Question about Lite On LVW-5005 DVD Recorder
LVW-5005 the tray wont open. What do you mean by hard reset? How do I do that?
    Genius:
  • 1,550 Answers
Unplugging the power chord to unit for sometime (around 20 - 30 minutes) and plug back the power chord .
After that press the eject button for 30 seconds at times this may work and you can get back the dvd from the player .
Posted on Oct 29, 2008
LVW 5006
as a default try
please try a hard reset before going for next trys
disconnect it from the power and leave for 2 hours.
Jun 30, 2008 | Lite On LVW-5005 DVD Recorder
Lite On LVW 5005 tray will not open
Drives stick from time to time. Get a Paper Clip and straiten one end out. Look for the small hole on the front panel. Stick the clip end into the hole and push. The tray should open. Grab the tray and move it rapidly in and out seven or more times. This may stop the tray from sticking, and if not you know how to open it manually.
Dec 31, 2013 | Lite On Computers & Internet
Dvd recorder repair
Remove the cover of LVW and access the dvd assy,unscrew the 4 screws holding the dvd assy to the LVW bottom.
Remove the top and bottom shield (also 4 screws)and remove the top black plastic cover (4 screws).
You will access the dvd spindle.
Remove the dvd stuck inside.
Oct 29, 2008 | Lite On LVW-5005 DVD Recorder
The tray won't open. There is a disk in the tray and I was able to play it back. But, when I tried to eject the disk, the tray woudn't open.
something like this is a physical problem. you should contact the manufacturer to see if there is a manual eject button and if not you will have to take it apart to get the disk.
Tray will not open
hi had the same problem, unscrew the top off from panel and just like a computer burner there is a button on the front of the burner on the inside independent of the eject button, that is away from the actual eject button. my friend drilled a small hole on the front near the burner from the outside and i stick an allen key through they hole and the tray will come open, not sure why the eject buttons are dodgy, but this should work. and do u know where i can get a replacement remote or which universal contol will work?
Oct 21, 2008 | Lite On LVW-5005 DVD Recorder
Lite-on DDW-813s
Open the drive (dont break it). Eject the tray, under the tray you should see a small belt drive. Replace the belt with a rubberband of approximatly the same size (a little smaller wont hurt). Re-assemble the drive and it should eject fine. Lite-On drives seem to go through these belts pretty quick, I have fixed hundreds this way. Never had one I fixed come back for the same problem.
Feb 16, 2008 | Lite On LVW-5005 DVD Recorder
LVW - 5005
Remove the cover of LVW and access the DVD assy,unscrew the 4 screws holding the DVD assy to the LVW bottom,remove the top and bottom shield (also 4 screws)and remove the top black plastic cover (4 screws).You will access the DVD spindle.Remove the disk if you still have a disk stuck inside.Visually check the spindle sticky rubber ring,most likely some sticky material migrated on top of the rubber ring and your DVD was stuck on it. Clean the best you can with a cleaner and a non lint cloth.I used a cleaner/degreaser for electronics.DO NOT POWER your LVW BEFORE reinstalling the black plastic cover.There is a laser inside !!! You may now try and if the drawer opens and closes, reassemble everything opposite way you disassembled.
Nov 18, 2007 | Lite On LVW-5005 DVD Recorder
Lite On LVW-5005 DVD Recorder Logo
211 people viewed this question
Top Lite On Televison & Video Experts
Jaime Hernandez
jason
Are you a Lite On Televison and Video Expert? Answer questions, earn points and help others
