Question about Cameras
Have replaced batteries and camera will only switch on for a second then goes off. samsung digital s1065
  • ahmed2009 Jan 08, 2009
    camera just switches off for no apparent reason evey now and then and this thing is only 5 days old batteries have been replaced many times yet the same issue exists
  • mwillywalker Mar 02, 2009
    hi I put new batteries in camera only came on for a few seconds then went off would not let me take any pic all i could do was view pics i had on card
Hi, i have the same camera and had the same problem. the only solution is to buy energizer lithium batteries there about £6 sometimes argos and superdrug do buy1 get 1 free they last for ages.
hope this helps
suzy
Posted on Jan 11, 2009
I have a samsung s1065 and when i try to switch it on the lens wont come out though the motor is trying i have installed new batteries
THE PROBLEM IS NOT OF THE BATTERIES. YOU MIGHT HAVE SWITCHED ON THE CAMERA AND SOMETHING MIGHT HAVE BLOCKED THE LENS WHILE IT WAS BEING PUSHED OUT. IN THIS CASE SOMETIMES THE GEARS SLIP OR GET DAMAGED .THIS MIGHT LOOK ODD BUT GIVE IT A TRY.WHILE SWITCHING ON THE CAMERA TRY TO PULL OUT THE LENS PHYSICALLY. THIS MANY A TIMES HAS SOLVED THE ISSUE. ALWAYS KEEP IN MIND NEVER TO BLOCK OR PUT PRESSURE ON THE LENS AS THE DELICATE GEARS MIGHT GET DAMAGED.
REGARDS.
PLZ. RATE THIS
Jul 02, 2011 | Cameras
I need samsung s1065 usb driver
Go to samsung's website, go to support and downloads, then do a search for the s1065 usb driver.
Nov 09, 2010 | Computers & Internet
Samsung S1065 digital camera. Won't witch on. Len won't extend, beeps three times, switches off. Any ideas gratefully accepted.
my samsung camera s1065 the lens wont extend when switching on the lens does not extend ,it bleeps 3 times but then closes down
Aug 28, 2010 | Gateway DC-M40 Digital Camera
My samsung s1065 lens wont shut and anytime i turn power on it bips 3x and goes off. lens wont close either. what can i do
tried above,but 3 beeps and dead camera has shown up on numerous forums from many s1065 owners so got repair under g/tee. if it happens again i'll have a replacement !!!
Oct 19, 2009 | Samsung Digimax D53 Digital Camera
Samsung S1065 beeps 3 times and nothing else
If you have recently dropped the camera you may have damaged the lens tube (housing). This damage will prevent the lens from moving properly and will cause the camera to shut itself off after a few seconds. If the lens is damaged the camera will require professional repair. If the lens is not damaged, the problem may be battery related. Make sure that you have the correct battery type installed, and that the batteries are fresh/fully charged. If the problem persists, you may have corrosion on the battery contacts inside that camera that is preventing full battery power from flowing to the camera. Remove the batteries and wipe the inside camera contacts firmly with a dry cloth (heavy corrosion may require cleaning with a wire brush, steel wool, or sand paper). Remove any residue that may have fallen into the battery compartment during cleaning, then wipe both ends of the batteries and reinstall them in the camera. This cleaning solves the problem about 90% of the time, and I hope it works for you.
Sep 11, 2009 | Gateway DC-M40 Digital Camera
Samsung s1065 beeps 3 times nothing else. only 6months old wont turn on. bought recommended batteries, still wont turn on
One of the 4 conditions a-batteries are inserted incorrectly b-batteries have died and need to be replaced c-you have selected the wrong battery type option on the Setup2 menu d-your camera is malfunctioning and needs servicing.
Jul 19, 2009 | Gateway DC-M40 Digital Camera
Memory
I had thesame problem when I bought my s1065, until I opened the battery compartment & found I had no memory card in, I went to Argus & bought one for £19 50p & now I can take as many photos as I like.
Alf.
Dec 20, 2008 | Samsung Digimax S630 Digital Camera
I need instructions on how to use my camera.It is ViviCam 3.6.3.2, 2.0 Mega Pixels. DC 2330 & 116L038C006363 on the bottom of the camera.
i just bought a samsung camera ,S1065 3 weeks ago. It was working very well until three days ago when i tried to change the battery. it comes on, take a picture and switches off by itself. what could be the problem?
Sep 06, 2008 | Vivitar Cameras
Cameras Logo
144 people viewed this question
Top Cameras Experts
Are you a Camera Expert? Answer questions, earn points and help others
