Question about Sony KP-43T90 43" Rear Projection Television
Flash Focus does not focus the TV colors are seperated
The flash focus does not focus the TV when pushed it tries but the colors are seperated.
  • 1 more comment
  • Mike M Nov 10, 2008
    watching a dvd last week, and it switched to the "red" shadow..
    I know it has something to do with convergence. But what can one do?
    Does anyone have the schematic for this? Mine was mfg August 2002.
  • clayvanvrank Nov 11, 2008
    I have a 3D look on every channel and 2 items are seen with each on the screen. Though using flash focus should work out the problem, I still see 3 crosshairs at end of process what should I do?
  • jason May 11, 2010
    have you unplugged the set for a little bit then start the antenna channel setup , then start the auto focus convergence untill the cross turns white? , then exit the auto focus/ , in that order?
  • 905 Answers
If that doesn't work it will need new convergence IC's put in as well as a resistor or two
electech
Posted on Oct 31, 2008
Won't focus colors .. can see blue red green seperate ,, tried auto focus did not work
colors won't focus and I tried using auto focus. How do you correct the problem? How do you adjust the tubes?
Jan 06, 2011 | Sony KP-61HS30 TV
Focus is off...at first it was all the colors separated I pushed the flash focus button and it straighted up some but is still slightly off...Sony model#KP61HS10 mfg. 9/2000
There is problem with your tv C board Base.First check it there is fungus if yes then replaced it with good one if still problem then focus block or fbt fautly.
Oct 28, 2010 | Sony Televison & Video
Wavy lines green and orange hue.While watching a fooball game the status bar is wavy and in two separate lines-Green and Orange-Tried flash focus and convergence and powered unit off for several minutes...
Flash focus button push,didn't solved pictures convergence problems.The tv convergence board is dead.The 2 STK convergence ICS and some or all it resistors are dead.These parts on the tv convergence board,must be replaced to solved the tv picture convergence problems.The shop,will cost u $300-350 for parts and labors.
Sep 18, 2010 | Sony KP-46WT510 46" Rear Projection HDTV
Picture looks concave ,mostly yellow,and double vision on words
Remove unshielded speakers or other metallic objects near the TV. It can cause picture distortion.
  1. Tune the TV to channel or cable program.
  2. Run the TV for at least 30 minutes.
  3. Press FLASH FOCUS on the front panel of the TV.
  4. A cross pattern appears and FLASH FOCUS begins to
    work. The adjustment is completed when the cross pattern becomes white and you are returned to the program you were watching.
You cannot perform any other functions until FLASH FOCUS has
completed its cycle. If you perform any other operation while FLASH FOCUS is in progress, FLASH FOCUS operation is canceled.
Oct 30, 2009 | Sony KP-57HW40 57" Rear Projection...
Sony kp 57hw40 Convergence Problem The screen looks distorted, Letters or words on the screen are bowed.(I can see double but the screen is stationary all the color, hue, sharpness, brightness, exc. can be...
If after the Flash Focus™ feature has been performed, the colors on the FLASH FOCUS screen do no line up (converge), press the FLASH FOCUS button on the television to begin the cycle again. If the colors on the FLASH FOCUS screen continues to appear misaligned, service will be required .
NOTE: It is recommended to perform the Flash Focus™ feature about thirty minutes after the television has been turned on and keep the room as dark as possible.
Sep 22, 2009 | Sony KP-57HW40 57" Rear Projection...
51" sony projection with distorted pic and color
The convergence amplifiers are likely blown.
Fairly easy fix if you are good at soldering.
Search this site for convergence repair.
Dan
Sep 09, 2009 | Sony KP-51HW40 51" Rear Projection...
Sony KP-43HT20 convergence problem
Replace STK-392-110s or 150s upgrade with 180s replace both ics.
Jan 04, 2008 | Sony KP-43HT20 43" Rear Projection...
Sony KP-43T90 43" Rear Projection Television Logo
362 people viewed this question
Top Sony Televison & Video Experts
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
