Question about HP LaserJet P2015dn Printer
Cannot connect to the device
My printer has a light on "paperjam" , but there is no jammed paper anywhere. I tried to turn it off and on and also restart my computer. Re-install and update the driver. Still the same and says "cannot connect to the device", but all powercords and cable ports are intact correctly. I do not know what to do next.
  • Anonymous Oct 30, 2008
    Paper jam is on but no paper is jammed
  • 66 Answers
Hi,,
try to locate the fuser assembly at the back of your printer sometimes a piece of paper can also cause a paper jam.when you saw it just pull it slowly and also try to check the sensor if its good position...
hope this would help you..
Posted on Oct 30, 2008
Paper was jammed and now removed light still flashing paperjam
If you pay my papal account than I solve your problem.
xptareq2000@yahoo.com this email address is my apypal
Aug 23, 2012 | Sharp AR-150 Toner
I had a paperjam. I successfully removed the jammed paper, but now the screen still says that I have a paperjam and won't allow me to use my printer
If you haven't already try removing the power cord from the back and wait 10-15 seconds and that will allow it to reset. Let me know what happens!
Jun 10, 2011 | Office Equipment & Supplies
Every page i try to print is says i have a paperjam clear the jam and press enter so i clear the jam and press enter nad it prints and then says exactley the same with every page i try to print and there...
First, lift the top of the printer up past the sensor. This usually resets it or try turning it off, waiting a minute or two and then turning it back on. If this doesn't clear it and it the paper doesn't move through the printer straight, there is a small torn bit of paper somewhere that must be removed. Good Luck!
vicki.velaz
www.togohair.com
Hair, ready to go, ready to wear!
Sep 21, 2010 | HP OfficeJet 6110 All-In-One InkJet...
I have a paperjam on my colour laser printer CLX 3170 and I dont know how to get to the paperjam inside the machine
Step 1
Turn the printer off and on to see if it can automatically clear some or all of the jam. Many printers provide an error-code listing on the front panel display for the area where the jam occurred. If your printer shows an error code, be sure and check the printer manual to see if that identifies the area of the printer where the jam occurred.
Step 2
Turn off the printer.
Step 3
Remove any paper trays. Inspect them for wrinkled or damaged paper.
Step 4
Open any other doors that give access to the printer's paper path and to the toner or ink cartridge.
Step 5
If necessary, remove the toner or ink cartridge. Place it in a bag or away from light to avoid damaging it.
Step 6
If you find a piece of jammed paper, remove it by holding it with both hands and pulling firmly. The goal is to keep the paper from tearing. If several pieces are jammed together, try pulling out the middle piece first to loosen the jam.
Step 7
If the paper does tear, try rotating the roller gears manually to free the paper. Don't force anything, though.
Step 8
Replace the toner or ink cartridge and paper trays, close any doors you opened and turn the printer back on.
Step 9
If the printer paper jam message still appears, then there is still some paper in the printer. Inspect the paper path once again.
Feb 19, 2010 | Samsung CLX-3175FN Color Laser All-in-One...
Getting the message "241 Paperjam Check Tray 1" I've checked tray 1 and have not found a paper jam
Turn the printer upside down and shake to find any paper jam as in most cases you will find some paper or dust falling out and then try.
Jan 26, 2010 | Lexmark T630 Laser Printer
Says paper jam but NO paper is in the machine
One problem i found with those printers is that over time the casting around the paper tray is wearing off and printers starts to show paperjams when there is no paperjam.
One way to fix is try and positions the paper tray better or perhaps raising it a bit with piece of wood or paper.
Cast unfortenately is too expensive to replace so if this doesnt work and you are sure there is no paperjam and nothing obstructing the sensor then replace the printer.
Nov 02, 2009 | HP LaserJet 2200D Printer
CLX 2160 - paperjam
There is probably a jam in the paper feed area. Pull the paper tray out and stick your hand in to find and remove any paper stuck there. Then reinstall the paper tray and open and close the front door of the printer. The jam should be cleared.
If it is still showing paper jam, pull the tray out again and look to make sure you didn't miss any paper, then check the other areas of the printer (starting with the exit area) for paper.
Oct 24, 2009 | Samsung CLX-2160N All-In-One Printer
Canon irc3380i paperjam
This problem fault manual presenting the track. Follows to consider several reasons. Check the condition rubber roller seizure of the paper. Check and clean lower brake platform. Check and value the possible ragged sheet of paper. Check presence a stranger subject in giving device. Try to give the paper along on format by narrow side. Thank you, good luck!
Sep 16, 2009 | Canon C2058 Color Copier
Laser Jet 4200 Main Motor doesn't spin
Remove tray 1 feeder assembly and check the paper flag sensor. It's probably jammed. Free it up with your finger.
Mar 20, 2009 | HP LaserJet 4200 Printer
HP LaserJet P2015dn Printer Logo
159 people viewed this question
Ben Johnson
