it belongs and then tighten the screw up tight. Turn mixer up the right way, raise head up, fit bowl & flat paddle. Lower head & turn machine on low, listen for paddle tinging on bowl, if it is touching turn off and raise the head. Look into hinge area from the front, that screw is the head height adjustment. Clockwise to lower paddle in bowl, anti clockwise to raise. You want to lower it until you hear the paddle tinging on the bowl & then raise it enough to clear without tinging. You don't wind the screw in & out huge amounts, 1/4 to 1/2 a turn at a time is plenty.
Dec 14, 2014 | KitchenAid KITCHEN AID 5 Quart Artisan...
Why
If you turn the mixer upside down, you will be able to see a locing screw which holds the hinge pin in place.
Center the pin and tighten the screw.
May 09, 2014 | KitchenAid Food Mixers
Hinge pin came out from head of mixer and can't put it back..will only go through part way.
did you turn your mixer over and unscrew the set screw on the hinge shaft before trying to put back in? there is a small set screw that holds the hinge pin in place during normal operation. the screw sometimes comes loose and the shaft will vibrate out of it's normal operating position but when you try to push it back in the screw now stops the hinge shaft from going in, You have to turn the mixer upside down and look into the base cavity and you will see the set screw in the middle. Loosen first, return hinge shaft to normal operating position and the re tighten the setscrews, you can be firm with this screw, let us know if this helped
Feb 06, 2013 | KitchenAid Artisan Series Tilt-Head Stand...
On my Kitchenaid Artisan mixer the 3" silver rod fell out the back. How do I slide back in?
I an sorry but the only Rod in the back of a K45SS is the pivot hinge pin that holds the motor head onto the base. if it fell out then the answer is simple. Turn the mixer upside down and wiggle the base while sliding the pin back in. Once the pin is back in place, there is a set screw in the middle of the shaft that you can see while you are replacing the pin, turn this back down with a flat head screwdriver untill it is firmly against the hinge pin. The culprit of the problem is this set screw. It came loose and allowed your hinge pin to vibrate out and then fall down or fall out as you said. once the set screw is back in place you will be fine. To avoid this problem in the future you might remove the screw entirely and put a drop of "Lock-Tight" on it that will help hold the setscrew in place for a very long time.
Dec 11, 2012 | KitchenAid K45SS Classic Stand Mixer
We have model # KSM90WW. The problem is that the mixer portion hangs down too far into mixing bowl, thus making the mixer "buck" when mixing. Have tried to tighten everything that can be...
Till the top back and look into hinge area. You will see a large set screw that controls how far the head drops. Try turning the screw counter clockwise 1/8 of a turn.
Feb 18, 2011 | KitchenAid Classic Stand Mixer
The top part of the mixer has about 1/2 inch play and must be lifted in order to put in lock position
It sounds like the bar that the head hinges on has come out. It is located on the base and should be flush with the side of the mixer on both sides. Just knock it back into position and then turn the mixer over to tighten the screw that holds the hinge pin in place. It might also be that you need to adjust the height of the head by turning the adjustment screw on the hinge. Lift the head and the adjustment screw should be visible.
Jan 28, 2010 | KitchenAid KSM90 Ultra Power Series Stand...
The head has a lot of play and the mixer attachment scraps the botton as it turns
It sounds like the pin that holds the head on is not in the correct place. IT should not stick out on either side, if it is, knock it back so it is flush with the sides. Turn the mixer over and tighten the screw that holds the pin in place.
The second problem is that the head is too low. This can happen over time. There is a screw that can be accessed when you lift the head up. It is in the middle of the hinge. Adjusting this will lower and raise the head position when the head is lowered back into place.
Jan 24, 2010 | KitchenAid KSM90 Ultra Power Series Stand...
Mixer head is wobbles. is there a way to tighten it?
I am guessing you have a model where the head tilts back. There is usually a pin that runs through the base and head hinge. Check that this is centered and not sticking out on one side. If it is, knock it back so it is even then tighten the screw underneath that holds it.
Jan 23, 2010 | KitchenAid Food Mixers
This may have a simple solution: This sounds like an issue of beater to bowl adjustment, which can come out of alignment naturally over time and with use of the machine.
If the flat beater is striking the bottom of your bowl, this may cause the locking mechanism to loosen and may cause the mixing head to "bounce" during use.
Your Use and Care Guide will cover the "beater to bowl adjustment," which you can do at home in a few minutes with a flathead screwdriver.
If the beater to bowl adjustment quickly comes out of alignment, you may need to seek service. You may find a Kitchenaid certified service location locally at the following website:
http://caservice.kitchenaid.com/
Dec 14, 2008 | KitchenAid KSM90 Ultra Power Series Stand...
Kitchenaid Mixer head wobbles bad
The solution provided by luannej is useful only if your mixing attachment is striking the surface of the bowl. By adjusting the screw located at the junction of the head and base, you are actually controlling how far the head is allowed to tilt forward and, thus, the height of the attachment above the bottom of the bowl. Although the attachment striking the bottom of the bowl will lead to wobble (and noise!), it isn't usually the root cause of the wobble. In fact, the wobble may be causing the bowl strikes and adjusting the head height only hides the problem.
The head of the mixer is secured to the base by a large steel pin. Any play between the head and base comes from this hinge and its resulting tolerances. To "tighten" the sloppy tolerances causing your wobble, follow these steps: 1) Lock the mixer's head down and turn the entire mixer upside down. 2) Looking deep into the hollow base, find the small slotted set screw. This screw actually presses against the pin and takes up the slop between the head and pin. Note that this screw is not the large slotted screw I mentioned earlier visible when you tilt the head back. 3)Tighten the small set screw as much as you can. Your wobble should be greatly reduced or eliminated now. 4) Lastly, you may want to readjust the large screw controlling the head's tilt to optimize the distance between attachment and bowl. Hope this helps.
Oct 24, 2008 | KitchenAid Artisan Series Tilt-Head Stand...
Food Mixers Logo
7,375 people viewed this question
Top Food Mixers Experts
Oscar Netto
Oscar Netto
Are you a Food Mixer Expert? Answer questions, earn points and help others
