Question about Maytag Dryers
Put dryer belt on maytag dryer
Put dryer belt on
  • 550 Answers
Generic maytag dryer belt replacement
type 1:older models by Maytag with lintscreen under door
  • unplug dryer
  • remove 2 screws from under front panel
  • tilt front panel up from the bottom and unclip top
  • remove door switch wires
  • set front panel aside
  • remove front drum retainer 2 screws each side
type 2:newer models by whirlpool lint screen in top cover
  • unplug dryer
  • remove lint screen
  • remove 2 screws under lint screen
  • with putty knife or other blunt blade
    unclip spring clips at front corners of top panel
  • remove 1 screw each side of front panel 1/2 way from top
  • remopve door switch wires
  • tilt front panel down and unclip
all
  • withdraw drum forward
  • examine drum rollers for wear
    if worn or locked replace in pairs
  • examine felts and nylon glides(if fitted) for wear
    if worn replace
  • examin case floor for tensioner
    (sometimes broken belt ends pull the tensioner out of place its easy to see the slots on the case floor for the 2 feet and spring, looks like a power socket)
  • loop new belt around drum at wear mark of old belt
  • insert drum
  • loop belt around motor pulley
  • pull tensioner to end of travel against spring
  • loop belt around tensioner
  • relax tensioner
  • rotate drum by hand to make sure belt wont jump off
reassemble in reverse order
Posted on Oct 29, 2008
3 Suggested Answers
MNTECH
  • 1543 Answers
SOURCE: How do you replace the drum belt on a Maytag DE610 dryer ?
OK, this one's a few years old. First, of course, disconnect power to the machine. Second, remove the two phillips head screws, one at L and one at R near the bottom corners of the front panel. Third, pull the bottom of the front panel toward you and unhook it from the dryer's top. Swing it to the side. You do not have to disconnect the wires to the door switch. Fourth, remove the four 5/16 hex head screws holding the drum supports and set it aside. Fifth, put belt around the drum. The smooth side of the belt touches the drum. Sixth, belt goes to the motor drive pulley and then around the belt tensioning idler pulley. Seventh, put the drum support part back on and turn the drum by hand to make sure the belt tracks OK and has no twists in it. Eighth, finish reassembly and test. Note: genuine Maytag belts usually have installation instructions on the back of the package, with a couple diagrams.
Posted on Sep 17, 2008
  • 3074 Answers
SOURCE: 1991 Maytag dryer Model #LD 68424AAL Serial # A0190126HY
Are you sure that you hooked the belt up correctly, as it sounds like you may have missed the tensioner pulley. As this will tighten the belt around the middle of the drum
Posted on Jul 20, 2010
Need to put my dryer belt back forgot to look to see how it went
Here is a tip that will help you see how to route the dryer belt.
Maytag Dryer Belt Diagrams and Replacement
heatman101
Sep 20, 2010 | Maytag Dryers
Maytag model no: de410 Looking for manual
I need the 6 digit model number from your dryer.
May 28, 2008 | Dryers
Jul 20, 2010 | Maytag Dryers
I have a Maytag Model pyet224ayw electric dryer, The belt broke and I replaced it. Now when I put the new belt on, every time that I turn it on the belt jumps off the tention pully. Can the problem be that...
http://www.applianceaid.com/maytag-dryers.html
this site has proper belt routing pictures for several brands maytag included might be helpful the only other thing i can think of the idler may be worn out or bent or drum may be tight not turning properly should turn freely with belt loose from inside dryer
should be able to push vanes and rotate drum easily
good luck ron
Dec 10, 2009 | Maytag PYE2300AY Electric Dryer
Need help with installing belt in Maytag Electric dryer
if not able to remove rear panel,you will need to start,like most models,take top cover off and hinge back to wall then remove frt cover including door as a whole assy. lift up drum put new belt on drum ( and position in same area as old belt,it will have marks on drum from where original belt was on drum) then put rest of belt over mtr pulley and then idler pulley, turn drum by hand to align belts and put it back together in reverse order
Jul 28, 2009 | Maytag PYE2300AY Electric Dryer
Belt installation for a maytag dryer model# sde305day
Usally put dryer belt around the drum first
then around motor the tensioner pulley has to to be pulled up when you do this to get the belt around tensioner then you release the tensioner pulley to put tension on belt
Jun 18, 2009 | Maytag PYE2300AY Electric Dryer
Sep 16, 2008 | Maytag Dryers
Dryer
there iws another pully with a spring to rap the belt around neer the motor.this pully puts pressure on the belt.
Aug 19, 2008 | Maytag Dryers
PYE1000AYW Maytag dryer
dont know if this will help or not ribs go up .. flat part of belt goes against drum this has a crapping diagram of curve of belt http://www3.sears.com/imaging/ImagePageJava.shtml?productTypeID=0151200&brandID=3048&modelDesc=ELECTRIC/GAS%20DRYER&modelNumber=PYE1000AYW&documentID=M0412160&documentTypeID=PLDM&documentClassCode=PV&titleType=TUMBLER&titleID=00004&
Aug 26, 2007 | Maytag PYG3200 Dryer
Dryers Logo
1,551 people viewed this question
Top Maytag Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Maytag Dryer Expert? Answer questions, earn points and help others
