Question about SuperMicro X7DAL-E Motherboard
X7dal-e pci express
Is there a problem with the PCI-Express interfaces on this board that would casue the computer to crash when I perform a particlar action on one of my PCI-Express cards
    Champion:
  • 261 Answers
The problem is not the board, it is the implementation and the limit of the PCI-e lanes in the CPU.
Solution, Do not use slot 4.
For add in cards use old PCI-X cards at 133MHz.
They are cheap used, 64 bit, and are 8 times faster than PCI.
Posted on Jul 03, 2015
5 Suggested Answers
Saigua
  • 981 Answers
SOURCE: PCI Express slot, eight beeps
Yeah, but it's not the slot; it's the northbridge chipset or a PCI bridge driving it that's perhaps overheated or set funny.  If you use 2 CPUs they can fall out of step several ways, or your clock circuits can age badly by themselves!  Got fresh CMOS batteries in there?  It could be that PCIe was merely asked to run at a frequency it won't run.  You should carefully make sure the board is nice and clean, reflash or at least clear settings on the BIOS, confirm the PCI videocard boots, make sure all the chips are cooled well, and again see if you can get a PCIe card to work without complaint.
Posted on Sep 10, 2008
preachw996
  • 1179 Answers
SOURCE: msi k8neo4 platinum mainboard pci express support
No. There is no software to change pci-e speeds. You would need a board already set up for pci-e2 to get the top speeds. Most pci-e2 graphics cards are backwards compatible but they will run at the slower speed. Hope this helps.
Posted on Dec 24, 2008
dwane4444
  • 219 Answers
SOURCE: I have a msi ms-7399
Looking in the net I found someone running an E8500 on this board so I guess an E8400 will work fine.
Posted on Oct 30, 2009
  • 67 Answers
SOURCE: Acer EG31M R01-A3 PCI Express spec
The pci-e bus lane should be 16x
Posted on Jan 28, 2010
Use of PCI-e x16 slot for non-video card
...........................................!O_O!...........................................................
WHY would you want to do that?
There is a PCI-Express x1 slot on the motherboard.
Black in color, and in-between the black PCI-Express x16 slot, and a white PCI slot.
Use the PCI-E x1 RAID adapter card in the PCI-E x1 slot, and a PCI-Express graphics card in the PCI-E x16 slot. Sheesh!
A PCI-Express slot is not an evolved PCI slot.
Completely different technologies.
PCI uses a shared Parallel bus architecture, while PCI-Express is based on Serial point-to-point.
So your idea of how to 'fix' your problem, is to use a PCI-E x1 card in a PCI-Express x16 slot, and a PCI graphics card in a PCI slot?
Completely backwards.
http://en.wikipedia.org/wiki/File:Motherboard_diagram.svg
PCI-Express x16 slot uses the same lanes from the Northbridge, as the OnBoard video?
UTTER NONSENSE!
The Northbridge chip handles the Faster capabilities of a computer.
Handles the Processor, Ram Memory, and HIGH-SPEED Graphics.
HIGH-SPEED graphics is the Accelerated Graphics Port (AGP) technology, and the PCI-Express technology.
The Southbridge chip handles the Slower capabilities of a computer.
The PCI bus is one of those slower capabilities handled by the Southbridge chip.
The PCI bus is also a shared bus. This slows data down.
The AGP bus, and PCI-Express bus are Not shared. They also have a direct link to the Northbridge chip.
The PCI Bus has to go through the Southbridge chip, which has to go through the Internal Bus, THEN to the Northbridge chip.
OnBoard video, or Integrated Graphics, uses the PCI bus.
When you inserted the PCI-E x1 RAID card in the PCI-Express x16 slot, and a PCI graphics card in the PCI slot, BIOS just assigned another IRQ for the PCI-Express x16 slot.
(Interrupt Request)
No fancy technology going on there.
Backwards technology going on with a PCI-Express x1 card in a PCI-Express x16 slot, though.
I do not concur, and do not think that is a good solution, Kevin.
Regards,
joecoolvette
Aug 24, 2012 | Gateway Foxconn C51GU01 Motherboard
What type of video card can I use on this motherboard? D945GZIS AGP? PCI? PCI EXPRESS?
Your MoBo has (1) of each PCI Express x1 & and PCI Express x16 slots, and (2) standard PCI slots. There are NO AGP bus slots on this board. You'd want to use buy a PCI Express x16 video card instead of a PCI video card due to the better performance offered by the PCI Express cards.
The full details of your motherboard are below:
Product Description The Intel Desktop Board D946GZIS delivers an integrated graphics solution in the Essential Series by combining exceptional value with quality and reliability and supports Intel Core2 Duo, Intel Pentium D, Intel Pentium 4, and Intel Celeron D processors with 1066/800/533 MHz system bus in the LGA775 package. This board features a PCI Express x16 connector, integrated 10/100 LAN, dual-channel DDR2 memory, Intel High Definition Audio (Intel HD Audio) and up to eight USB 2.0 ports.
Processor Model: D946GZIS Chipset Type: Intel 946GZ Express Processor Socket: LGA775 Socket Installed Qty (Max Supported): 0 ( 1 ) BIOS Type: Intel Storage Controler: ATA-100
Memory RAM Installed ( Max ): 0 MB / 4 GB (max) Supported RAM Speed: PC2-4300, PC2-5300 RAM Features: Unbuffered, dual channel memory architecture
Audio Audio Output: Sound card Sound Output Mode: 5.1 channel surround Compliant Standards: High Definition Audio
Expansion / Connectivity Expansion Slot(s): 1 PCI Express x1, 1 PCI Express x16, 1 processor - LGA775 Socket, 2 PCI, 2 memory ( 1.8 V ) - DIMM 240-pin Interfaces: 4 x Hi-Speed USB - 4 pin USB Type A, 1 x serial - RS-232 - 9 pin D-Sub (DB-9), 1 x parallel - IEEE 1284 (EPP/ECP) - 25 pin D-Sub (DB-25), 1 x display / video - VGA - 15 pin HD D-Sub (HD-15), 1 x network - Ethernet 10Base-T/100Base-TX - RJ-45, 1 x audio - line-in - mini-phone stereo 3.5 mm, 1 x audio - line-out - mini-phone stereo 3.5 mm, 1 x microphone - input - mini-phone 3.5 mm, 1 x storage - floppy interface - 34 pin IDC, 1 x keyboard - generic - 6 pin mini-DIN (PS/2 style), 1 x mouse - generic - 6 pin mini-DIN (PS/2 style)
Nov 03, 2010 | Intel D915GAV Motherboard
Type of video card
The Compaq Presario SR1630NX desktop computer, has a PCI-Express x16 slot on the motherboard, for a PCI-Express graphics card.
The Presario SR1630NX came out in 2005.
PCI-Express 2.0 technology came out January 15, 2007.
The Presario SR1630NX uses the PCI-Express 1.1 technology.
You can use a graphics card based on the PCI Express 2.0 technology, however.
PCI Express 2.0 is Backward Compatible with PCI Express 1.1
You just won't get the full capability, of a graphics card based on the PCI Express 2.0 technology.
Will you notice?
NO
May 24, 2010 | HP Compaq Presario SR1630NX PC Desktop
How can i tell the difference between pci slots and pcie slots
The Peripheral Component Interconnect or more commonly known as PCI is a standard for connecting a lot of devices inside your computer to extend its capabilities. Devices like sound cards, modems, NIC, TV Tuners, and some video cards have at some point or another have used the PCI port.
PCI express ( PCI-E ) is a much improved version in terms of speed. PCIe uses a serial interface instead of the old parallel interface used by PCI. It also utilizes individual buses for each of the devices connected to it instead of a shared one like what PCI uses. The difference in speed is quite huge when comparing the standard PCI slot which runs at 133MB/s to a 16 slot PCIe that can send or receive up to 16GB/s.
The most common use for PCIe nowadays is with graphics cards which benefits hugely from the huge bandwidth provided by the interface.
1. PCIe is much faster compared to PCI.
2. PCIe uses a serial interface while PCI uses a parallel interface.
3. PCIe speed is classified into lanes, each capable of delivering up to 1GB/s data transfer.
4. PCI slots are standardized while PCIe slots vary depending on the number of lanes the slot is intended for.
5. Despite PCIe superiority, most manufacturers still use the PCI standard for their devices.
Unlike PCI slots which are the same size for all devices, PCIe slots can differ depending on which form factor it accepts. The longest would be the 16 lane slot and understandably, the shortest is for the x1 devices.
I hope this much information is enough for you to understand the difference between both of them. If you need any more help let me know.. !
May 13, 2010 | Dell Dimension 3000 PC Desktop
Will these graphic card work on my pc
yes, it will all works for your computer as long as the graphics card you mention have a PCI express interface in order for it to fit into the PCI express slot.
hope this could help you!...:-)THANKS..
Dec 23, 2009 | Computers & Internet
About graphics card slot..
The board has a pci express port on it. You can install any video card which uses the PCI-E x16 interface. Almost all new video cards use this interface.
Your board also has an onboard video card (ATI x300 model). You don't actually need a graphics card unless you want the better performance for games.
Specs:
http://www.intel.com/products/motherboard/D102GGC2/index.htm
Feb 20, 2009 | Intel D102GGC2 Motherboard
I have a asus p5ld2-vm/s motherboard for which i want to buy a graphic card i dont know what type the board supports either agp or pci-x.can any one help me
01.gif Intel Graphics Media Accelerator 950
The new Intel Graphics engine has new capabilities that provide a significant increase in graphics performance. DirectX 9.0 hardware acceleration, 333MHz core clock, and up to 224MB of video memory all together provide a full-value, high performance graphic
Nov 26, 2008 | ASUS P5LD2-VM Motherboard
PCI
"As of 2007, PCI Express has replaced AGP as the most common interface for graphics cards on new systems. With a few exceptions, all graphics cards being released today (2008) from ATI and NVIDIA use PCI Express. NVIDIA uses the high bandwidth data transfer of PCIe for its newly developed Scalable Link Interface (SLI) technology, which allows two graphics cards of the same chipset and model number to be run as a pair, allowing increased performance. ATI also has developed a dual-GPU system based on PCIe called CrossFire. Towards the end of 2007, AMD released a motherboard chipset, the AMD 790FX, which supports up to four PCIe x16 slots, allowing tri-GPU and quad-GPU configurations for ATI cards.
Uptake for other forms of PC expansion has been much slower and PCI remains dominant. PCI Express is commonly used for onboard gigabit ethernet and wi-fi but add-in cards are still generally PCI, particularly at the lower end of the market. Sound cards, modems, serial port cards and other cards with low-speed interfaces are still nearly all PCI. For this reason most motherboards supporting PCI Express offer legacy PCI slots as well."
Source/Link: WikiPedia
Please let me know if this helps. Good luck!
Feb 28, 2008 | Televison & Video
Graphics cards
that might be pci express new style wont work with what u have ok
Feb 03, 2008 | Gigabyte GV-NX66T128D GeForce 6600GT 128MB...
SuperMicro X7DAL-E Motherboard Logo
147 people viewed this question
Top SuperMicro Computers & Internet Experts
Tony
David
David
Victorman
Victorman
Are you a SuperMicro Computer and Internet Expert? Answer questions, earn points and help others
