Question about Jenn-Air JES9860 Electric Kitchen Range
Electronic Display The display on our Jenn-Air Range (SVE47600B) has dimmed to where we cannot read the display. Occassionally we can just barely read it but mostlt not. I have been told I need to replace the EOC Board on my Jenn-Air range. Model SVE47600. The electronic display is so dim I cannot read it though it seems to set the temp. etc. How do I do this? Thank you, Char
  • josh197 Jan 03, 2009
    exact same problem
    josh@Pennhill.com
Go to, fixitnow.com for a cheap fix on these displays. It worked on my jenn air.
Posted on Feb 28, 2009
    Guru:
  • 310 Answers
For those finding this question: We rebuild these oven controls frequently at www.fixyourboard.com. We can help you save your oven at a very reasonable cost and a 2 year warranty on the refurbished oven control circuit board.
Posted on Nov 21, 2016
I ended up replacing both the display controller and the panel
Range has a very dim display
I have a Jenn-Air double wall oven with a very dim display light. Replaced c3 capacitor 68uf 35w - with a 100uf 50w cost $1.60 closes size available at Radio Shack and works good as new. Requires soldering onto the circuit board. I price a replacement part for $276.00.
Mar 19, 2014 | Jenn-Air 27 in. Electric Single Wall Oven...
Jenn-Air model #sve47600b. Today put new display control panel in. Didn't fix the problem. The display now works, but the oven light and fan will not stop running. Also the touchpad doesn't work. If it...
Make sure that you properly plugged in the keypad cable. There is the wide connector that brings all the keypad touches up to the display board, and there is the small 4-black wire connector that brings power to the control board.
For future reference, we repair electronic control boards at www.fixyourboard.com, maybe we can help you in the future.
Oct 08, 2009 | Jenn-Air JES9860 Electric Kitchen Range
Jenn Air SVE47600b dead touch panel and blower runs constantly
I have had similar problems:
Display was the Part # 71001799 circuit board..$175+labor
Oven blower problem was control relay board, part# 12001689...$224+labor
My solution. replace with non-Jenn Air.
Check Consumer Reports. Jenn Air has high repair history.
Mar 14, 2009 | Jenn-Air SVE47100 Slide-In Electric...
Display panel
Dim display indicates a "failing" electronic oven control. It will continue to get dimmer and dimmer until it fails completely. You need to replace the "clock" (sometimes called the ERC <---Electronic Oven Control)
This is a tricky repair. Be sure you have the power off (at the breaker box) before attempting this.
Tracy
Oct 28, 2008 | Jenn-Air WW27430P Stainless Steel Electric...
Electronic Display
Further inspection found that the ribbon got damaged during the re-instalation of the clock board. A new front control board had to be ordered and installed.
Feb 23, 2008 | Jenn-Air SVE47100 Slide-In Electric...
Jenn-Air Convection Oven
Our 7 year old "Jenn-Air Convection Oven", Canadian Model # SVE47600 also has a very dim display. We can barely read the temperature on the oven. Does anyone know what is wrong, how to fix it, and what it may cost us?
Dec 20, 2007 | Jenn-Air SVE47100 Slide-In Electric...
Jenn-air slide in range/convection
I put a $.12 capacitor on the display board and the display came back. capacitor in position c3, part from mouser electronics, #746-uvy1v680med
Dec 19, 2007 | Kitchen Ranges
Electronic Display
This is a common problem with Jenn-Air and Maytag that I have found. There is no way to brighten the display and usually requires the replacement of the Electronic Oven Control (EOC) board. I think this may have something to do with the placement of the board and possibly being damaged by heat from the oven over a period of time. Do you do a lot of baking? Do you use the self-clean mode for your oven a lot? These seem to be contributors to these boards failing like they do. I know of one person who has replaced the EOC 6 times on the same stove. I don't know if this is the advice you were looking for, but I hope it helps you.
Jun 17, 2007 | Jenn-Air SVE47100 Slide-In Electric...
Jenn-Air JES9860 Electric Kitchen Range Logo
907 people viewed this question
Top Jenn-Air Kitchen Ranges Experts
Mike Carew
Dan Webster
Dan Webster
Sal DeAngelo
Are you a Jenn-Air Kitchen Range Expert? Answer questions, earn points and help others
