how much it will cost me to fix white plastic in a slot between card slot and battery of nikon coolpix p4. thanks
Comments:
Dec 15, 2008
- thanks a lot mate for ur suggestion may be it will be helpful in future. at the moment i got it repaired from nikon service for 39 pounds including vat. anyways thnx
-   The small plastic piece fell out and camera will not turn on. I understand the principle behind this little piece as the camera becomes active once the battery door is closed, however, this appears to be a more common problem and Nikon should be offering a free "fix" for this. Alas, I've seen nothing on this and the initial warranty has run out. I've been quoted $120 to have it repaired... which is absolutely ridiculous. I love the camera, but loathe this design flaw. Anyone find a solution?-   VOLS85
Ok, I Joe McGee'd the issue -- take a small piece of tin foil -- make it fit the hole area. Insert it and poke it into each open "port" on both side -- pack it in with a pin --
Mine is working fine now -- not sure how long, but it works.
a white piece fell out from the spot next to the memory chip of my Nikon coolpix P4 camera, now the...
(More)
a white piece fell out from the spot next to the memory chip of my Nikon coolpix P4 camera, now the camera will not turn on, can you tell me what this piece is for and if my camera can be fixed, thanks
When power turned on , the message "lens error" appears in the lcd screen . I've tried...
(More)
When power turned on , the message "lens error" appears in the lcd screen . I've tried leaving the battery out for a few days , but the problem persists- Any ideas
