Xerox Phaser 7760DN Laser Printer Logo
Anonymous Posted on Feb 28, 2012
I print artwork (cards) on 250gm xerox silk paper. I'm getting faint streaks developing down the A4 print, starting on the left side, if I print more than 5 copies at a time, if I set to print 20
If I print 1 sheet at a time then quality is perfect, up to 5 sheets the 5th is slightly streaked, but hardly noticeable (streaks are white as in less/no toner by the way)
Tareq Bin Mostaq Mostaq
Level 3:
President:
  • Xerox Master 1,449 Answers
  • Posted on Jun 24, 2012
Xerox Master
Level 3:
President:
Answers
1449
Questions
31
Helped
614134
Points
3628
Problem on your printer fixing unit.Its muddy in wast toner.Need service this printer.I hope fix your problem
5 Related Answers
Anonymous
  • 18 Answers
  • Posted on Nov 23, 2007
SOURCE: Xerox phaser 7760 streaking
to fined out what the problem could be you need to open a word doc and sent a blank page to the printer. from this it will show where the problem is in the printer
if u still get streaking it couls be a faulty toner and it may not be the cyan toner either. i would give the fuser unit in the printer a check. if there marks on tthis unit i can cause this problem as well
Anonymous
  • 208 Answers
  • Posted on Dec 20, 2007
SOURCE: Streaking Printer
On that product, it is just as likely that a single color drum is bad. Not the developer. That is a more likely problem then the developer.
Anonymous
  • 2072 Answers
  • Posted on May 30, 2008
SOURCE: Xerox Phaser 8400 Streaking
You can go into the trouble shooting menu and do the "eliminate Light stripes" procedure a few times.
Then you can do Jet substitution from the same menu.
If that does not work then most likely you need a new print head.
If you have used non xerox ink sticks that is your most likely cause of the problem. cheaper is not always better
Anonymous
  • 2072 Answers
  • Posted on Jan 19, 2010
SOURCE: xerox phaser 8860 light streak in cyan color field
On your panel, scroll to troubleshooting, then to something that states something like adjust image quality or repair image quality.
You are looking for a procedure called simply "remove light stripes, and also remove smears and streaks. Run those and they should clean your jets and resolve our problem.
PRLandreth
  • 17 Answers
  • Posted on Apr 03, 2010
SOURCE: xerox phaser 7400 I'm getting large black streaks
That would be the drum 99% of the time. A fuser is what heats up the paper and the toner so it will stick properly. If it is "smudging" then its the fuser. But is it is lines sometimes with dots in them that is a bad drum.
Hello, i have a Xerox Phaser 6110 printer, with printing streaks.how can i get ris of them ?
Try this link:
https://www.support.xerox.com/support/phaser-6110/support/enus.html
Xerox is printing pages with a red line down the left side
Streak in only one color:
Check the condition of the print cartridge, and replace as necessary.
Verify that the print cartridges (C/M/Y/K) are genuine Xerox cartridges,
and replace if necessary.
http://download.support.xerox.com/pub/docs/6180MFP/userdocs/any-os/en/user_guide_en.pdf
Prints a light gray streak down the left side of paper
either the drum developer or fuser if you can show me a sample I can tell you which it is
I have a Gestetner DSC224 copier/printer that has started to output poor copies and prints. Documents come out of he machine with horisontal blank/unprinted streaks across the papers - in my case mostly...
Watch the development stations to see if there are white lines that match. The stations are easily removed from the left side. If so, stir vigorously the station and manually turn the developing roller
2answers
Ricoh Aficio 3800C: How do you clean the Development Unit Hello, I have a Ricoh Aficio 3800C. I noticed that there are faint Cyan streaks when I print. I opened up the printer/copier unit and looked at...
I believe what you are referring to is the drum inside the toner cartridge. The drums are usually very strong colors, blue or green and if it is streaking then the drum cleaning blade has failed on the inside and you need to replace the cartridge.
1helpful
Is it canon laser LBP 3300 printer take Legal Size printing ?
Here are "little" specification:
Body installation method desktop page printer
Photosensitive medium OPC drum
Exposure method semiconductor laser
Development method Toner projection development
Transfer method by roller
Separation method by curvature
Cassette pickup method by pad
Multifeeder pickup method by pad
Drum cleaning method by blade
Fixing method on-demand
Delivery method face-down/face-up
Toner supply type by toner cartridge
about 6000 prints (A4, single-sided; at 5% image ratio)
Warm-up time in standby: 0 sec (at power-on: 10 sec or less)
Print area top: 5 mm; bottom: 5 mm; left/right: 5 mm (if envelope, top, bottom, left,
right: 10 mm)
Printing resolution 600dpi
First print time 9 sec or less (approx.; A4)
Print speed (A4) 21 pages/min (approx.)
Cassette paper size A4, B5, A5, Legal, Letter, Executive
Multi-purpose paper size A4, B5, A5, Legal, Letter, Executive, Envelope DL, Envelope COM10,
Envelope C5, Envelope Monarch, Index Card, Custom Paper Size (width
76.2 to 215.9 mm, length 127.0 to 355.6 mm)
Cassette paper type plain paper (64 to 90 g/m2), heavy paper (91 to 120 g/m2), recycled
Multi-purpose paper type plain paper (64 to 90 g/m2), heavy paper (91 to 163 g/m2), recycled
paper, transparency, label paper, envelop (DL, COM10, C5, Monarch,
B5)
Cassette capacity 250 sheets (approx.; plain paper, 64 g/m2)
Multi-purpose capacity 1 sheet
Delivery tray stack 65sheets (Face-down) /1sheet(Face-up Output Slot)
Memory 8 MB (internal; no optional memory available)
Operating environment
(Temperature range) 10 to 32.5 deg C
(Humidity range) 20% to 80% RH
Noise 52.8 dB or less (during printing; based on ISO9296; announced noise
emission)
Power supply rating AC100V±10% (50/60Hz ±2Hz)
Power consumption (Maximum) 790W or less (approx.; 20 deg C; for input of rated power supply;
including peak value lasting 1 sec or more)
Dimensions 370 (W) x 375 (D) x 258 (H)mm
Weight printer: Approx;11kg; toner cartridge: Approx,0.8kg(2.5K)
Option paper feeder
2answers
Phaser 3200 mfp laser printer leaves streaks on paper. First sheet is okay then rest get worst as printing continues.
One of two things.
If the streak is a line. No visible print in the streak, Then most likely the drun cleaning blade is bad and the drum unit will have to be replaced.
If the streaks are sort of reprint. a faint reprint of what is already on the page, then you need to replace the fuser.
Yellow not printing - but only in streaks
Your yellow problem sounds like a bad yellow developer housing. Take the drum out and look at the developer housing, You will need a flash light to do so. See if the roller is solid yellow. Even if it is there may not be any developer left in the housing.
The Cyan sounds like the drum since it gets worse as it prints.
That can also be caused by the transfer belt cleaner. But that normally is the opposite. It has a rainbow sort of streak and it gets better as the machine runs.
Top Xerox Office Equipment & Supplies Experts
ZJ Limited
ZJ Limited
Grand Canyon Tech
Grand Canyon Tech
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
