Question about Dell E173FP 17" LCD Monitor
Dell se198wfpv no power right out of box
How do you remove the back off of this unit. when purchased never powered up from factory. they sent new monitor but dont want to trash this any ideas?
  • josevillazan Mar 08, 2009
    dell 198wfpv went off and never came on again
  • Anonymous Mar 16, 2009
    My SE198WFPv won't power on either. Just stopped powering on last week for some reason. Does anyone know if these are covered under Dell warranty?
SOURCE: My Dell E171FP Is Dead!!
May be the power supply went down!
Posted on Nov 26, 2007
skotkolr
  • 558 Answers
SOURCE: dell E196FPf monitor power problem
generally dell monitors open from the bottom they have slight indented flat spaces for a small flat head screw driver to twist and pop the frame apart I start on the bottom left and work my way right and then open the sides carefully and last the top.
Please rate if helpful
Posted on Feb 17, 2009
  • 135 Answers
SOURCE: Dell E173FPc monitor. Screen is black, power button color cycles
First, verify the monitor is functional.
Monitor STFC (Self Test Feature Check)
Turn off the monitor
Plug the monitor power cord directly into the wall socket to remove any
surge protectors or APCs from the troubleshooting equation
Unplug the monitor video cable from the back of the computer
Turn on the monitor
The floating dialog box should appear on screen against a black background.
If the issue appears during the STFC, the monitor is defective.
What are the results please?
Posted on Feb 24, 2009
  • 152 Answers
SOURCE: Dell flat pannel monitor fail to power up after power outage
rtutt, First, before you start to tear apart the monitor any further, take pic's (close-ups) of screws, cables and their positions BEFORE detaching them from their board mounted jacks. Second, the fuse will be a small pigtail type soldered to the power supply board. It's the board that will have the connector on it that the line cord plugs into from outside the plastic cover. This is Pretty neat for you because if you forget where something goes, you can always open up another monitor. Well if you get the steel shield cover removed (BE VERY CAREFUL NOT TO RIP OFF ANY CABLES OR MULTI CONDUCTOR RIBBON FLEX CABLES) the cables can then be popped off. you can probably catch a video of monitor tear-down on YOUTUBE.com by doin a search on LCD repair. Yes I have seen some that are 8 to 12min long on the tube. Also you will be visually checking all large electrolytic capacitors for SWOLLEN tops of their aluminum can. You will need a large magnifying glass to inspect the solder side of the board for circular hairline fractures around the leads of heavy and larger "through-hole components, that have been thermally/mechanically STRESSED over the years. they will need to be resoldered. Well any way, keep me posted of your progress. Im louie12fix or lmistyrel@ aol.com PS: I have dell and will take pic's of board!!
Posted on Apr 08, 2009
  • 47 Answers
SOURCE: dell monitor
This is most likely the power inverter board in the monitor - this is common in many monitors. If it started taking longer and longer to display an image, and the power light is blinking on-and-off, that's most likely the problem. You can confirm that it's actually the monitor and not your computer or the cable by plugging in another monitor if you have one to try. If it's under warranty, send it back, if not, there are inverter boards for many common models of LCD monitors that are replaceable. The board can run anywhere from $50 on up. Depending on how old your monitor is, and how much you've invested into it, you may find it better to just replace it with a gently used one from ebay.
Posted on Jun 18, 2009
My printer doesnt make any print at all.
Can you copy a document under the glass? B&W and color?
Are you using Dell Series 5 ink cartridges?
Unplug the printer from the wall. Now remove the power brick from the back of the printer for 60 seconds. Plug everything back in. This will reset any error messages the printer has.
Power on the printer. Open the printer and take out the Dell Series 5 Black cartridge. make sure all the tape is off the cartridge and put the cartridge back in. Now do the same for the Dell Series 5 color cartridge.
Close the printer. It should print an alignment page. Any error messages?
Black cartridge = black side(left side) color cartridge = color side(right side)
Photo cartridge = black side(left side) color cartridge = color side(right side)
Dell Series 5 ink cartridges have a sensor in them that cannot be reset. Article on refilling Dell ink cartridges.
Dell Series 5 ink cartridges can be purchased at Staples, Walmart or Dell's Website.
If these ink cartridges are new, then take them to the place of purchase for a refund or replacements. If they're old, then try purchasing a new Dell Series 5 ink cartridge.
Rick
Aug 14, 2011 | Dell 924 All-in-One InkJet Printer
I want to change the power of my XPS420. Actualy,L375P00 (375w) i search a power with 450w minimum. Can you give me one or more references. Thank.
Sure patrice_gray.
1) The form factor of the Dell XPS420's power supply is an ATX form factor.
(The term Form Factor actually refers to Motherboards, but has been used for computer parts such as the Power Supply, and the computer case)
The ATX form factor for an ATX power supply is approximately 6 inches Wide, 5-1/2 inches long, and 3-1/2 inches tall. (6 X 5.5 X 3.5 inches)
The stock 375 Watt PSU (Power Supply Unit) is held in the computer case by 4 Philips head screws, (back side), and two metal clips.
With the new PSU you can just use the 4 screws.
450 Watt minimum?
Know this; A computer ONLY uses the power it needs, and no more.
If you installed a 10,000 Watt unit, and the computer only needed 100 Watts, it would use ONLY 100 Watts. (Typical power consumed by a desktop computer when surfing the internet)
Do I assume that you're going to install a better graphics card?
If so why not avoid hassles in the future, and install an economical PSU that will be ready for future upgrades?
I would recommend an OCZ StealthXStream 600W.
Why?
1) If the temperature of the PSU is kept at, or lower than 118.6 degrees Fahrenheit ,(48.2 Celsius) the PSU is capable of putting out 736.2 Watts reliably,
http://www.hardwaresecrets.com/article/OCZ-StealthXStream-600-W-Power-Supply-Review/451/9
(The above is the 9th page of the article. Here is the 1st page,
2) It has all the power cables you'll need. (Click on the Details tab)
3) It has a 120mm fan mounted on the bottom, and mesh on the back. Better airflow through the computer case.
4) The price. The one in the link is a Re-certified unit.
This means the power supply was sent back to the factory to be tested to their specs. Once found to be good, it is re-certified as a good unit.
(Could be someone bought the unit, and didn't want it. Newegg then sends it back to the factory to be checked out. They don't want to sell a bad power supply)
Dell Support, XPS 420 main page,
http://support.dell.com/support/edocs/systems/xps420/en/OM/HTML/index.htm
You may find - Removing and Installing Parts - helpful.
BEFORE you begin:
Computer unplugged from power, observe Anti-Static Precautions.
Anti-Static Precautions:
Your body carries Static electricity. Static will fry out (Short Circuit) the hardware components inside a computer.
Relieve your body of Static before working on your computer.
Computer unplugged from power, and on a table, computer case open.
TOUCH the metal frame of the open computer case BEFORE reaching inside the computer.
IF you walk away then return, be SURE to touch the metal frame again.
For additional questions please post in a Comment.
Regards,
joecoolvette
Jun 06, 2011 | Dell L375P00 (KH624) 375Watt Power Supply
Black cartridge is new. registers low ink level and does not print at all.
Unplug the printer from the wall. Noe remove the power brick from the printer for 60 seconds. This will reset any error message the printer is getting. Plug the printer back in.
Turn on the printer. Open up the printer and take out the black cartridge and reseat it. Do the same for the color cartridge. Now close the printer and it will print an alignment page. Any error messages?
If you still get the error message, then it's possible that the sensor in the Dell Series 5 ink cartridge is bad. If this is a new Dell Series 5 ink cartridge, then take it back to the place of purchase for a replacement or refund.
black = black side(left) color = color side(right)
photo cartridge = black side(left color = color side(right)
It's possible to purchase a Dell Series 5 ink cartridge with a bad sensor. Please take it back to the place of purchase for a replacement.
Rick
Mar 17, 2011 | Dell 962 Photo All-In-One InkJet Printer
I am getting the following error message: Black/photo cartridge missing
Rick
Mar 06, 2011 | Dell 924 All-in-One InkJet Printer
I intalled new ink on my computer and it says to remove tape from cartridge when I all ready did and it will not work
Rick
Jan 10, 2011 | Dell 962 Photo All-In-One InkJet Printer
The colour ink cartridge is not being identified. I have tried taking them out and putting them in again. I have powered it off and on but nothing is working. Any suggestions would be greatly appreciated
Rick
Jan 09, 2011 | Dell 924 All-in-One InkJet Printer
Dell SE198WFPv LCD monitor won't turn on.
try it on different computer and if it doesnt work replace costs more to fix than replace
Jul 06, 2009 | Computers & Internet
Power dont come on
Some of the older units did have some trouble with the connection for the power cord. Try to push in the power cord all the way and wiggle it a little bit. If it still doesn't come on the unit needs to be serviced.
The FreshAir has a 3 year factory warranty. Make sure to have the unit registered, or have an invoice showing your purchase date.
You can call EcoQuest support at 1-800-989-2299
Let me know if you have more questions
Dutch
Aug 04, 2008 | Ecoquest Fresh Air Air Purifier
Dell photo 924 ink cartridge problems
Hi ,
if you are getting the msg color cartridge missing , maku sure that it is compatible with your printer , on the cartridges you will get the part no M4646/J5566 , look for those part no's and if it is giving the error msg on the LCD display of the printer , try using the old cartridge ...try the following steps
1) put the old cartridge in and then unplug the power adapter (Black box ) from the printer.
2) wait for 30 seconds and put back the power adapter and turn on the printer, and look for the msg on the printer display. if it gives the same error msg with the old as well as the new color cartridge then its an issue with the printer , and if it does not gives the error msg with the older one then its an issue with the cartridge and if you have purchase the cartridge from dell online/phone then call them back give the order no of the cartridge that u have purchased and they will replace it.
good luck..
Jan 09, 2008 | Dell 924 All-in-One InkJet Printer
Dell E173FP 17" LCD Monitor Logo
183 people viewed this question
Alun Cox
