Question about Danby DDW1805W Designer Series Free-Standing Dishwasher
Portable dishwasher does not attach properly to faucet sink
Hi, I have a portable Danby dishwasher and the attachment piece does not secure tightly enough to allow a smooth and not wet flow of water from the sink to the dishwasher.
HELP???!!
Thanks. Lei
4 Suggested Answers
  • 1314 Answers
SOURCE: Sink Help
it should tighten when you turn the water on ?
Posted on Mar 31, 2008
  • 10 Answers
SOURCE: Portable Dishwasher Faucet Adapter Comes Apart
I'm glad to hear that solved the problem. I hope the new adapter comes quickly.
Posted on Jun 16, 2009
  • 401 Answers
SOURCE: HOW DO I HOOKUP PORTABLE DISHWASHER BUT NOT TO SINK FAUCET
your probably out of luck. unless you can use your bathroom sink.it also needs to drain out the sams hose.
Posted on Mar 01, 2010
Hose/ Adapters for older Maytag Portable Dishwasher
The sink faucet may have to be modified by installing an adapter.
Jun 22, 2017 | Maytag Dishwashers
Attach hose to sink
what is your question? if it is how to attach there is an adapter that screws on to facet and then you connect the hose piece to that.
May 07, 2014 | Danby DDW1899WP 8 Place Setting Portable...
Maytag Portable Dishwasher coupler/faucet problem
Standard garden hose has same threads/adapter size.for trouble shooting run garden hose to washer try running cycle. Give it 20 minutes to finish previous cycle as it may not be trying to run what appears on settings. Water won't fill unless cycle that will allow such is chosen and active.
Dec 01, 2013 | Dishwashers
How do i connect a kenmore ultra wash II portable dishwasher to kitchen sink, the attachement on the hose attached to the dishwasher it to big around to fit my facuet
You can get an adapter from a local hardware store. I'd come equipped with make and model number and the screw on screen retainer piece from your faucet.
Aug 21, 2009 | Dishwashers
I have a Kenmore Quietguard dishwasher, only a few years old, and it won't drain. I pulled it out and checked the drain hose, could not find a clog. I took the basket and sprayer out, couldn't find any...
I have a Kenmore Quietguard portable that won't stay connected to my kitchen sink faucet. Checked all I can and continues to spray the wall and me without staying attached securely to the faucet adapter. Help!! Any ideas?
Jun 17, 2009 | Kenmore 24 in. 15162 Built-in Dishwasher
Jun 02, 2009 | Danby DDW1805W Designer Series...
Water not flowing into Danby 18"
Okay, this might seem crazy, but it worked. I spent the last 2 days trying to contact Danby customer service to no avail, so I came back here to look for solutions. Found two:
(1) Someone said to open the little rubber cover under the front right of the machine...I couldn't find such a cover.
(2) Someone said to pull off the front plastic panel...mine doesn't seem to be removeable.
So! I turned my Danby DDW1805 upside-down (!) to see if I could locate the aforementioned rubber cover, and a bunch of water drained out of the machine. This is what both solutions above said I wanted to happen, so I flipped it back right-side up and hooked it back onto my faucet.
Golden. Works perfectly again.
May 15, 2009 | Danby DDW1805W Designer Series...
Hose does not fit on sink faucet
Yes, the adapter was the answer!!! I went to the Sears Service Center and bought one, under $10. HURRAY! And say hello to softer hands . . .
Nov 12, 2008 | GE 24-7/8" Convertible Portable Dishwasher...
E3 code
Received from Danby customer support:
"The error code of E3 tells us that the unit is not getting the proper water temperature to continue thru the entire cycle. Before starting the dishwasher and attaching the quick connect assembly to the faucet, please make sure that the water from the faucet is warm to the touch; you can then attach the quick connect assembly with hose to the faucet and start the unit. If the water temperature does not reach 120 degrees F the dishwasher will not be able to run thru the entire cycle properly. If this is being done and the same code comes up, we will need a service tech in you area to diagnose the problem for us. For a warranty servicer in your area you can reach us at 800-263-2629 Mon-Thu 8:30-5 or Fri 8:30-4 EST."
Jun 11, 2008 | Danby DDW496W Free-Standing Dishwasher
The plastic connector separates from the metal faucet attachment when I turn on the water (PS I have the Danby 496)
IF IT IS NEW, PARTS SHOULD HAVE A 1 YEAR WARRANTY.
GO BACK TO THE PLACE YOU PURCHASED IT AND HAVE THEM ORDER A NEW CONNECTOR. IT SHOULD COME WITH
THE HOSES AND ALL YOU HAVE TO DO IS UNSCREW THE
HOSES FROM THE BACK OF THE DISWASHER AND INSTALL THE NEW ONES. IF IT IS OUT OF WARRANTY, MAKE SURE ALL OF THE SCREWS ARE TIGHT IN THE CONNECTOR. OTHERWISE, REPLACE THE CONNECTOR.
Feb 16, 2008 | Danby 22 in. DDW396 Free-standing...
Danby DDW1805W Designer Series Free-Standing Dishwasher Logo
675 people viewed this question
Top Danby Dishwashers Experts
Oloyede Monsuru
Are you a Danby Dishwasher Expert? Answer questions, earn points and help others
